allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Fri Oct 30, 2009 4:42 am Post subject: Have my gowesty springs installed what else? |
I have the springs a new set of bilstein shocks and the ball joint spacers going in. Anything else I should have them do up front while they are in there? _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Oct 30, 2009 7:07 am Post subject: |
I'm in the process of tearing down and reassembling my entire front suspension. 2WD.
California van '89 saw some mountain roads during ski season. Overall rust moderate. Otherwise in very good shape.
The rubber bushings have shown to be in surprsingly good shape.. Even at 20 yrs and 170k miles.. but am replacing them all anyway, since its being entirely torn down.
The steel sleeve bushings on the radius control arm and the sway bar link (lower bushing) are both badly corroded. These should be looked at.
If you are doing extensive work up front, it might be worth taking a closer look into both areas and if not replacing now, plan on it in a yr or two.
The sway bar link steel bushings are still available. The radius control arm steel bushings are currently not. But Van Cafe is looking to have them manufactued locally. Samba member Tschroeder made his own out of stock pipe. He stated his were corroded to "dust".
Also, if you are runnning out of room for getting a decent alignment, I am told that the upper control arm bushings and adjustment washers may need replacing. Bentley has diagrams for identifying wear on the control arm bushings.
$0.02.
(This project started out as "just replacing the upper ball joints".. hahaha.. Now it includes Audis brakes, 16" wheels, VanCafe modest lift springs and all new front end rubber) _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Fri Oct 30, 2009 8:47 pm Post subject: |
yeah it all starts with a just gonna do this. And then you end up many thousands into it. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Oct 30, 2009 9:28 pm Post subject: |
Go Westy has the radius arm steel bushings. You just have to call and ask them. I got some about a month ago. _________________ 89 Westy 2.1 Auto |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sat Oct 31, 2009 7:01 am Post subject: |
How about inspecting the condition of the brake lines while your in the vicinity. |
ZimZam Samba Member
Joined: July 21, 2005 Posts: 562 Location: Talkeetna, AK
Posted: Sun Nov 01, 2009 10:39 am Post subject: |
SVX engine swap! _________________ '85 Cabriolet (Margo)
'87 Westy (Heidi)
'75 Porsche 911S Targa
"Nobody trusts anyone, or why did they put tilt on a pinball machine.”
- Steve McQueen
"It's just metal, when rusted and dented , anything you will do will be better. Stop being afraid. What they (VW) did many year ago is not better then what you will do now." -Ben |
Posted: Sun Nov 01, 2009 11:06 am Post subject: |
I just finished my swap. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
