How to convert wiper/washer switch to run an electric pump
Page: 1, 2, 3  Next
Jeckler
Jeckler is offline
PostPosted: Fri Oct 23, 2009 2:52 pm    Post subject: How to convert wiper/washer switch to run an electric pump Reply with quote
Copied from http://www.clubvw.org.au/how_to_modify_those_windscreen_w.htm
Put here for future reference. You never know when the above webpage might go away.
How to modify those windscreen washers so they actually work!
It's the usual yearly pink slip joke when the mechanic checks that everything on the car works. Then as usual we come to the windscreen washers and he has a chuckle about how he hasn't seen a Volkswagen with working windscreen washers since the 1970's, when the car was new.
Outline
What I've outlined below is a step-by-step upgrade to install a small micro-switch in place of the usual pressure valve at the back of the windscreen washer switch in a 1969 Kombi or any other Volkswagen where the washer switch looks like the one shown in the article below. I performed this modification on our 1969 microbus and was so impressed with the results I decided to document the process. The dash switch will work as usual but the washers will work off a 12 volt motor instead of relying on the washer bottle being pressurised with air and the dashboard will look factory without an ugly switch installed elsewhere. Note for those vehicles with the washer switch on the stalk of the steering column I will write an article in next months magazine on how this can be modified just as easily to include a micro switch.
Parts Required
Firstly you'll need to buy a 12-volt aftermarket windscreen washer motor from an automotive shop such as Autopro or Super Cheap etc, I paid $16.95 from the later shop. Then you'll need to buy a press button switch & some wire capable of handling just a few amps from Jaycar or Dicksmith. The switch I bought was from Jaycar (cat no: SP-0710), which cost a grand total of $1.20. This switch is perfect for our use, as I'll explain soon.
Above is a picture of the washer pump I used. Note the electric motor is above the impellor. This is an important point to remember for installation as described later in the article.
The Install
Firstly begin by disconnecting your vehicles earth lead from the battery for safety. You'll need to remove the windscreen wiper switch from the dashboard and label the wires so you'll know where the wires need to be reconnected later. To remove the wiper switch unscrew the plastic knob of the switch and then gently rotate the back of the switch to loosen it from the dash. Hopefully then the switch will only be finger tight and will be able to be unscrewed from the front alloy besil. Once this has been done remove the two rubber lines that go through the back of the switch that carry the water from the washer bottle to your windscreen washer nozzles located under the front windscreen.
This is what the switch looks like out of the car. The plastic piece on the right is what I refer to as the switch insert.
Above is the rear view of the switch. Note all terminals are numbered as per Volkswagens standard design.
You will need to carefully drill out the rivets on back of the wiper switch to release the plastic section from the rear of the switch and remove the plunger arrangement that is no longer needed.
You can see in the picture above I am holding the rear part of the switch that has been cut and the micro switch installed. Here it is easily seen where the original plastic piece needs to be cut.
The reason I suggested you buy the same micro switch as I have installed here (pictures above and below) is because it is the correct size to screw tightly into the back of the windscreen switch without having to go to the trouble of drilling or taping the hole for installation.
Above is another view of the micro switch screwed into place. The red button is what the insert of the switch presses against.
Above is the switch insert protruding from the back of the switch. This is the piece that needs to be carefully trimmed to size.
Screw the aftermarket switch you bought from Jaycar into the back of the plastic of the windscreen wiper switch. You will need to resecure the plastic backing piece to the switch again using two 3mm*35mm nuts and bolts. Below is the finish product.
Screw the original front knob back in place and insert the front cover with the insert that will press against the micro switch at the back. You may find this plastic insert will need to be trimmed to size to make it sit in place and also be able to reach the micro switch.
Below you may notice the switch insert is a fraction too long and protrudes too far from the front of the wiper knob. Remove the insert and trim the end closest to the micro switch carefully with side cutters to achieve the correct length.
With this done place the switch to the side and focus on the rest of the job. You will need to install that windscreen washer motor at position lower than the washer bottle because these pumps aren't self-priming (which means these motors are unable to suck fluid, they can only push fluid once it has actually drained to the pump using gravity.
Below is a picture of a pump located lower than the water reservoir in a late model beetle. The same applies for a bus. The washer motor must be lower than the bottom of the reservoir.
IMPORTANT
Before installing the washer motor look carefully at the pump for an arrow that indicates which direction of the pump is the fluids in & out directions. These pumps only pump fluid in one direction so you will need to ascertain which direction is "in & out" before you mount the pump.
Another point to remember when mounting is that the pump MUST be mounted horizontally with the in & out fittings on the pump pointing horizontally. As well as the electric part of the pump being higher than the impellor of the pump. If you fail to do this water may leak from the pump into the motor and short the motors electric circuit.
Connect one wire from the 12v windscreen washer motor you have installed to an earth point on the chassis of the car. Next connect a wire from the other terminal of the windscreen washer motor to one side of the micro switch you have adapted to the back of the original switch, this will require soldering. Then connect another wire from the other terminal of the micro switch back to the 12-volt accessories of the fuse box. That's it for the wiring..
Below is a diagram of what is required.
The windscreen fluid hose.
Earlier you disconnected the flexible rubber fluid hose from the wiper switch at two points. You will need to trace which hose goes back to the windscreen washers. This hose is to be routed back to the 12-volt washer pump you have installed. Note this hose goes to the "outward" side of the washer pump or the side in which the arrow points. Finally you will need to connect the inward side of the pump to the washer bottle. You will also need to vent the washer bottle so that a vacuum doesn't form inside the bottle when the motor is running. To do this simply unscrew the black plastic fitting on top of the washer bottle and remove the air pressure fitting that usually resides here. This is enough to vent the bottle sufficiently to atmosphere to prevent an air lock forming.
Reconnect the wires to the back of the windscreen washer switch that you modified earlier and mount his back onto the dashboard. Fill the washer bottle with water if it has been drained, and reconnect the battery earth strap. With the ignition key in the accessories position and by pressing the factory knob in on the dashboard you should hear the 12 volt washer motor run and prime with water for the first time and have a stream of water on the windscreen probably for the first time in years. And best of all you can stick it to the mechanic next time he carries out that pink slip and jokes about Volkswagen windscreen washers!
Parts required
12 Volt Windscreen washer motor - $16.95
Push button switch - $2.20
2 metres of 5-amp wire - $4.00
Install time - 1 hour.
Next month I'll detail the same install into a Kombi or beetle that has the washer switch mounted on the stalk of the steering column of the car eg: Super Bug, L bug, Type 3, later Kombi (1971 onwards)
See you on the street!
Leigh Harris
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
rokemester
rokemester is offline
PostPosted: Fri Oct 23, 2009 6:37 pm    Post subject: Reply with quote
Can this be done with a 6V system. I imagine the trick is finding a 6V washer pump? Very innovative solution by the way. I have been trying to find replacement switch washers, but they don't make them anymore. You end up having to buy a $85 dollar switch which is kind of ridiculous.
Culito
11010101
Culito is offline
PostPosted: Fri Oct 23, 2009 7:00 pm    Post subject: Reply with quote
Very nice writeup.
I thought about trying to find a combined pump/washer tank from the rear of an SUV. Pretty cheap from a wrecking yard.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Oct 24, 2009 5:37 am    Post subject: Reply with quote
Heck, I've got one from the rear of a VW Rabbit in the front of my Baja.
andk5591
andk5591 is offline
PostPosted: Sat Oct 24, 2009 5:58 am    Post subject: Reply with quote
Hey - I like what you did with the switch better than the bracket I made for mine. Will do that on the next one - Very nice.
Now, if you want real clean and don't have a super (or you are missing your reservoir), you can get the Mexi VW reservoir/pump assy and it bolts right inside the drivers side of the trunk. I did that on my 65 and it looks factory.......
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
cuizable
cuizable is offline
PostPosted: Tue Aug 24, 2010 12:45 am    Post subject: Reply with quote
This alternative method doesn't require you to drill out the rivets and trim the washer plunger;
It does require you to blindly drill into a massive pocket of energy, leading the construction of another Dharma Station.
http://forum.earlybay.com/viewtopic.php?f=31&t=18970&hilit=electric+washer
http://karakalemportre.weebly.com/ --> My Dad's Artistic Work - Check it out..! Smile
My NOS Bosch Coffee Maker
1971 Type1 1302 (1200cc)
1974 Type1 1200 (1200cc)
andk5591
andk5591 is offline
PostPosted: Tue Aug 24, 2010 4:34 am    Post subject: Reply with quote
I have done the method in the previous post twice now and it works very well. ( just drilling out the back and cutting it off - switch is readily available at Radio Shack) I just had to put a couple tiny bends in the rod to keep it from falling out of the switch. The one thing you have to watch for is the micro switch tabs wont take a lot of yanking or flexing, so I wire tie my wires securely to the switch body. Clean, easy and cheap......
Keith
Keith is offline
PostPosted: Wed Nov 30, 2011 4:52 pm    Post subject: Reply with quote
bump
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
Kirkne
Kirkne is offline
PostPosted: Wed Jan 29, 2014 3:38 pm    Post subject: elect. washer pump Reply with quote
this is just the sort of thing that ive been looking to do for my 65 bug.
andk5591
andk5591 is offline
PostPosted: Wed Jan 29, 2014 4:42 pm    Post subject: Reply with quote
Just be careful that you have enough clearance on by the wiper assembly. I have had to pull the wires at back toward the dash pretty hard so they didnt rub. BUT it works great have done it maybe 3 or 4 times now.
Kirkne
Kirkne is offline
PostPosted: Tue Feb 04, 2014 12:35 am    Post subject: Reply with quote
One concern that i have with this method after messaging back and forth with a guy from bitsbox is that the momentary switch that you show using is only rated for 250 mA and the pump is going to pull more amps than that. He didn't think it was a good idea? Does any one out there have any input as to where you can find a similarly sized switch that will hold the appropriate amount of amp?
Kirkne
Kirkne is offline
PostPosted: Tue Feb 04, 2014 12:40 am    Post subject: Re: How to convert wiper/washer switch to run an electric pu Reply with quote
Outline
Parts Required
The Install
IMPORTANT
Parts required
Leigh Harris
Jeckler
I like the idea, but before i go ahead with it do you or anyone else have a handle on how to do this with a 66-67 turn signal that has the dimmer built in for the washer pump. I have a 65 and am considering which will be easiest and most effective in long term and not have to redue any of this in terms of overloading a momentary switch.
andk5591
andk5591 is offline
PostPosted: Tue Feb 04, 2014 6:15 am    Post subject: Reply with quote
Jeckler
Its been done on here - there was a very nice "how to" I was looking for the thread the other day and couldnt find it - but wasnt looking very long.
61SNRF
61SNRF is offline
PostPosted: Tue Feb 04, 2014 7:21 am    Post subject: Reply with quote
The advise from bitsbox is absolutely correct, the micro switch is not rated for the current draw used by the pump. The small switch presents a restriction/resistance in the circuit and will inhibit the pumps output. If the pump is ran for long periods the switch will likely overheat, open circuit and become inoperative in a short while.
The problem is easily overcome by adding a relay to the circuit.
Wire the small micro switch's output as the "trigger source" shown above, then wire the pump as your "devise", and all will be well Very Happy
-Bruce
An ounce of prevention is worth a pound of cure.
Kirkne
Kirkne is offline
PostPosted: Tue Feb 04, 2014 1:57 pm    Post subject: Reply with quote
61snrf
thanks for the help, and great post. But I have just a couple questions, and I appologize ahead of time for being an electircal moron. what is the wiring schematic for? I got really confused about where I'm supposed to be attatching wires on my wiper switch, because it has 6 connectors not 5 and are numbered differently. I tried to find a diagram that used the same numbers on samba and couldn't find one. I am using a new version of the 67 bug wiper swithch.
30, 31, 31b, 53-a,b,c
is the diagram for relay only?
Kirkne
Kirkne is offline
PostPosted: Tue Feb 04, 2014 3:52 pm    Post subject: Reply with quote
OK i figured out that what you were showing is a standard 12v 5 prong relay. So that will now get wired into the circuit that will connect to the wiper switch and water pump?
61SNRF
61SNRF is offline
PostPosted: Tue Feb 04, 2014 4:15 pm    Post subject: Reply with quote
Yes, the diagram I've added is showing the relay base and it's terminals only. Install your washer pump as the "devise" in the diagram, and wire in the micro-switch's output as the "trigger source".
Remember, the stock switch has two functions,
#1-Wipers, which are electric,
#2-Washers, which are mechanical.
All the modifications within this topic deal with making the stock electrical/mechanical switch into an electrical/electrical switch.
The stock W/S Wiper switch and motor are on a totally different wiring circuit and remain the same.
Please review Smile Wink
-Bruce
Kirkne
Kirkne is offline
PostPosted: Tue Feb 04, 2014 10:18 pm    Post subject: Reply with quote
what capacity relay should i get? they seem to come in 30 amp is that standard? I need to make sure that they will activate with a small amount of current don't I if the switch is only rated for 250mA or 500mA?
Miklo
¡Chale!
Miklo is offline
PostPosted: Tue Feb 04, 2014 10:43 pm    Post subject: Reply with quote
Yes, the 30 amp relay will do just fine.
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
Goshen
Goshen is offline
PostPosted: Sun Feb 23, 2014 6:34 pm    Post subject: Reply with quote
I did the same type of modification and i hadn't even seen this thread..
I was perplexed trying to figure out why have two separate switches one for the motor wiper blades and one for the electric washer pump.
So mine didn't turn out as clean and pretty as yours but it works just fine.
and that is what is important.
This is where the washer bottle will go:
I custom made this bracket
Here it is
My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870
Page: 1, 2, 3  Next
