Loopole Samba Member
Posted: Mon Aug 23, 2010 9:51 am Post subject: |
I am running a pan-evac, this is how i have it setup. I had tiger weld the pan evac to my collecter, I have a gary berg breather mounted on the firewall, the top port is vented to the 1-2 air filter. the valve covers are vented to the breather box, 3-4 to the side port, 1-2 to the bottom port, with one port plugged. The pan evac is connected to a 3/8 port on the oil fill cap, so the engine is always pulling filtered air through the top of the breather box, then making its way through the valve covers, through the sump and out to the exhaust. When the engine is idling you can feel the suction on the intake hose when you remove it from the air filter top, as you rev the engine the suction increases. What i have noticed after a year is my oil stays clean much longer, I no longer have any crankcase odor when my heat is on, the i have eliminated the water condensation spooge you get in the crankcase when it gets cold and you are running on short trips, the only problem i have noticed is increased oil consumption, i am pulling to much oil mist out through the exhaust, i need to put a effective baffle at the oil filler cap, but have not bothered to do this yet. |
Barracudabrendon Samba Member
Joined: October 26, 2008 Posts: 298 Location: Kahuna Metal Works SoCal
Posted: Sat Sep 18, 2010 9:57 pm Post subject: |
Anyone know if this thing will fit with Kadrons or is it in the way of the push pull linkage? _________________ Building quality HWE style racks for your Type 2 Kahuna Metal Works.
1957 Bus
Turbo Mini Single Cab
1964 N Model Squareback
Ruthless Fastback Drag car |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Sat Sep 18, 2010 10:10 pm Post subject: |
Yes, it works.
[/quote] _________________ (ignore the X's ) |
BeetleBurner Samba Member
Joined: May 18, 2010 Posts: 10 Location: Oxford England
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Mon Sep 20, 2010 7:04 am Post subject: |
In 1986, I got one of the first series Berg Crankcase Breathers. they had some flaws. they didnt sit/seat just right on the generator stand. The O-Ring cover seal was impossible to deal with. But looking back at my engine in 1986, you gotta laugh. The berg breather was the highlight of the engine compartment. (what the hell was I thinking)
mark tucker Samba Member
Posted: Mon Sep 20, 2010 7:22 am Post subject: |
Eaallred wrote: |
The CB box is just fine.
The breather lines on the bottom of the box make NO difference AT ALL.
When you add oil, the oil that goes down the breather lines will go into the valve cover, drain down the pushrod tubes, and into the case.
The only thing that can make it not work well, is if you route the lines with excessive length and end up with 'low spots' in the lines that will collect oil like a P-trap from a plumbing system.
The lines entering at the bottom is the better design as it does offer more oil/air seperation before it hits the vent to the atmosphere. |
I knew there was some reason I liked this guy.he has more that 1/2 a brain!!! I kinda like the feature of the oil going through your valve covers, helps to rinse down the old oil&carbon that has accumulated in the vc& tubes so it can get stuck in the oil filter where it should be. some things are so easy ,but if you try to over think them and dont realy know what you are thinking about you will tend to run into problems that arnt there or you have made your self. thanks eric!!! ( I wonder where they thought the oil from the push rods was going????) |
vdubnut58 Samba Member
Posted: Mon Sep 20, 2010 7:38 am Post subject: |
mark tucker wrote: |
Eaallred wrote: |
That box is almost worthless. Fancy oil filler if you ask me. A true "breather" needs to breath, if its not vented it can't breath. If its all closed up like some of the pictures posted where is all your crankcase pressure going? You can add a breather to your "cb breather" then it will work properly. These may work OK on small motors. But don't try and put one of these on a 2387........ |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Thu Oct 21, 2010 8:57 am Post subject: |
isn't that what the little K&N filter ontop is for? or running them to the carbs? _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sat Nov 20, 2010 10:58 am Post subject: |
vaughn bros. wrote: |
^^^^^^^^I'm sorry to say that is NOT a Berg Breather box in your picture, that's a CB Performance breather box.^^^^^^
The Berg Breather box looks like this:
And the Bergs are remaking the old style angluar (the style I have): http://www.thesamba.com/vw/classifieds/detail.php?id=1011968 _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Posted: Sun Nov 21, 2010 7:28 pm Post subject: |
If I remember correctly, there is a port on the upper rear that may be used for running a vent tube down through the stock location, just like the stock oil filler. See hose next to Berg dipstick.
catarinoforlife Samba Member
Joined: November 15, 2009 Posts: 226 Location: Rancho Cucamonga, CA
Posted: Sun Nov 04, 2012 9:25 pm Post subject: |
Reviving an old thread! I'm looking at getting a new breather, read tons of threads, and am leaning towards something like this.. slightly modified of course..
Anyone wanna report how theirs is working out? Any quality issues arising? I will |
slalombuggy Samba Member
Posted: Mon Nov 05, 2012 5:40 am Post subject: |
I use it on my motors and have had great success with it. I put a filter on the top port and have no problems with oil spray or anything,
brad |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Mon Nov 05, 2012 7:42 am Post subject: |
Empi just came out with a ripped-off version of this breather box. They re-designed the mounting of the cover plate with (7) bolts. Much better than the (3) CB uses.
It's actually made pretty well.................
OK, everyone can start with the Empi Bashing now. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
joescoolcustoms Samba Member
Posted: Mon Nov 05, 2012 8:38 am Post subject: |
I have the CB unit on my 2165 in a '59 Single Cab. I have to "work" the cover plate and threaded risers sealing surface to get it flat to seal. It works very well as a breather tower.
But, it is a PITA to fill oil in. Makes oil changes slow and messy if you try to over feed it. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
JoeD Samba Member
Posted: Mon Nov 05, 2012 8:44 am Post subject: |
You guys sure have clean engines. |
Posted: Mon Nov 05, 2012 9:06 am Post subject: |
JoeD wrote: |
I don't go for Purddy. I go for function, so mine is clean, just not painted shinney and polished. (I run air filters, I was just dialing in the jets at the time of this picture)
Posted: Mon Nov 05, 2012 9:32 am Post subject: |
JoeD wrote: |
Everythings clean when it's new, then you use it
Yes, That's SALT Fun stuff......
brad |
JoeD Samba Member
Posted: Mon Nov 05, 2012 9:38 am Post subject: |
Whew.. thats better. I was begining to think I needed to polish my engine every night. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Mon Nov 05, 2012 4:39 pm Post subject: |
Ya right, this $!^ will strip powdercoating if left long enough. It's great for getting cad plating off of anything you want.
brad |
