LynnsABCs Samba Member
Posted: Fri Nov 20, 2009 12:10 pm Post subject: 87 Weekender--What Is It Worth? |
I had a mild heart attack 18 months ago and decided to buy a Vanagon Camper to travel in anticipation of retirement in 3 to 5 yrs. After spending about $3,500 in parts and about 100 hrs or my work on it, my wife has decided she doesn't like it and wants me to sell. (I have a small garage and 2 Porsches.)
1987 VW Westfalia Weekender. 165,000 miles.
Work done by prior owner
1. VW Factory rebuilt engine (Canadian) 30k miles ago.
2. $2,500 in F/R brake work. No receipt, but brakes look fine.
New Parts I have Installed:
1. New rear bumper. All bumper end caps F/R.
2. All new headlight adjusters.
3. New muffler, muffleer straps, catalytic converter, oxygen sensor and tailpipe.
4. New fuel pump, filter and all new fuel lines from tank to engine and new lines to fuel injectors.
5. Fuel tank reseal kit installed.
6. New AC compressor, Receiver/Dryer, Expansion valve and all 5 AC hoses replaced. Ready to be charged.
7. New Pop-Top seal kit--both pop-top and luggage rack seals.
8. Top cleaned with GW Protect All Oxidation Remover and sealed with 303 Fiberglass Restorer.
9. New Skylight.
10. Set of new lugnuts for the stock 14" alloys.
11. Set of 4 Hankook 185R14 tires.
12. Several cooling hoses replaced.
13. New Plugs, distributor cap, plug wires, rotor.
14. New Alternator.
15. New air filter. New belts.
16. New CV joints one side.
17. Cleaned and regreased other side and all new boots and bolts.
Work I've Done:
1. Flushed cooling system and refill using Prestone coolant and distilled water.
2. Changed oil/filter twice and new drain plug.
3. Drained trans filter twice and replaced trans filter.
4. Flushed the AC condensor and cleaned rear AC cabinet. Waiting to charge AC system with Red-Tek or r34A.
5. Flushed brake fluid.
6. New tires means no more sway at 70 mph. Front end tight.
7. New exhaust system allows fuel injection 18 mpg on interstate.
8. 5 stock alloys (including spare).
9. Have rear bug screen but not side door screen.
New Spare Parts:
1. Hepi Water Pump
2. 4-Bosch WR7 spark plugs
3. New Bentley Manual
4. Ignition Switch
5. 2-Relays--1009510001
6. 2 Front, 1 R wheel bearing seals
7. Hoses--Tank 025 121 108D 025 121 058 J
8. Hoses--025 121 058 H 251 121 058 A
9. Oil cooler hose 025 121 058 GMY
10. T Piece--11954024066
The bad:
1. Sliding door panel is gone.
2. Clear coat on exterior paint is flaking. Some dings and some seam rust treated with rust killer.
3. Crack in windshield, of course, right in front of driver's view.
4. Rear apron over muffler is banged up.
5. Original rear pad replaced with a piece of foam.
What is it worth for resale? _________________ LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
1961 Porsche 356 B Notchback Coupe
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Fri Nov 20, 2009 12:22 pm Post subject: |
Unfortunately, not an option. _________________ LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
1961 Porsche 356 B Notchback Coupe |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Fri Nov 20, 2009 12:33 pm Post subject: |
One very simaler sold here in the northwest for 3000.00. The lot opened at 9:30 I was there at 9:40 and it had sold!!
Arond here it would be listed for around 7-9k . But what someone is willing to pay???
good luck.
You porsches arent a 72 or 73 911?? for sale??
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
vw7266 Samba Member
Joined: April 28, 2004 Posts: 3038 Location: the point, ohio
Posted: Fri Nov 20, 2009 12:35 pm Post subject: |
id give ya 3500 for it |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Nov 20, 2009 12:38 pm Post subject: |
Depending on what part of the country you're in it will bring different prices. Here in the NW I would think you might get more like $4500-$5500. The poptop without the camper interior is pretty desirable and harder to find.
http://www.thesamba.com/vw/classifieds/detail.php?id=848213 _________________ 89 Westy 2.1 Auto |
buildyourown Samba Member
Posted: Fri Nov 20, 2009 12:45 pm Post subject: |
Quote: |
Here in the NW I would think you might get more like $4500-$5500. |
You would be able to much better than that.
Is that a Wolfsburg badge?
Despite some mild body rust, has it been a southern van and never seen salt?
In the NW, I'm thinking $7-8k easy. Especially if you fix a couple of those cosmetics. |
mellow cat Samba Member
Posted: Fri Nov 20, 2009 1:04 pm Post subject: |
I'm very interersted, let me know when you settle on a price.
MC |
Posted: Fri Nov 20, 2009 1:14 pm Post subject: |
The van has been in the South the last 5 or 6 yrs. My receipts are at home on the rebuild, so I don't remember but I think it was installed in Colorado. The underside of the bus looks great with minimal signs of rust.
There is a Wolfsburg badge on the van.
I hope to take lots of photos Saturday and then post it in the Classifieds at $6,500. At that price, I'm way upside down with original purchase and money spent on it--so I'm not spending any money on paint or windshield.
There are some more photos of the van in my AC Rebuild thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=365626&highlight=[/url] _________________ LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
cats_r_cute Samba Member
Joined: October 08, 2009 Posts: 148 Location: Seattle
Posted: Fri Nov 20, 2009 3:38 pm Post subject: |
a914622 wrote: |
good luck.
jcl |
this post is fun to read! |
Zero419 Samba Member
Posted: Fri Nov 20, 2009 3:41 pm Post subject: |
The Canadian rebuild is not know for its quality.
I'd say 3,500
Edit: Thinking about it a little more, I have the same year, same color, full camper and I just did a rebuild myself and sent the trans to German transaxle for a preventative rebuild.
If I were to sell it now (it still needs brake and suspension work) I would ask
5,000-6,000. (never would sell)
I don't think I would get it. It's just that I put so much heart and soul in it that I think it would be worth more than it is. _________________ 1987 Westy Auto Bostig 2.0 Ztec
Posted: Fri Nov 20, 2009 3:46 pm Post subject: |
Thank God my wife is supportive of everything I do! She loves my Westy and thinks it was a wonderful idea. We've been married 10 years. I can't imagine having my partner tell me to sell my vehicle because she "doesn't like it". I guess I'm lucky. |
Posted: Fri Nov 20, 2009 4:19 pm Post subject: |
cats_r_cute wrote: |
I don't have that problem either, but that's because my wife knows what the answer would be.
Actually, it's her van. She bought it, and I bought all the parts and did all the work. We're just about even. |
Posted: Fri Nov 20, 2009 4:20 pm Post subject: |
To the OP, check out the "Good deals on nice vans" thread.
It would give you an idea of what a van priced to sell looks like. |
Posted: Fri Nov 20, 2009 5:02 pm Post subject: |
The 911 is a '71 and goes to my son post mortem.
I realize the economy sucks and this is a poor time of year to sell, but show me a running poptop for less than $3,000 and add $3,500 in part receipts plus lots of work on my part, and $3,500 is an unrealistic, low-ball valuation. _________________ LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
Posted: Fri Nov 20, 2009 5:36 pm Post subject: |
Maybe I was unclear. The $3,500 spent does not include the original purchase price. _________________ LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
Jon_slider Samba Member
Posted: Fri Nov 20, 2009 5:42 pm Post subject: |
I agree, that other samba link is to a van with blown engine:
"-Coolant is leaking from head gaskets
-Some oil smoke from the exhaust
-Brake rotors are rusted
-Upper balljoints and control arm bushings are cracked
-Radius rod bushings cracked
-Power steering lines rusted "
Thats nothing like your van. You did some really nice work on your AC system. Im sure any buyer will be lucky to get it, and I think your asking price is fair.
I dont need another van, so just here to say, sorry about your heart, and very nice van, fairly priced.. imho, any van under 5k, probably needs a motor, yours obviously has that base taken care of already.. and btw, its rare to find a van with working AC, or any AC at all, yours is a cherry.
And its a Wolfsburg!
nice piece, would be good for the grandkids, mention that to your wife and she might let you keep it.. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sat Nov 21, 2009 11:13 am Post subject: Re: 87 Weekender--What Is It Worth? |
LynnsABCs wrote: |
If I was buying a Westy, these items would knock about $2,000 off the price that I would offer. They make it look like there are a bunch of other hidden problems. If you want to keep the buyer's attention on the excellent and very valuable preventative maintenance work that you have done, it will be impossible with big, visual flaws. The problem is that people with money in pocket will walk away, and only the low-ballers remain.
Not much can be done (sensibly) about the flaking clearcoat. I think the other 3 problems above could be handled for about $250 (??) and ( ....relying ONLY on your SAMBA description ) this could net you about 1,000 - 2,000 or more, value. The door panel and the rear foam can be had, and installed in 20 minutes. And the windshield is a phonecall away, maybe $150? Maybe SirSam has some parts that you need. http://www.thesamba.com/vw/forum/viewtopic.php?p=4165272#4165272
I would not like to be in your position, upside down, but since you asked, it is my opinion that taking care of the 3 big "visuals" will get you farther out of the hole you're in.
I would say that in the NorthWest USA this van would go for $4000 as described with 3 or 4 people coming to look at it ( lowballers who smell blood because it's unfinished). And $6-8,000 with 20 inquiries if it looked like it was "all there" ready to go.
Good luck. _________________
....KTMs, GasGas, SPOT mtb |
