Volkswache Samba Member
Posted: Sun Nov 15, 2009 3:55 pm Post subject: Help Identify Very Early Chassis |
That is the place where we found it. You can only see the shifter
You can shift with it and that after years in ground
Thats the reinforcements under front seats:
Anybody know for what this switch is:
Any diference in shifter?
Anybody knows for what this is?
We take a look and after sandblasting the chassis is useable |
Simon uk Samba Member
Posted: Sun Nov 15, 2009 4:17 pm Post subject: |
cool, are there any pics after it was cleaned up? |
Posted: Sun Nov 15, 2009 4:20 pm Post subject: |
Sorry, not yet.
We want clean it and give them to sandblaster. |
roy63 Samba Member
Joined: August 16, 2004 Posts: 1338 Location: Mechanicsville Va.
Posted: Sun Nov 15, 2009 5:13 pm Post subject: |
Holy dirty pan Bat Man, blasting may not be the best for your pan, it may blast it all away? You may want to try Electrolis (sp). _________________ MyBuild http://www.thesamba.com/vw/forum/viewtopic.php?t=571921
Some day when the rust is gone, I will at last found inner peace... (Peace has Been Found)
"Wide awake, and keeping distance from my soul" |
splitjunkie Samba Member
Posted: Sun Nov 15, 2009 5:31 pm Post subject: |
if it is not usable after blasting it won't make any difference if you use blasting or electrolysis. If there is not enough metal there it won't matter either way.
Based on the two round drain plugs on the pan it looks like you have a Klubelwagen pan there. _________________ Chris
spookymulder Samba Proletariat
Joined: January 02, 2004 Posts: 3298 Location: I'm either at 95608, 97537 or 94708 only my CPA knows for sure
Posted: Sun Nov 15, 2009 5:52 pm Post subject: |
neat find, did you use a metal detector? |
LeviMan2001 Samba Post Whore
Posted: Sun Nov 15, 2009 5:58 pm Post subject: |
spookymulder wrote: |
Would that hulk of rust even set off a detector ?
Seriously though, very cool, especially if its a kubel. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs |
kdf38 Samba Member
Posted: Sun Nov 15, 2009 6:17 pm Post subject: |
I don't see any pics of drain plugs. Are there more pics?
Mike
splitjunkie wrote: |
Based on the two round drain plugs on the pan it looks like you have a Klubelwagen pan there. |
mightymouse Samba Member
Posted: Sun Nov 15, 2009 6:32 pm Post subject: |
type 87 _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
Keoki Samba Member
Joined: April 21, 2004 Posts: 262 Location: PNW aka 96706
Posted: Sun Nov 15, 2009 6:34 pm Post subject: |
Shows an early 50's tranny nose cone mount....
"KOOL" find.... _________________ Peev's; People that pretend to be something there "NOT"...... |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Nov 15, 2009 7:23 pm Post subject: |
How come that pan buried in the dirt lasted longer then most of my cars above ground?
Maybe I'm washing them too much. _________________ Mother Nature is a Mean Evil Bitch! |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
sparkleplenty Samba Member
Joined: January 09, 2008 Posts: 1110 Location: California
Posted: Sun Nov 15, 2009 9:15 pm Post subject: |
Was that thing at the bottom of Pearl Harbor next to the Arizona? Geez oh man... _________________ '56 European Oval Ragtop-Stock
'56 Karmann Ghia Coupe-Stock
'59 Italian Series I Li150 Lambretta-Stock
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime."
"Only when the tide goes out do you discover who is swimming naked." |
eurodub Samba Member
Posted: Sun Nov 15, 2009 11:42 pm Post subject: |
it was buried in the home country's land... the soil was protective with the pan... _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
ProjectX Accessory Nut
Posted: Mon Nov 16, 2009 12:08 am Post subject: |
Looks kind of like QWERTY's 46 chassis. His is in a little better shape
If you look at the 2 center support straps they match the details on the bottom of the pan pictures from above.
_________________ Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible |
Undis Samba Member
Joined: October 24, 2006 Posts: 1396 Location: Riga, Latvia & Sydney, Australia
Posted: Mon Nov 16, 2009 4:47 am Post subject: |
Looks to be Kubelwagen floorpan
_________________ Check out my Facebook page: Volkswagen Prototypes. |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Mon Nov 16, 2009 5:16 am Post subject: |
Nice artifact from the past.
The switch could be a revers light switch that workt over a lever that was attached to the shift rod.
I have seen a simular setup. It is for sure aftermarket.
I think the early beetles used the same floor as the kubel, sure the ones made before 47.
best regards. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
Posted: Mon Nov 16, 2009 5:29 am Post subject: |
I was wrong about the drain plugs. They would be at the very front of the pans as you can see in the picture of the overturned Klubel. But most definitely a very early pan. _________________ Chris
Posted: Mon Nov 16, 2009 7:24 am Post subject: |
Whats the deal with the bottom of the shock towers? Is that the shock mount below the lower tube? _________________ Mother Nature is a Mean Evil Bitch! |
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Mon Nov 16, 2009 7:58 am Post subject: |
Soak that thing in a huge pan of STONG tea----the tannic acid will stop the rusting and the chunks of rust will fall off leaving just dark metal. Look it up on the net. It'll take a while but may be less destructive than blasting! This is what we did in a museum for such metal as 200 yr old axe heads found in mud for preservation.
How did you happen across this find?????????????
Such exciting times in the VW world!!!!!! |
