wokokow Samba Member
Joined: August 13, 2012 Posts: 27 Location: Nairobi, Kenya
Posted: Sat Jul 26, 2014 7:22 am Post subject: |
I've been thinking about this modification at the back of my mind and I'm glad I found it has already been done by some bright chaps on here.
Learnt a few more things in the process but forgive my ignorance I don't know how to wire a relay. The switch has two terminals (wires) and I understand one has to go on the trigger side of the relay as indicated on the diagram, where does the other switch terminal go? |
Buck Naked Samba Member
Joined: March 11, 2009 Posts: 400 Location: El Dorado County,CA
Posted: Sat Jul 26, 2014 8:27 am Post subject: |
If you are going by the picture diagram posted earlier, the other side of the switch needs to be connected to +12 volts. I recommend using a fuse and connecting to a source that gets power only when the key is on. Hope that helps.
Shane _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Posted: Sat Jul 26, 2014 9:45 am Post subject: |
wokokow wrote: |
Shane is right on the money...
that is exactly what i did.. fused it and ran to a 12+ Volt positive lead that is only powered when ignition is on...
No need for a relay because it is only temporary . you push the button to squirt and release and that is all to it.. so a relay is not important..
Thanks Shane "Buck Naked" _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Sat Jul 26, 2014 5:20 pm Post subject: |
Here's another way to mount the switch.
_________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Posted: Sun Jul 27, 2014 5:52 am Post subject: |
They make a washer bottle with a 6V or 12V pump that fits in the original location.
CIP1 sells them. _________________ 1965 Double Cab
1967 Bug, Sedan
Posted: Sun Jul 27, 2014 10:27 am Post subject: |
GuteAndTitle wrote: "That fits a standard. Look back in the thread and you'll see the car it's being fit to is a super beetle with the upright angled tank."
I'm sorry, I thought I thought I was in the 1958 - 1967 Beetle forum. _________________ 1965 Double Cab
1967 Bug, Sedan
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Posted: Mon Dec 12, 2016 6:20 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
I have been meaning to make this mod for a couple of years for our Ghia. The car already has an electric washer pump fitted, but the switch is an ugly toggle hacked into the underside of the dash.
I had got hold of a 'Mera' switch, which I thought I would use instead of the factory switch. I had a 'normally off' micro switch from Maplin and a micro relay which I might stick to the bottom of the switch.
The pics might just give people another slant on what is involved...
This is the switch, and I decided to try the technique of removing the brass peened tubes that hold the two parts of the switch together. Gently increasing drill size and a hand held brace and bit did the trick.
There is a rubber valve on the inside of the black half and to remove the spring and workings you have to cut the black part in half. I used a hacksaw but a cutoff wheel is much better!
If you choose drill size carefully, the Microswitch will screw in tightly, with no need for glue. The key is to tailor the depth that the switch sits at, so the plastic rod on the push button will trigger it properly. I sanded the black part of the switch to length. Using this method the two halves of the whole switch can be joined back together with long machine bolts.
_________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
Posted: Mon Dec 12, 2016 6:29 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
Now for the bit I didn't expect!
I thought the escutcheon, and the rubber knob and the push button with the logo would swap between the two switches...
No, no, no.
The two switches have different sized escutcheons, and the push button with the plastic rod would not pass through the newer switch body.
So, using my new found knowledge of the switch anatomy, I took my life in my hands and hacked into the OG switch...
This time I did a neater job, cutting into the switch with a Dremel cutoff wheel and pulling out the internals (after drilling the rubber valve with a large drill bit). This means the two halves of the switch stay together. Pretty quickly ended up with a nicely modified wiper switch. As I say, I'll probably use the switch to trigger the pump via a small relay.
grandpa pete Samba Member
Posted: Mon Dec 12, 2016 7:07 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
or this ;
out of a " 67" and up , 12 volt
If you do this be prepared ; you will need a longer " fender " bolt , and the gas vent line and clip have to be moved in a 12 volt 66 .
_________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
All_talk Samba Member
Joined: March 07, 2002 Posts: 114 Location: Thorp, WA
Posted: Mon Dec 12, 2016 11:24 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
For the switch I used a headlight switch with a bad dimming rheostat, pull to the first stop for low speed, second stop for high and twist for wash, the wash position is not momentary so you have to turn it back to stop the pump but simple and works.
Gary |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Tue Dec 13, 2016 12:25 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
A couple of hints, I made the same:
1) the switch has 2 terminal and pump needs + and -; I suggest to make connection directly on the main wiper switch where the source you need are already there (53b and 31), so from the two-switch-assembly exits a bipolar wire straight to the pump
2) between pump outlet and spray nozzle you need a non-return valve so spraying is immediate; they are cheap and ebay available. Elsewere after every "pumping" water returns into the bottle. |
Posted: Tue Dec 13, 2016 3:56 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
herbie1200 wrote: |
Thanks Herbie1200. I was thinking along the same lines, except I think you could have a single switched hot wire to the pump (mine is in the spare wheel well) and just have a short ground directly to the chassis.
As to the valve, I think my pump arrangement must have one already, as there is no backflow.
I'll post pics when I eventually put the car together! _________________ 1978 marino yellow Bay Dormobile camper
Johnerzen Samba Member
Posted: Wed Dec 19, 2018 5:33 pm Post subject: Re: How to convert wiper/washer switch to run an electric pump |
I followed your switch conversion and it works great. I changed the pump with one from Moss Motors for a 71 MGB, it will suck the fluid from the reservoir. I attached the pump to the the stock reservoir behind the tire on my 70 Bug Conv. I then connected the line from the tire to the top of the reservoir but it is not screwed on tight enough to with draw air from the tire. I placed a back flow preventer from the bottom of the reservoir to the pump so it holds the fluid in the line to the nozzle. Here are pictures for you to look at. It appears as stock but works like a new system.
Posted: Thu Dec 20, 2018 12:17 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
This arrangement seems strange.
Those pumps do not suck water, they should be under the level of water, to be always full of water.
you had the needing of connect the spare whell is for this issue: that pump is not auto-feeding. But in this way you lose advantages of have an electric pump; this arrangement is like an electric valve.
My suggests:
1) eliminate the hose to the spare wheel
2) reposition the pump UNDER the reservoir, find a room near the bump bracket
3) drill a small hole AT THE BOTTOM of the reservoir to feed the pump, so the pump is always filled with water. This connector can be a simple tire valve with the internal plug removed
4) at the top of the reservoir, make the existing connection free for air intake. If it is like a tire valve, simply remove the internal plug; this air is to replace the water used by pump
5) keet the non-return valve, it is fundamental to have a quick spray |
Posted: Thu Dec 20, 2018 3:49 pm Post subject: Re: How to convert wiper/washer switch to run an electric pump |
This pump does suck, I have used them before and this one sucks and sprays fine. The arrangement with the pump on top of reservoir fits well and under the reservoir does not. This set up is convenient and with the tire in place the area under the hood looks original. |
Posted: Fri Dec 21, 2018 12:52 am Post subject: Re: How to convert wiper/washer switch to run an electric pump |
To be correct: does this pump spray also if you disconnect the hose from the spare tire? My suspect is that this pump needs a positive pressure, like all other washer pumps.
The location I suggest for the pump is in a corner under/behind the spare wheel, and a small hose from bottom of the reservoir towards the pump.
All hidden, until the spare wheel is removed |
