dillon schuh Samba Member
Joined: July 21, 2003 Posts: 343 Location: Sacramento
Posted: Fri Nov 06, 2009 8:55 am Post subject: need a better ride |
My notch was lowered and it rides like crap. No suspension at all. It rides on the rubber. what do i need to do to make it better.
Thanks |
Gizmobob Samba Member
Joined: December 06, 2006 Posts: 1001 Location: Apple Valley, CA
Posted: Fri Nov 06, 2009 9:11 am Post subject: Re: need a better ride |
dillon schuh wrote: |
Thanks |
Raise it back up
Just a thought... there's no shame in 'pimpin' purist style
Giz _________________ "And now, in the interest of equal time, here is a message from the National Institute of Pancakes: It reads, and I quote, "Fuck waffles." " - George Carlin
'61 Type 311-Black
'62 Type 311-Gulf Blue (Germany)
'62 Type 313-Anthracite (Germany)
'62 Type 311-Gulf Blue (Italy)
'63 Type 361-Anthracite (Sweden)
'64 Type 343-Pacific Blue/Blue-White (Germany) |
Posted: Fri Nov 06, 2009 9:14 am Post subject: |
Cant do it... haha |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Fri Nov 06, 2009 9:27 am Post subject: |
Cut off the bump stops? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Nov 06, 2009 9:51 am Post subject: |
I have a couple good front ends that have not been slammed. I even have a couple of pans. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3685 Location: San Jose, CA
Posted: Fri Nov 06, 2009 2:00 pm Post subject: |
no other acvw rides better than a stock height type 3...
then again, no acvw looks better than a lowered type 3...
pick your poison. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
vwfye Samba Member
Posted: Fri Nov 06, 2009 2:24 pm Post subject: |
69SquareGuy wrote: |
pick your poison. |
actually not quite true. no a/c vw rides better than a 412! but it don't look good _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Fri Nov 06, 2009 2:29 pm Post subject: |
Mike Fisher wrote: |
Cut off the bump stops? |
there's your answer. how could it ride good if your setting on the snubbers. mule and wagon all the way. if you cut them off there will be lots of travel left. i've heard people say the snubbers are in at that position to keep from it bottoming to the point of stressing the balljoints and that what vw did was figure the angle they would be stressed and then designed the snubbers to limit the travel to 2" above that stress point.
but yeah remove that whole "arm" for the snubber and remove the snubbers out back and you should get ride back out of it. it still ain't gonna be a cadillac but it will be better.
i've got a type conversion beam waiting to go in mine. i went a bit different and it's a -4" balljoint based beam WITH shocktowers where most run without. between the shorter stiffer torsions and still having shocks i'm hoping it rides similar to a stock type3 suspension...ken.... _________________ ITMC
Secret Service |
Posted: Fri Nov 06, 2009 2:38 pm Post subject: |
haha i'll take the ride of a type 3 over the look of a 412 anyday! _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
66311 Samba Member
Joined: December 31, 2006 Posts: 1477 Location: Olive Branch MS
Posted: Fri Nov 06, 2009 6:39 pm Post subject: |
Start by removing the rubber if it's not more than a couple inches lowered.
Russ Wolfe wrote: |
I have a couple good front ends that have not been slammed. I even have a couple of pans. |
Put one of those front ends on my list please.
luckystiff wrote: |
[there's your answer. how could it ride good if your setting on the snubbers. mule and wagon all the way. if you cut them off there will be lots of travel left. i've heard people say the snubbers are in at that position to keep from it bottoming to the point of stressing the balljoints and that what vw did was figure the angle they would be stressed and then designed the snubbers to limit the travel to 2" above that stress point. but yeah remove that whole "arm" for the snubber and remove the snubbers out back and you should get ride back out of it. it still ain't gonna be a cadillac but it will be better.
i've got a type conversion beam waiting to go in mine. i went a bit different and it's a -4" balljoint based beam WITH shocktowers where most run without. between the shorter stiffer torsions and still having shocks i'm hoping it rides similar to a stock type3 suspension...ken.... |
I'm not arguing but snubbers are generally for cornering. If the only idea was bottoming out the rubber would likely be flatter and solid. Look at the upper one under the sway bar and consider what it's job might be. Rubber is off in photo.
What type is your beam? Pictures? I like the idea of shocks.
Raising or lowering doesn't change the tension on the spring. It changes the position of travel and effects the cast rake among other things like ball joints.
https://www.thesamba.com/vw/gallery/pix/389641.jpg |
jlew Samba Member
Joined: October 22, 2008 Posts: 273 Location: Central VA
Posted: Fri Nov 06, 2009 8:41 pm Post subject: |
awesome motto squareguy.......
no other acvw rides better than a stock height type 3... Very Happy
then again, no acvw looks better than a lowered type 3... Cool _________________ 1968 Notchback |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Sat Nov 07, 2009 12:14 pm Post subject: |
The only way to get close to a stock ride is to use drop spindles. Someone here had some made recently. Good luck finding any now. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Posted: Sat Nov 07, 2009 2:54 pm Post subject: |
oldspeed in paramount makes dropped spindles. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
