grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Sat Oct 17, 2009 6:18 am Post subject: brake vacuum and a diesieling engine..... |
ok heres the run down
stock 1700cc block
hydro lifters
weber 32/36
well tuned. runs flawlessly (nearly)
timing is at 28-29 degrees
once in awhile when im parking on a hill and have the brakes depressed the engine will diesel just long enough for me to hear it.
it only happens when im parking on a hill...
im thinking it has something to do with my brake vacuum taking the symptoms into account.
has anyone experienced anything similar? _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
busdaddy Samba Member
Posted: Sat Oct 17, 2009 7:13 am Post subject: |
If your booster is leaking and your idle mixture is rich the extra air could provide enough mixture to keep the engine running using glowing carbon buildup as the ignition source. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Oct 17, 2009 7:51 pm Post subject: |
sounds about right on to what i was suspecting.
since im running a progressive with no pre-heat and no flat spot... im sure its a bit rich i havent gotten it on a wideband yet... since i have not got my duals onto it yet.. i dont want to dial it in untill i get those mounted..
i did however throw a good German 034 on my bus today upgrading from the utoh nine that was on it when i aquired it.
thanks for reconfirming my suspicions BD _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
cr@M wrote: |
