Randy in Maine Samba Member
Posted: Mon Nov 02, 2009 12:53 pm Post subject: 71 vacuum set up |
I am trying to help my buddy out here on his missing vacuum lines on his new 71 westy. 009 in there now. I think he has the correct air cleaner. I saw no altitude compensator.
I have the DVDA carb lines figured out and the brake booster off the intake manifold all figured out.
Where does the small vacuum port on the 3/4 intake runner plug into?
I tried to search for it, but nothing really came up.
Thanks! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16923 Location: San Diego, California
Posted: Mon Nov 02, 2009 1:04 pm Post subject: |
Hey Randy,
I had a 1971 bus for many years running a 009. That 1/4 inch tube sticking out of the 3&4 cylinder intake end piece was always plugged off. I'm not sure but I think it ran to an altitude compensator which I had shit canned years ago.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Nov 02, 2009 1:10 pm Post subject: |
Here ya go from the gallery
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Desertbusman Samba Member
Posted: Mon Nov 02, 2009 1:22 pm Post subject: |
^^^^Ditto^^^^ (the first pic and description)
With a 009 the only vac line on the engine is the booster on a '71. With a vac distributer it's just the vac connection/connections? at the carb. The port on the LH manifold is blocked on both my engines. And I havn't recognized any need for the altitude compensator unless the daily drive is from Death Valley to Mount Whitney. The oil bath connects to the vapor canister and the canister also connects to the port on the shroud RH side. But that's not vac.
_________________ 71 Superbug
71 Westy |
Posted: Mon Nov 02, 2009 1:45 pm Post subject: |
Thank you! |
