pcnorton Samba Member
Joined: March 15, 2010 Posts: 41 Location: Indian Orchard, Massachusetts
Posted: Tue Sep 07, 2010 4:42 pm Post subject: |
Thank you for this info and foot work. I am blessed by those that go before me and share info. I hope I can do the same.
Paul |
binger59 Samba Member
Joined: December 09, 2007 Posts: 236 Location: Oswego, NY
Posted: Tue Nov 02, 2010 12:22 pm Post subject: |
I'm installing Power steering in my 1984 west and just located a part number for the low PSI side for the rack. It's a gates fitting and the part number is g25640612 it's m18X1.5 3/8 diameter hose. Hope this helps some of you folks out. _________________ Binger
1984 Westy
1986 7 Pass R.I.P. Donor van
2019 Jetta
2014 Passat
2019 Atlas
2006 Passat R.I.P.
1998 Jetta R.I.P.
1984 Vanagon R.I.P. |
Mick Ord Samba Member
Joined: April 26, 2008 Posts: 203 Location: Vancouver, BC
Posted: Sun Dec 19, 2010 3:19 pm Post subject: |
Am about to go to my nearest Parker Hose & Fitting Hydraulics Dealer and order the necessary hoses/fittings etc.
I am going to replace both pipes.
Can someone please confirm the specs etc for the low pressure return hose and fittings.
As im not entirely sure of what im doing, i would like to go into the store and present a full list of items required, so i can just pick up lines and have them fitted at the shop without too much hassle !!!
Thxs _________________ 1991 Syncro Westy- 2.5 Suby
1989 Syncro Tristar ( sold)
1988 2wd Tristar- about to start resto/rebuild !! |
Timwhy Samba Member
Posted: Sun Dec 19, 2010 3:21 pm Post subject: |
Mick Ord wrote: |
Thxs |
The Low Pressure side is M18X1.5 _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
John Sullivan Samba Member
Joined: July 04, 2006 Posts: 170 Location: Lansdale, PA
Posted: Sun Dec 19, 2010 5:24 pm Post subject: |
I replaced my steel power steering lines while I was doing the Bostig. I picked up most of the info here.
I bought 11.5 feet of the high pressure line. Fabricated with 6G-0FDLORX fittings. The gates number for that fitting is 7100-92175. This is a metric Female 24 degree cone with o-ring. It looks different then the compression style on the vanagon but mates perfect no leaks. I had the Hydraulic Fabricator use better than 4800 psi, 3/8 id hose for the high side. I used straight fittings at both ends but a 90 degree on one end might be better (the front).
The low side I used 13 feet (which I cut to fit) of what they had for standard hydraulic returns (they do a lot forklift hoses). The ID was the diameter of the return steel lines. I used heavy duty hose clamps and left about 5 inches of the old tube attached at the steering rack. Cut with a standard tube cutter. I mated the other end to the reservoir at the rear.
I ran the new lines 90 degrees through the center opening of the gas tank and then over toward the pass side and along remaining sections (that I left) of the old lines. Gave me something to tie them to.
They work great plus major peace of mind. Total cost was less then $75. |
denn704 Samba Member
Joined: March 14, 2011 Posts: 21 Location: Mason Michigan
Posted: Mon Jun 27, 2011 1:31 pm Post subject: bump |
Can any one be more in detal to what size fittings I need p;eas.. |
jbeaulie Samba Member
Joined: September 20, 2009 Posts: 99 Location: Cincinnati
Posted: Fri Apr 19, 2013 7:19 pm Post subject: |
Took the fittings from the original steel lines to my local Parker Hose vendor today.
HIGH PRESSURE LINE:
11.5' hose, straight fitting on pump end, 90 degree on other. Part number for the whole thing: F436-C5-C3-10-10-6-138
$103
LOW PRESSURE LINE
13' hose, no fittings on either end. Part number: 836-8-RL
$62
HOSE CLAMPS FOR LOW PRESSURE LINE
Stainless steel, size 6 ABA clamp. Part number: SS12020.
$4.25 each
Fit like a glove, though I cut the low pressure line down to 12 feet. |
chazz79 Samba Member
Posted: Fri May 24, 2013 7:59 pm Post subject: |
did mine today
140.00 covered both lines.
It would've been cheaper but the guy messed up and made both lines out of high pressure.
I opted for the low pressure 90 fitting with 13' of hose open at the end. My low pressure line was pretty nasty so I didn't want to risk leaving any of it.
The hose I went with is 2600 working,14000 burst. I think you guys are erring on the side of caution and really over buying your hose.
My hose sets would've been @50.00 more using the 4800 stuff ( almost 2.00 more a foot)
So price your hoses as the gates 2600psi. I use this on most of my tractors/backhoes misc and it's held up fine _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Fri May 24, 2013 9:44 pm Post subject: |
On the way home from SyncroFest this year we detoured to an obscure road that goes over Parkfield Grade. It is a slow going, steep, hot (+90F) dirt road...lots of scenery and fun.
Halfway up the grade my Syncro's power steering started feeling thick and heavy. Never done before or since so I attribute the problem to over HEATED fluid. I feel this calls for a PS fluid cooler like most modern cars and all most all trucks. Search forum and found nothing out there on the subject or modification. Anyone add a cooler for the PS fluid? If so would like details and the all important photos of you install.
Thanks _________________ '65 T1 Sedan
'87 T3 Syncro |
Posted: Fri May 24, 2013 9:49 pm Post subject: |
Not a problem with the amount of fluid these circulate. Most factory coolers were just a small loop of hard line, the vanagon came with 25feet of "cooler".
No leaks but hard steering? Check your steering u-joint _________________ One day as a lion, or a lifetime as lamb
slo356 Samba Member
Posted: Fri May 24, 2013 9:56 pm Post subject: |
Thanks for the suggestion. Only hard to steer when VERY HOT this one time. Probably not related to u-joints, btw, this rig has 78k miles, no leaks or other symptoms. My bigger trucks (3/4 to one ton) , have an actual "oil radiator" to cool PS fluid. _________________ '65 T1 Sedan
'87 T3 Syncro |
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 937 Location: NE Ohio
Posted: Sat Jun 01, 2013 11:08 am Post subject: Aftermarket lines |
My lines sprung a leak early this spring and I've been running without PS since. I knew it was a matter of time before the old rusty lines would let go, so I had this thread bookmarked for when I would go the DIY build my own lines route.
However, I see now that Busdepot is offering pre-made lines all ready to go. From the picture it looks like Parker hoses and fittings they have already put together. $180+shipping. And they usually give a Samba discount. I'm going to give them a try Saves me the time of driving 30 minutes to my nearest Parker hose dealer.
http://www.busdepot.com/251498100
_________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
focusedcycling Samba Member
Joined: September 10, 2010 Posts: 56 Location: Annapolis, MD
Posted: Thu Jun 06, 2013 4:03 am Post subject: |
Just had a new High Pressure line made up at a Cauliflower Inc (Parker Hose Dealer) here in Annapolis MD.
I used the straight fittings. The guy gave me a blue hose.
I aksed about using a lower psi burst rate hose, he said the 4800 is the most common and so the price is not much different.
Took the guy all of 3 minutes to do, cost me $158...
Ohh well, good to have it done and done right. Now I will have to save up to get the LP side down.
-Ben |
FalcorWesty Samba Member
Posted: Tue Jun 25, 2013 10:47 am Post subject: Re: Aftermarket lines |
Have you installed these yet? I'm about to and order them. I have a 1984 Westfalia (site lists them as only fitting 85-91) but I called busdepot and they claim they will fit mine as well. Let me know how they worked out. Thanks!
James 93SLC wrote: |
Posted: Tue Jun 25, 2013 6:08 pm Post subject: Re: Aftermarket lines |
Not yet. Other projects have taken precedence.
FalcorWesty wrote: |
91 Vanagon Carat
93 Corrado SLC
insyncro Banned
Posted: Wed Jun 26, 2013 6:16 am Post subject: |
James,
Does the low pressure hose have crimped ends as pictured and not just bare hose with clamps?
TIA |
the stormtrooper Samba Member
Joined: June 09, 2010 Posts: 11 Location: Vancouver, BC
Posted: Sun Jul 07, 2013 8:34 am Post subject: |
I'm in the middle of this now and struggling to get the old hard lines out from over the fuel tank. Any tips for this? Are people dropping the fuel tank to do this? _________________ ~~~~~~~~~~~~
87 2WD GL Automatic Bostig Zetec |
wecm31 Samba Member
Joined: August 05, 2012 Posts: 360 Location: Eganville, Ontario
Posted: Sun Jul 07, 2013 8:45 am Post subject: |
I cut the lines just rear of the tank and abandoned the pieces above the tank.
Not worth dropping the tank for me, it was no problem threading the hoses
through the tunnel.
Next time I drop the tank, I'll think about removing the lines then. _________________ Gerald P
1985 Vanagon (Betty) & 1985 BMW R80RT (Wilhelm)
vintage boxers!!
Gone are the days we stopped to decide
Where we should go, we just ride:) |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Thu Jul 11, 2013 1:56 pm Post subject: Retro-fit from an '85 Westy wreck |
I just dropped the fuel tank, removed the old rack and pinion for installing a power steering unit from an '85 Westy that was totaled in a wreck back in 1995. The unit, as well as the hard lines, are in excellent condition (no rust with less then 75k miles on them)
Unfortunately, the one fleixible pressure line from the hard line back to the engine bay has gone missing. So, I need that line.
Besides length of hose, what do I need to tell the hose shop? It will require a female fitting on one end and a male fitting on the other end, both being the same as far as fitment.
I have the short flexible pressure line with the banjo fitting. I suppose they can figure it out from there.
The TDI ALH power steering pump will be pushing this unit.
Info welcome! _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
hippiepilot Samba Member
Joined: June 18, 2008 Posts: 455 Location: Sarasota, FL
Posted: Sun Aug 25, 2013 11:52 am Post subject: |
Going through this ordeal myself and was wonder how the hoses from Bus Depot hook up to the power steering pump. http://www.busdepot.com/251498100 Do you still need the "bango" connector as well as low press side hose or do these hoses hook up directly to the pump itself. _________________ 83 air-cooled Westy
91 Carat (daily driver)
http://www.changeisland.com |
