KG Tire Survey
Page: Previous  1, 2
Cohibra45
Cohibra45 is offline
PostPosted: Wed Dec 16, 2009 8:45 am    Post subject: Goodyear Triple Tread 195-60-15 Reply with quote
TIRE SURVEY
For each brand and size tire are you running on your Karmann Ghia(s),
please provide:
Tire Brand: Goodyear Triple Tread
Tire Size: 195-60-15
Tire "series" and/ or type: All weather, no information in snow, but in Florida rain, they are good.
Approximate cost each (unmounted): about $95
Wheel: Please respond only if non-stock: Porsche
Wheel manufacturer & / or wheel name: Fuchs 2.0l
Diameter: 15
Width: 5.5
Offset: 40
(If front and rear are different, please provide both sets of data.)
If Radial: Belt material (from sidewall): Steel
Sidewall construction:
If bias-ply: Tube or tubeless?
White-wall width?
White-wall on both sides of tire?
Does this tire mounted on this wheel fit in the _undamaged_ nose of a Karmann Ghia? NO!!!
(_Please_ answer either yes, no, or unknown. If front and rear rims / tires differ, please provide all data.)
Treadwear: 740
Traction: A
Temperature: B
Tire Fit: Great with no rubbing front or back.
Lowered in front by how much: stock
Lowered in rear by how much: stock
Front axle beam narrowed by how much: stock
Tire rubs coachwork in all the following places: none
Additional remarks: (Do you like the tire? Durable? Handling? etc.) They made a huge difference in handling. No more rolling, just grip and hang on... Very Happy
Kelly
CJA333
CJA333 is offline
PostPosted: Sun Jul 18, 2010 8:19 pm    Post subject: Re: Goodyear Triple Tread 195-60-15 Reply with quote
Kelly
RIGHT ON!
Altema
Altema is offline
PostPosted: Mon Jul 19, 2010 11:58 am    Post subject: Re: Goodyear Triple Tread 195-60-15 Reply with quote
CJA333 wrote:
Kelly
RIGHT ON!
Definetly grippy, I had these on my daily driver/weekend track car for a season. Better wet traction than some tires have dry, and snow traction is excellent as long as you have more than 60% or more of the tread left. Breakaway is a little sudden, so if you push the limits at speed, you may want to look at something that will give a little more warning.
Yowman
Yowman is offline
PostPosted: Sun Aug 08, 2010 7:58 pm    Post subject: Reply with quote
TIRE SURVEY
please provide:
Tire Brand: Dunlop
Tire Size: 165SR15
Tire "series" and/ or type: SP 4N Steel M&S
Approximate cost each (unmounted): Unknown, were on car when bought
Diameter:
Width:
Offset:
If Radial: Belt material (from sidewall): Polyester & Steel
Sidewall construction: Polyester
If bias-ply: Tube or tubeless? Tubeless
White-wall width? N/A
White-wall on both sides of tire? N/A
Does this tire mounted on this wheel fit in the _undamaged_ nose of a Karmann Ghia? Unknown
Treadwear: 320
Traction: A
Temperature: B
Tire Fit:
Lowered in front by how much: Unknown
Lowered in rear by how much: Unknown
Front axle beam narrowed by how much: Unknown
Tire rubs coachwork in all the following places: None
The Dunlops seem to handle pretty well, but that's hard to say considering that they are on a 1966 Ghia. I mean it doesn't handle like my '01 Mustang GT did, that's for sure.
desmato
Location: Michigan, USA, Earth, Milkyway, Universe,... Bottom of some being's shoe !
desmato is offline
PostPosted: Mon Apr 23, 2018 7:09 pm    Post subject: Re: KG Tire Survey Reply with quote
Tire Brand: Ohtsu (Sumitomo)
Tire Size: 175/65-15
Tire "series" and/ or type: FP0612 A/S
Approximate cost each (unmounted): $55 (Discount Tire)
Wheel: Please respond only if non-stock: '72 Marathon
Diameter: 15
Width: 4.5
Offset:
If Radial: Belt material (from sidewall): "Dual steel belts with a polyester cord body"
Does this tire mounted on this wheel fit in the _undamaged_ nose of a Karmann Ghia? unknown
Treadwear: 480
Traction: A
Temperature: A
Tire Fit:
Lowered in front by how much: 0
Lowered in rear by how much: 2 spline ?
Front axle beam narrowed by how much: 0
Additional remarks: (Do you like the tire? Durable? Handling? etc.) New, hasn't been on the road yet but used the same tire on other cars and they perform great.
[/img]
jpsport
jpsport is offline
PostPosted: Wed Jan 15, 2020 3:32 pm    Post subject: Re: KG Tire Survey Reply with quote
I love my 165/80R15 on my 69 Karmann Ghia, they look great but I bought 5 and i just found out the spare is too wide (diameter is 25.25 inches and too tall to fit in the well and close the trunk. What size does fit and yes I will have two different size wheels if i need to use the spare.
thanks
jp
Page: Previous  1, 2
Page 2 of 2
