Vanagon stove burner will not work
metroatlantacomputers
metroatlantacomputers is offline
PostPosted: Mon Jul 13, 2015 12:29 pm    Post subject: Vanagon stove burner will not work Reply with quote
One of my stove burners works, but the other one does not. Does anybody know how to fix this. Thanks
zippyslug31
zippyslug31 is offline
PostPosted: Mon Jul 13, 2015 2:06 pm    Post subject: Reply with quote
You could try cleaning the valves to see if it helps.
I did this on my van a while back and it's been running great ever since: http://www.thesamba.com/vw/forum/viewtopic.php?t=544333
previous: '80 westy
current: '90 syncro westy featuring 2.5 subi, front & rear lockers, decoupler, 16" wheels, and an empty bank account. Also added an '84 sunroof van, all original and unmolested except running a 2.1L motor.
Timwhy
Timwhy is offline
PostPosted: Mon Jul 13, 2015 5:16 pm    Post subject: Reply with quote
In this image from Zippy, the hole in the top left corner. Try blowing air into it, I used an electric pump with a
length of tube connected to it. Gave it a few seconds of air and burner worked as good as new.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jul 13, 2015 5:23 pm    Post subject: Reply with quote
Dust bunnies or webs can disrupt the gas flow in there. Look in the holes. Just use a soda straw and blow some air through those 2 intake holes with your mouth. Blow hard.
Mark
Vinzanto
Vinzanto is offline
PostPosted: Mon Jul 13, 2015 8:20 pm    Post subject: Reply with quote
I remember one of mine wouldn't light/burn very strong so ended up blowing some compressed air through the line and after hearing a quick "floomp" sound it burned nicely.
1984 Vanagon Westfalia Wolfsberg
Kathy Marlow
Kathy Marlow is offline
PostPosted: Sun Nov 29, 2015 8:31 am    Post subject: Re: Vanagon stove burner will not work Reply with quote
One of the two burners in my Westy wasn't working properly, producing a yellow flame when operating. I just followed zippy's great tutorial on cleaning his stove burners and mine are now working perfectly. Including both on the lowest setting, neither of which worked before. Thanks for the great post!
