shmoe2k Samba Member
Joined: August 09, 2009 Posts: 160 Location: Camarillo, CA
Posted: Wed Nov 04, 2009 10:14 pm Post subject: |
Here is one more way. T off the oil sending unit and put a pressure switch in there. There should be enough fuel in the float bowl to start the vehicle so you shouldn't have any extra cranking time. the good thing is when the engine dies for some reason it will shut the fuel pump off. The fuel pump should be run off of a relay. when you wire the fuel pump you should be coming from the battery to the relay to the fuel pump. There should be a wire from the ignition switch to the pressure switch and then to the fuel pump relay. |
thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Wed Nov 04, 2009 11:13 pm Post subject: |
Ok, that sounds like a good plan except i have a type 3 engine converted to a type 1 which means the oil pressure switch sticks out right next to the crank pulley. But I havent looked at it with that plan in mind yet, so it might work.
Thanks _________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
Posted: Thu Nov 05, 2009 11:18 am Post subject: |
thesatelliteguy wrote: |
Thanks |
Get a steel braided line and you can run the oil sending unit and T away from anything that might be in the way. Give that a shot if need be. |
Posted: Sat Nov 07, 2009 9:48 pm Post subject: |
well i got lazy and anxious (it started raining just as i was starting to put the pump in. so i wanted to go play in the mud) and just put a switch in that gets its power from the ignition.
Now im trying to get a 1 piece front end i found for $200. It also comes with two rear fenders and two spare front fenders(though i dont know what i would need two front fenders for). the guy also has a roll cage for $200 more and some seats for $150. i want them all but can only afford the fiberglass. _________________ Toyotas are so bumpy it makes me sick, literally.
Posted: Sun Nov 08, 2009 2:24 pm Post subject: |
So im curious on how to cut up my baja to fit this one piece fron end on. Does any one have an idea and some pics you could share? _________________ Toyotas are so bumpy it makes me sick, literally.
plotch Samba Member
Joined: December 22, 2004 Posts: 540 Location: jeffersonville, vermont
Posted: Sun Nov 08, 2009 4:21 pm Post subject: |
Don't forget to check the fuel pressure that your carbs like to run at. You might need a regulator. |
Posted: Sun Nov 08, 2009 6:48 pm Post subject: |
I just got back from picking up my new parts. I got the one piece front with the tilt bumper, front and rear fenders, nerf bars, a rear bumper and a 6 point roll cage for $300. Score!!! Tomorrow i think i will put the new roll cage in. Im really excited to do this. _________________ Toyotas are so bumpy it makes me sick, literally.
crazyman1 Samba Member
Posted: Sun Nov 08, 2009 7:08 pm Post subject: |
YOU SUCK`````````LOL Just kiing. Good score
I just got back from picking up my new parts. I got the one piece front with the tilt bumper, front and rear fenders, nerf bars, a rear bumper and a 6 point roll cage for $300. Score!!! Tomorrow i think i will put the new roll cage in. Im really excited to do this. |
Posted: Sun Nov 08, 2009 9:23 pm Post subject: |
^ Yeah it seems like i too go around saying that at a few people that get really good deals. It'll come to you man, you just got to search. And not to rub it in i also got two rear side windows and a rear windshield out of a 69'. They're tinted and for sale if any one wants them. I also want to sell the extra rear bumper and the front fenders. the fenders are for a bug eye kit. Im also going to sell my current baja kit. Its a rare one so if any one wants it, or any thing else i mentioned, let me know.
But for now i just got done putting in the roll cage. I wasnt going to do it tonight, but i got the center hoop in and the rear arms so i figured "what the heck!" and did it. I had a hard time getting the stock seats back in because the front hoop was in the way. It also makes it a pain in the ass to get out, I almost faced planted the first time. I can see this being a problem after a few beers, i probably wont care by then. I ended up just cutting off part of the seat track on the seat and it slid right in. I really want to start adding to the cage to make it better and stronger, as well as extend it to the front beam and back to the frame horns, but im planning on swapping to an IRS pan some time soon so i would just have to cut it apart. i do see a few parts i can tie together here and there though.
Tomorrow i plan on cutting the front off so i can fit my one piece on there. _________________ Toyotas are so bumpy it makes me sick, literally.
olmer2 Samba Member
Joined: June 28, 2009 Posts: 781 Location: chattanooga TN
Posted: Sun Nov 08, 2009 9:32 pm Post subject: |
Nice work. PICS PICS!!!! You one heck of a deal! congrats |
Posted: Sun Nov 08, 2009 10:29 pm Post subject: |
Ok here's some pics
The rear. I plan on putting in one cross bar under the window. I dont know what im going to do with the bumper supports (the green tubing). Tell me what you think (keep in mind i plan on swapping to IRS soon, though i dont know when). Cut them apart and tie them into the cage, then connect the cage into the rear bumper? Just leave it be? Or take some tubing and just connect them the way they are?
For those who are interested in my old baja fiberglass, heres a pic of the front.
Any one interested in an engine cover?
Or the bug eye front fenders?
Bajabro Samba Member
Joined: October 15, 2008 Posts: 284 Location: Arizona
Posted: Sun Nov 08, 2009 10:41 pm Post subject: |
Noice!! I like your door panels! _________________ 65 Baja (selling$$)
62 Dune Buggy (Selling$$)
Dads 66 Dune Buggy (building)
New 71 irs baja- work in progress |
Posted: Mon Nov 09, 2009 2:06 pm Post subject: |
This morning i got to putting my new one piece front on. Heres some pics
old front fenders removed. I kind of like this look. i was tempted to take it out for a lap around the block, but i decided not to get distracted.
Hood and nose removed.
Starting to make the cut to get the body metal off
This brand new cut off wheel came apart and one piece hit me in the chin. It didnt hurt as much as i would think a disk spinning at 3000RPM would.
Front body removed. Im excited to be able to see all the suspension components.
Im wondering what to do with this lip. Should i grind it back further or should i just beat it back with a hammer?
Ohh yeah i got another one piece front end. Its for sale for a cheap $20. easy come easy go.
And the (almost) completed new front. I just need to secure the back side with some hood pins and mount the bumper a little better. Right now its just tach welded on the mounts that the C clamps are on.
Nachodaddy77 Samba Member
Joined: October 31, 2009 Posts: 149 Location: Sacramento, Ca
Posted: Sun Nov 15, 2009 12:17 pm Post subject: |
what are you doing with the old front bumper? i need one for mine. |
Posted: Sun Nov 15, 2009 4:50 pm Post subject: |
did you cut out that z bar thing on the rear. im debating on cutting mine out just wanted to hear frome someone that has to see how it does |
Posted: Sun Nov 15, 2009 4:55 pm Post subject: |
no its still on the car. i have been planning on taking it out but im lazy and its dirty and muddy under there. _________________ Toyotas are so bumpy it makes me sick, literally.
Posted: Sun Nov 15, 2009 5:47 pm Post subject: |
can you take pics of the rear mounts for the onepiece front? did you use dzus fastners? a close up with the nose on and off whould help alot |
