jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Thu Jul 23, 2015 2:30 pm Post subject: |
Footloose wrote: |
Nope. 3 holes. See photo. Maybe the plastic was original after all? I pulled it out because the bugger leaked after rebuild. I suspect because either it is missing an O-ring, washer or the plastic face was worn. I will add the WW rubber piece with five holes and try again. Does anyone else have a switch with only three holes? Why would there be more than thee any ways?!?
My 58 has this style valve, it only has 3 holes as well. I just put it back together using the WW kit and I'm unsure how the dust boot goes on, anyone have any idea? The 2 tabs that stick out prevent the boot from going all the way on. |
Jrb572 Samba Member
Joined: August 30, 2013 Posts: 191 Location: St. Louis
Posted: Mon Sep 07, 2015 6:06 pm Post subject: |
Guys I was going to add to this also. For some weird reason. My brand new fuel tap from WW the long brass pipe after six months of sitting the tall brass pipe was eaten of and clogged my tap. The only thing I figured was the previous owner had cleaned the tank with some kind of acid and it was still in the tank dried to the sides if that's possible. I am hoping it was not someone I work with as it has been sitting in the shop I work for. I didn't think that soldering the brass to the aluminium would work that great. Not saying it won't. I used a thread and tap. I bought the brass tube and used my die to see what tap would work best. I took and bent the tube slightly at the top so I could spin it in by hand. I think I used a 10/32. The I used the tap on the body and screwed the long bent pice into the short side first and cut then into the long side and cut. It seemed to work good. Just a thought for someone who doesn't know how to or feel the solder will hold. |
Posted: Sun Jan 17, 2016 4:47 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Hello all,
I'm just trying to take my tap apart for rebuilding but the large securing nut is not co-operating in coming loose.
After a good bit of heat I can get it to turn about 45 but that's about it.
Anyone any ideas or should I not bother removing it if it won't effect how the valve seals to the tank?
Cheers |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 17, 2016 10:09 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Use a good penetrating oil and work it back and forth so it gets a little more movement at each try. Also the thread on the tap is LH. _________________ In Stereo, Where Available! |
Izzygt500 Samba Member
Posted: Mon Feb 01, 2016 1:20 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Hi Guys quick question,
What is the thread size for the nut and thread in bottom of the fuel tank?
Where the fuel tap/petcock attach. I just rebuilt my fuel tap and the nut has a few threads that need to be tapped with a die, and ill be cleaning the threads also from the gas tank. This for a 1957 Bug with a regular style humpback tank.
Thanks! |
Posted: Mon Feb 01, 2016 2:01 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Better to use a hand wire brush on the outside threads and a dental pick or scribe to clean out the inner threads. Apply some oil on the tank threads and see if you can work by hand the nut onto it. _________________ In Stereo, Where Available! |
60greenbug Samba Member
Joined: March 29, 2008 Posts: 41 Location: tucson, az
Posted: Thu May 19, 2016 4:22 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
I have a 60 vw bug
I am trying to rebuild my fuel reserve tap, but, cannot get the circlip on
I depress the assembly down with a socket in order to secure the retaining clip, but, it pops out of place.
Here is what I have....(pic)
Other questions now arise... when I view the WW instructions, it shows an additional washer (beneath spring), and, an additional washer at the base of where the copper filter seats, neither of which were indicated as necessary when I bought the rebuild kit.
So, 1) does anyone have tips for getting the circlip on?, and, 2) do I need the additional washers described above?
Posted: Thu May 19, 2016 4:38 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Maybe try something like a thin dental pick to make sure the C-clip is fully in the groove and have a helper too boot to lend a hand. Make sure the groove is clean of anything else in it and undamaged.
Only need one sealing washer. Aluminum of the filter sock will mold to shape and seal also.
More info in the parts manual here:
http://oacdp.org/type1part.html#f2 _________________ In Stereo, Where Available! |
Posted: Thu May 19, 2016 8:05 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Thanks Eric&Barb!
After hours of research, I found a lone post, that stated, the ring in a 'rebuild kit' was ever so very slightly thicker, and did not fit.
He went back to his original ring, and, perfection.
Precision is everything! Beware the supplier... |
Posted: Thu May 19, 2016 8:58 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Thanks for that update! Been a way long time since we bought new rebuild kits. Back then they did not come with the rubber dust boot or the clip. Figures that the original is thinner.
Same problem has been noticed with newly made rebuildable fuel pumps that have too thick and strong springs causing too much fuel pressure. Solution is to install OG spring. _________________ In Stereo, Where Available!
Posted: Thu May 19, 2016 11:49 pm Post subject: Re: CANT get the retaining clip to go back on @beth percola |
beth percola wrote: |
what a bitch
i have the tap in a vise and I have tryed a deep socket to help getting the c clip in...I have tryed a couple different ways but it keeps popping out any great ideas ?? |
I was having the same problem with the rebuild kit that I bought from WW. If you still have the original clip, use that. The one in the kit is slightly larger than the original and I couldn't get it to fit, but the og clip went in just fine. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri May 20, 2016 9:08 am Post subject: Re: CANT get the retaining clip to go back on @beth percola |
60greenbug wrote: |
what a bitch
Tw different reserve taps so maybe different parts. |
Posted: Mon May 23, 2016 11:56 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Eric&Barb, here's what I was talking about...out of Bentley....i.e. extra washer below spring and another below filter. |
Posted: Mon May 23, 2016 12:02 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Interesting! Perhaps later on they decided the second sealing gasket was not needed. Even if it was half a cent savings, over 1,000,000 cars later that would be a nice savings of about $50,000.00. _________________ In Stereo, Where Available! |
DannyT3 Samba Member
Joined: September 03, 2012 Posts: 135 Location: Norway
Posted: Fri Jun 03, 2016 5:24 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
I've a tap I want to rebuild, been searching for the gasget kit, but haven't found any... can someone enlighten me on who WW is?
thanks,
danny |
Posted: Fri Jun 03, 2016 7:03 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
WW = Wolfsburg West _________________ In Stereo, Where Available! |
Posted: Fri Jun 03, 2016 7:22 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Thanks
Just checked now, its $9 for the set, but $52 for shipping to Norway!!!
BTW anybody think its possible to make the gasket of some fuel resistant rubber? |
Posted: Fri Jun 03, 2016 8:48 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
DannyT3 wrote: |
Thanks
Give them a call direct and see if they can get that shipping cost down. Did a quick look at USPS and could get one of their small boxes sent for about $34.00 to Norway. If you have other stuff to order at the same time from WW that should bring cost down over all. Wonder how much it would cost you to do it thru Ebay with their international shipping?
You could try fuel resistant rubber, but you would need the correct thickness and harder rubber to do it. _________________ In Stereo, Where Available! |
Posted: Fri Jun 03, 2016 8:54 am Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Do a WWW search for "Reserve Fuel Tap VW":
Got this one result in the UK that might be better for you shipping cost wise. Did not dig further, but if they sell reserve taps and some of the earlier filter pieces for them they probably have the rebuild kits.
http://www.coolairvw.co.uk/Category/0/Shop_by_Vehi..._Taps.html _________________ In Stereo, Where Available! |
Posted: Sat Jun 04, 2016 2:40 pm Post subject: Re: Rebuilding your 56 to 61 fuel reserve tap. |
Thanks!
I did clean it properly, filled it with some gasoline, and it seems to be a leak free. I changed it because when I got the car, it had a leak for what seems to be the tap. But probably came from where it connect to the tank. Will try to mount it on, after cleaning the threads on the tank as well.
What is the proper way to mount it? Start with the nut of both the tap/tank, and finger tight it on both parts at the same time, or first on the tank, then the tap?
regards,
danny
Sorry, read "panicman"s description further up in this thread |
