Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Fri Nov 13, 2009 12:46 pm Post subject: Syncro transaxle pushing out oil |
I switched from Redline to a thick Swepco trans. oil last summer. In the last month or two I've noticed that the breather pipe that comes off the tranny was oily. The transmission oil had been pushed up and out of the breather. I blew into the open end of the breather pipe, it didn't seem plugged.
I also noticed last week some oil seepage and drip at the tranny/engine connection point. So I thought I had too much oil in there, so I leveled the van and sure enough a few ounces of oil slooowly dribbled out of the fill opening overnight.
So today there appears to be even more tranny oil dripping down between the engine and trans.
Would being over filled just a tad cause me to blow that shaft seal on the transmission? What else could cause high transmission oil pressure?
The transmission was rebuilt (3) years ago.
Thanks for any ideas.
Cheers, Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Fri Nov 13, 2009 1:13 pm Post subject: |
This is a syncro, so I thought there was no breather to unclog? As in, the breather hose replaces the breather hole so it doesn't flood on syncro river crossings. It's the breather hose on my van that's pushing out the oil. Please correct me if there's another breather I need to look for. Joel _________________ Joel Lane
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Fri Nov 13, 2009 1:49 pm Post subject: |
There are 3 breather hoses the trans the front diff and the flywheel they all terminate under the fuel tank. I made a manifold for mine with a filter so they could not get clogged.
Posted: Fri Nov 13, 2009 1:56 pm Post subject: |
Oops, Didn't see the part about it being a syncro. |
