thesatelliteguy Samba Member
Joined: January 06, 2007 Posts: 1515 Location: Santa Rosa CA
Posted: Wed Jun 29, 2022 1:38 pm Post subject: Re: Satellite Guy's build page |
Ive got 30" tires on it right now. And it looks like I have enough space between the tire and body that I can go with a bigger tire.
These pics are with the yellow tubes 3.5" off the ground.
_________________ Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878 |
JWHracing Samba Member
Joined: September 17, 2008 Posts: 234 Location: Mesa, AZ
Posted: Wed Jun 29, 2022 1:53 pm Post subject: Re: Satellite Guy's build page |
That's the problem with the subaru motor is they hang a lot lower than a vw motor. so you're giving up ground clearance for sure. _________________ 65 Baja - Class 5 Unlimited Race Car
2021 STORR Pro Air Cooled Buggy Champion
2019 AZOP Unlimited Buggy Champion
2017 SADR 1300 Class Champion
2016 AZOP Limited Buggy Champion
Currently "retired" from racing |
Posted: Wed Jun 29, 2022 2:43 pm Post subject: Re: Satellite Guy's build page |
With that 002, I can definitely tell you, you will want a 32-33" tire to bring the rpms down. If it is stock you will be doing 3500 rpms at 60-65 mph. You will be much better with a bigger tire and that will help with the ground clearance. _________________ 65 Baja - Class 5 Unlimited Race Car
Posted: Wed Jun 29, 2022 3:31 pm Post subject: Re: Satellite Guy's build page |
I just found out that a Subaru trans will hold the engine up higher then the 002. So that’s a plus. But that’s not going to happen for a while.
I’m thinking, set the compression at 3” before bottom out. Plan to put bigger tires on it. That’ll gain me an inch. Your right. It does run high in the rpm’s. 60 mph is 3000rpm. That’ll be another benefit of bigger tires. _________________ Toyotas are so bumpy it makes me sick, literally.
dustymojave Samba Member
Posted: Wed Jun 29, 2022 5:24 pm Post subject: Re: Satellite Guy's build page |
I agree that I would have those yellow bars up against the yoke tubes. But I understand the extra depth of the Subie pan.
Have you thought about using a low profile oil pan? Skidmark cut his Subie oil pan for more clearance under the car years ago. The info is probably not on this forum. You might find him on Shop Talk Forums/Offroad Forums. He talked about it/shared pics on SoCalBajas.com. If I removed depth from the oil pan, I would want to make the bottom of the pan wider like a road race pan for a V8.
Google it too. _________________ Richard
SoCalBajas Member
Posted: Wed Jun 29, 2022 5:28 pm Post subject: Re: Satellite Guy's build page |
Thanks Dusty, Ive already cut the pan down tho. I think i took about 3" out of it. IDK. it was a long time ago. I was thinking "dry sump?". lol I dont think its worth the work tho. _________________ Toyotas are so bumpy it makes me sick, literally.
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Thu Jun 30, 2022 8:12 am Post subject: Re: Satellite Guy's build page |
one more question:
What kind of angle can you get with the sway away 930 kit?
If I remember right I can get 21 with my empi race 930s *edit* prep T2 cvs, but I end up keeping it more around 17 because of the stretch going on with my limit straps and the racket they make if I don't.
I have 2X3's and I end up with around 10" of travel which is why I ask.
Thinking I might be able to find a little more travel like you did... _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Thu Jun 30, 2022 9:16 am Post subject: Re: Satellite Guy's build page |
Orange,
Ive got my eyes on the FOX 2.5 Performance series with Dual Speed Compression Adjusters on a remote reservoir, in 14" length. SKU: FOX-983-06-105-S Coming in at $884 each with springs and tuned from accutuneOffRoad.
For the 930's, i got GKN Stock German 930's from Kartek and then i ordered a polishing drum for the die grinder and race prepped them my self.
Ive read that 930's can do 25*. I honestly havent measured what mine are binding at.
Im getting 13.5" of useable travel. And my motion ratio is 1:.8 _________________ Toyotas are so bumpy it makes me sick, literally.
Posted: Thu Jun 30, 2022 1:20 pm Post subject: Re: Satellite Guy's build page |
Back in the 1980s, I was using 28° for 930 CVs on the race cars I was prepping. I NEVER had a CV failure other than a torn boot.
One Raceco 1600 buggy I prepped came from Raceco with 16" of rear travel. That put the bottom of the 33" Yoko Super Digger IIIs well above the bottom of the skidplate. So I limited the up travel so the skidplate would not touch the ground. Hated the loss of travel, but when the belly of the car hit it was NOT a pleasant experience. Replaced a lot of rear skidplates before then too.
These days, the 5/16 Baja Bugs and 1600 buggies (which are both limited to 0x1 arms) are mostly getting around 16" of travel with microstub hubs. One 5/16 guy who has stuck with VW hubs says he gets about 12" travel.
So with 3x3s, I keep wondering why you guys keep limiting your suspension. _________________ Richard
SoCalBajas Member
Posted: Sat Jul 09, 2022 6:15 am Post subject: Re: Satellite Guy's build page |
Im limiting my suspension because I hear that bottoming out the belly is not a pleasant experience. And i would believe it. That seems like a lot of spine crushing. _________________ Toyotas are so bumpy it makes me sick, literally.
Posted: Sat Jul 09, 2022 6:41 am Post subject: Re: Satellite Guy's build page |
I got the shocks ordered (or should i say back ordered). Now ive turned my attention to brakes while i wait for the shocks.
I have Jamar 4 piston calipers for the rear with Wilwood MC4 mechanical parking brake calipers. And i have good old drum brakes on the front. I had to make the mounting bracket for the Wilwoods to attach to the rear trailing arm. Thats where the new CNC plasma table came in handy. Id like to put in brand new disk brakes in the front, but thats just not in the budget right now. I have the front/rear bias adjuster for the wilwood brake pedal so i think that will help with balancing the brakes.
I drew up a diagram for my brakes and included every hydraulic adapter and fitting so i could get a proper order together.
I hate plumbing.
It's such a fricken headache. But the diagram makes it a lot easier.
So, I got an order together. I decided to use -3AN for everything bc I couldn't find stainless steel braided brake hose with an inverted flare end. Also, I like how the wrench size for -3an are bigger than the wrench size for inverted flare.
Before I can get going, I would like to cut away the tunnel by where the gas pedal will go. There's not enough room down there for my foot so I think I'll cut out about half the tunnel and fill it back in. Then the brake and clutch line will enter the tunnel right behind where my foot will be. Or maybe in front of the gas pedal. I'm not really sure yet.
But anyway, this will be a fun challenge. I'm glad I got that giant hole cut out in the foot well for this.
Posted: Thu Aug 18, 2022 4:50 pm Post subject: Re: Satellite Guy's build page |
So I didn’t end up getting very far with the brakes. I got the rear line going back to the tee. And that was about it. Lost interest. But that was because the shocks got ordered and delivered a few days later. I was expecting at least eight weeks for a turnaround, but I guess they had some ready to ship out. So I got after it, setting up my rear cage and shock mounts.
Posted: Wed Aug 31, 2022 6:06 am Post subject: Re: Satellite Guy's build page |
Got a little more done over the weekend and after work. I just need to fully weld everything and I can set the car back down on the ground without jackstands. It still needs limit straps and it’s been suggested to me that I put internal bump stops inside of the coilover. i’ve never seen or heard of that before but my good friend that builds off-road race cars for a living has recommended it.
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Thu Sep 01, 2022 6:20 pm Post subject: Re: Satellite Guy's build page |
Looking good! _________________ it's more fun loud and dirty |
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Fri Sep 09, 2022 9:14 pm Post subject: Re: Satellite Guy's build page |
build is looking good,
if your friend is talking about the same bump stop i have, it is a rubber type stop that slides over the shock shaft. the shock itself has to be fully disassembled to do it though. i built a pretty solid skid plate for my car because of the oil pan. kind of boxed in the area of the oil pan that hung down a little bit.
as for 930cv angels for whomever was asking i have mine strapped at 28deg. been running this way for roughly a year now. They are GKN's with chromoly cages and have been polished/ race prepped. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Fri Sep 23, 2022 6:14 pm Post subject: Re: Satellite Guy's build page |
Bad_chopper wrote: |
as for 930cv angels for whomever was asking i have mine strapped at 28deg. been running this way for roughly a year now. They are GKN's with chromoly cages and have been polished/ race prepped. |
That's the angle I used to use on 930s for offroad race cars back in the 1980s and 90s when I was operating my offroad race prep and fab shop. _________________ Richard
SoCalBajas Member
Posted: Sun Nov 27, 2022 7:45 pm Post subject: Re: Satellite Guy's build page |
I got everything welded up. The upper mounts moved on me a little bit so the through bolt didn't line up unless i took a BFH to it. So i got out the old die grinder and clearanced the inside. I've had that die grinder fopr years but have never used it bc I didn't have bits for it. Damn! That thing does work. It's my new favorite tool.
Anyway, cleared up that problem, installed the shocks with the springs on and sat it down on its wheels for the first time in probably a year and a half! It was a good feeling to see it like that, but the battle is nowhere near over. I noticed while it was sitting in my garage that the front seems to be up higher then the rear. I'm not going to jump into fixing that problem yet, not until i can drive it around and see it outside the garage. But it was kind of a let down. But, this is my first time building a car like this, i don't have anyone physically here to help me, and i don't do this for a living. So over all, I'm still pretty happy. Gotta stay up ya know?
I lost motivation and it sat for a while after that, about 2 months.
A couple days ago, just before thanksgiving, I came home and just jumped back into it. I built some limit strap upper mounts and cut out the lower mounts on the CNC plasma table. Got those installed and was happy. I realized that if I get the bump stops built and welded in, i would be done (for the most part) with the rear suspension. So after a Tequilla, i was all fired up to get it finished. I slammed those out yesterday and today.
I also got the rear brake lines finished up. I'm not sure i want to put brake fluid in it yet as i might have to take it apart again before final disassembly for paint.
I used 3/16" stainless brake line and -AN flares. I really like working with stainless steel. Its harder to bend and manipulate then steel lines, but it just looks better and seemed to be easier to straighten out. Any way, on to the pictures
