aeromech Samba Member
Joined: January 24, 2006 Posts: 16960 Location: San Diego, California
Posted: Sat Nov 07, 2009 7:22 pm Post subject: Another Freeway Flyer Thread |
Guys,
Just a quick thought on this subject. Let me lay out the specifics.
1968 bus
2007cc type 1 engine (about $5500 invested)
Dual Dellorto 40 DRLA's
A1 Sidewinder exhaust
Engle 100 cam
Scat heads
Doghouse cooler plus external full flow cooler with electric fan
This is a higher HP engine designed for power and dependability. It should cruise at around 210 degrees oil temp. My question is should the owner pony up for a freeway flyer tranny to get all the available speed and benefit of the big engine. I've read the threads warning against this tranny but we have a big engine with really great cooling so I'm thinking that taller gears might be a good option. After all, the 1979 buses had this size engine and taller gears. What do you think?
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sat Nov 07, 2009 7:48 pm Post subject: |
Beautiful engine you built.
My 2 cents. When one is in a 40 MPH headwind we see our speed decreased by a huge amount. The VW bus is like a sheet of plywood going down the highway, pushing wind in front of it. The best thing someone can do for their bus is keep it 65 or lower to avoid pushing all that air. He doesn't need a freeway flyer at 65 or lower. He is getting bragging rights as it is, a freeway flyer may reduce those bragging rights.
Back in the early 1980's I had a 1971 deluxe with a similar motor except I ran an extended sump for oil cooling instead of an external cooler. In the spring and fall, until it got up to about 105, we used to run out to Havasu from Los Angeles each weekend. It is a long drive in the desert and I would push the bus sometimes to a sustained 85mph. On average I could get 20,000 to 30,000 miles on an engine. Considering I was driving 2000 miles a month, rebuilding the engine was an annual event. At about 250,000 miles the trans showed signs of age, a slight howl. A friend who worked for a VW dealer promised to rebuild it for me but instead he showed up with a new 1979 trans and my bell housing etc and said it would give me better results than rebuilding the 002. To be quite candid, I hated the gearing. If I had a way to go back in time I would have stayed with the 002 or an early 091 like I have now on this 1977. I had no tach during the long runs out to Parker Dam and London Bridge. It wasn't until later in 1983 or 1984 that I added one and realized what kind of RPM's and load the engine sustained on those trips out to Havasu.
The owner will be really happy with that fine engine you have built for him, but I think he will be happiest if he keeps the speed down to 65 and under, which will give him a very long life on the engine, trans and CV joints. He'll have plenty of power to merge onto the freeway now. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Sat Nov 07, 2009 7:49 pm Post subject: Re: Another Freeway Flyer Thread |
aeromech wrote: |
What do you think?
Can't help you with an answer to your tranny question, but I'm assuming you know the heat tubes aren't supposed to go down through the tin and around the exhaust correct?? _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Randy in Maine Samba Member
Posted: Sat Nov 07, 2009 8:04 pm Post subject: |
Why wouldn't you just put on some taller tires like 195R14s or 205R14s? |
Posted: Sat Nov 07, 2009 9:04 pm Post subject: Re: Another Freeway Flyer Thread |
VDubTech wrote: |
aeromech wrote: |
What do you think?
Can't help you with an answer to your tranny question, but I'm assuming you know the heat tubes aren't supposed to go down through the tin and around the exhaust correct?? |
Actually, I've been thinking that I need some sort of pipe for that but have been unable to come up with one. What's the answer? Seems like years ago I had some pipes that were formed to fit around the header but that was many moons ago. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Nov 07, 2009 9:05 pm Post subject: |
Randy in Maine wrote: |
Because we just spent $180 on powder coating the wheels and another $400 on Hankook's in the 185 variety.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Nov 07, 2009 9:21 pm Post subject: |
Sell the 185s and put 205s on there and it will gear you up another 5%.
Cheaper than a "freeway flier". |
Posted: Sat Nov 07, 2009 9:23 pm Post subject: |
That's an option. Are the Hankooks available in 205's? Maybe the owner would like to upgrade to some Fuchs? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
mr69 Samba Member
Joined: March 03, 2006 Posts: 179 Location: Long Beach CA
Posted: Sat Nov 07, 2009 9:30 pm Post subject: Re: Another Freeway Flyer Thread |
VDubTech wrote: |
aeromech wrote: |
What do you think?
Nice work. cool that you took the photo while the motor was running.
don't forget to put the clamps on the fresh air hoses at the shroud.
Why not use an electric fuel pump?
where did you get that throttle cross bar, never seen that one. looks like the cable wont rub in the tube. _________________ 1968 blue rocket
Vettes, mustangs, camaros, hondas and nissans all look the same in the rear view mirror. |
volksterii Samba Member
Joined: December 01, 2006 Posts: 425 Location: San Diego CA
Posted: Sat Nov 07, 2009 9:37 pm Post subject: Re: Another Freeway Flyer Thread |
aeromech wrote: |
VDubTech wrote: |
aeromech wrote: |
What do you think?
Actually, I've been thinking that I need some sort of pipe for that but have been unable to come up with one. What's the answer? Seems like years ago I had some pipes that were formed to fit around the header but that was many moons ago. |
Use these. A bit more expensive but you will never buy more due to wear. I used them and did it in two pieces each side.
http://www.thesamba.com/vw/classifieds/detail.php?id=622081
_________________ 71 Westy Hardtop, 1915
2005 Touareg V8 air susp. |
Posted: Sat Nov 07, 2009 10:14 pm Post subject: |
"Why not use an electric fuel pump?
where did you get that throttle cross bar, never seen that one. looks like the cable wont rub in the tube."
The original pump is more bullet proof thn an electric and provides a solid 3 psi of fuel flow.
The cross bar is a Gene Berg. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Sun Nov 08, 2009 9:03 am Post subject: |
Hey aeromech I run the same setup with a freeway flyer tranny and I like it. I am running Kadrons in an effort to get some fuel economy. If I drive it like a bus I can manage 21-22 m. most of the time its about 17-18. Its a lot more fun than my stock camper though. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sun Nov 08, 2009 9:23 am Post subject: |
Install a '75 pyramid case trans. It's the last of the 002, with strong (and slightly taller) 4.86 R&P. |
Posted: Sun Nov 08, 2009 11:19 am Post subject: |
Thanks guys. I'm getting some good info here. The bus originally had the 195 tires with a stock engine and it was a real dog on the road. Going up to larger diameter tires would be a good try now that we have the big engine, thanks Randy. I know that the owner is watching this thread and also doing his own research on the best option so for right now the jury is still out on this one.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sun Nov 08, 2009 11:37 am Post subject: |
We found that the solution to the hose issue was slicone hoses with wire inside. They outlast the heat. The issue with the paper is it will char on the outside so close to the exhaust. If you don't go with the silicone hoses at least wrap 1/8" to 1/4" of aluminum foil around it where it goes by the headers. That will protect it some keep oxygen away if it catches fire. It will still char but slower.
Here is an example of one of the kinds of hoses. There are many Internet companies that sell it. I forget who in San Diego sells rubber products but someone down there should see rubber products. They will have high temp hose that will work,
http://www.flexaust.com/cwgs |
vw76westy Samba Member
Posted: Sun Nov 08, 2009 1:01 pm Post subject: |
i had a freeway flyer in my last tranny
like sgkent said it will take away from the engine not add to it
given that i have a type 4 engine
the tranny was a 002 with 091 bellhousing & a freeway flyer
the 4th gear did not start putting out any torque untill i was at 65-70mph
so getting there after shifting from 3rd at 50mph was slow & fustrating
that freeway flyer got shreaded into shaving's while going up a hill
with a full load, (trans had 35k miles on it at the time)
it started with a few bucks at 60mph then a quick grinding
& waaalaaa no more freeway flyer.i had to turn around & drive home in 3rd(50miles away) like a spiltty @45mph in the slow lane
no matter how big the engine is,it would be hard to go up a hill at 25mph in 3rd
no matter how small a engine is it will march up a hill at 25mph in 2nd
going 25 in 3rd is how a freeway flyer performs at 50-60mph in 4th
i think if you want to get the most out of bigger engine
get a 75-79 091 tranny & change the bell housing to fit the type 1 engine
just think this(091) is what all the sand rail & dune buggy people use for top
performance |
germansupplyscott Samba Member
Posted: Sun Nov 08, 2009 1:19 pm Post subject: |
vw76westy wrote: |
get a 75-79 091 tranny & change the bell housing to fit the type 1 engine |
an 002 transmission with a 4.57 R&P will give you almost exactly the same gearing as an 091. _________________ SL |
Posted: Sun Nov 08, 2009 1:33 pm Post subject: |
i dont know what the gearing was exactly
i bought the tranny at a time when i knew absolutly nothing about vw !!!
i walked into vw trans shop in long beach CA & asked for a brand new tranny with a freeway flyer on it.then i had it installed by a mech
5 years later i learned i had a 3 rib tranny on my bus not a 6 rib
& that is how it felt between 50-60 mph |
Posted: Sun Nov 08, 2009 2:12 pm Post subject: |
I'm going to order the stainless heater hose from Vee Dub Parts. Where can I get these seals?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
