JorgeDavidson Samba Member
Joined: August 31, 2008 Posts: 358 Location: Buenos Aires, Argentina
Posted: Sun Nov 15, 2009 8:03 pm Post subject: Best way to install body moldings |
Hi Folks! Maybe someone ask for it before, but I couldnīt find anything... A friend and I are working on a '51, and the point we were not sure how to install molds in any Split -`cause of its shape- without damaging Splitīs moldingīs curves.
I never use this method, even in later models, I guess it only works w/stainless steel moldings:
http://www.5min.com/Video/How-to-Restore-Chrome-Molding-on-VW-Volkswagen-30438025
Is there a "correct" way to fix them on the body? is it the same for all models?
Thanks! _________________ 1957 Oval Window - Polar Silver L324
2008 VW Suran Trendline |
splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1251 Location: Good Ol`Buenos Aires, Argentina
Posted: Mon Nov 16, 2009 4:02 pm Post subject: |
don`t tell me that the butcher from Roca street is trying to put a split together ....he should finish my customer`s 61 before he goes to the next level in pursue of perfection ......he`ll never get the black belt though
give me a call or come to my house , i can show you my split and discuss anything you want to know about it ....for free !!! _________________ in my Garage:
1951 crotch cooler split
1971 1302 cabriolet
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
Posted: Mon Nov 16, 2009 7:02 pm Post subject: |
Thanks! you really surprised me with that of "special body molding clips" for Splits.. not to mention that of Splits donīt use seals under BM.. Iīll looking for some pics on the web. See U. _________________ 1957 Oval Window - Polar Silver L324
Posted: Tue Nov 17, 2009 1:58 am Post subject: |
split clips are different from later clips , no rubber cupt under it except for some "witch" hats glued under the hood and doors .... too funny they will keep water between the body steel and the clip after you wash and dry the car ....correct me if i am wrong ... _________________ in my Garage:
1971 1302 cabriolet
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Nov 17, 2009 7:20 am Post subject: |
Use a small piece of wood to press on the moldings to distribute the pressure and not leave a "thumb dimple". _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Nov 17, 2009 8:31 am Post subject: |
it is just a clip issue , john , and the fact that he thought early cars would use the small rubber cups from the outside .... _________________ in my Garage:
1971 1302 cabriolet
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Tue Nov 17, 2009 8:51 am Post subject: |
I use 2 thin steel spattles to press on each side of a clip to prevent paint damage during assembly. Clip has sharp edges to cut paint on hole.
I use the same method to remove moldings.
Grooved moldings has no big risk for "thumb dimple", they are much more stiff than newer model molding. |
Posted: Tue Nov 17, 2009 9:05 am Post subject: |
i do use 2 credit cards , either for instalation or removal of moldings
never leave home without them _________________ in my Garage:
1971 1302 cabriolet
williamjagers Samba Member
Posted: Tue Dec 22, 2009 7:44 pm Post subject: Split Hood (not sure) |
Hello
I have a 50, that is currently be restored (3 years ): I thought the bug was 100% original. However, I took a close look at the hood, and its only 3 tabs. Is there any possible way this could be original to the car ?
Thx _________________ 1950 Standard
1955 Oval Rag
1957 Oval Rag
1967 Bug |
Suboval Samba Member
Posted: Wed Dec 23, 2009 7:31 am Post subject: Re: Split Hood (not sure) |
williamjagers wrote: |
Hello
Thx |
Is there a triangle underneath the hood with three small holes where the tabs go thru? Does each hood arm have three bolts? Is there a separate bolt for the hood prop? Is there holes for a hood badge? _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
