vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Fri Nov 27, 2009 6:48 pm Post subject: another boring Axle Tube tear down thread..... |
My old axle tubes were rusty. The chinese Chrome Rocket Car axle tubes are under $70.00 per pair. A qt of DP90, some thinner, and sand blasting sand makes a man think.
I had a 1-1/8" deep impact socket that fit the od of the tubes perfectly. Using a Harbor Fright floor press and a beer. When they broke free, they slid right out. After measuring the old and preping the new axle end, I was ready to press back on. I suggest preping the axle tube end before pressing. Its such a tight fit, the cheap chrome may bunch up behind your housing as its being pressed on. I made an excecutive desision and buffed down the chrome up to a measured scribe line. Worked great.
Hotrodvw Samba Member
Posted: Fri Nov 27, 2009 7:59 pm Post subject: |
The chrome's gonna rust too. I powder coated mine. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Bruce Samba Member
Posted: Sat Nov 28, 2009 12:34 am Post subject: |
And leak too. Sealer does not stick to chrome. _________________
Posted: Sat Nov 28, 2009 8:18 am Post subject: |
I know I dont need to remind you guys how much horse power I added to my bug by putting these on.
My stock bug leaked and rusted too. Thats some of the stuff you put up with when you have a hot rod. Wouldnt have it any other way. |
Posted: Sat Nov 28, 2009 8:37 am Post subject: |
Mypoint is you can have a decent look, and have the seal at the same time.......best of both worlds. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Mon Dec 07, 2009 4:30 pm Post subject: |
Cant forget the brakes. Not now anyway. Thanks to the dune buggy market, the typical brackets for the hard lines works pretty good.
Racebug57 Samba Member
Joined: October 22, 2003 Posts: 114 Location: Prescott Valley, AZ
Posted: Mon Dec 07, 2009 11:22 pm Post subject: |
Chrome won't get you home....but it does work magic on the ladies. |
Posted: Wed Dec 23, 2009 1:37 pm Post subject: |
Positioning the Axle End Casting on the press. Make sure its level and being supported properly.
Here is where you press after the Pin is out and laying on a table.
One of my 3/4 drive impact sockets fit snug inside the tube and rested flat on the axle tube inside.
Ready to press. Mine took about 12 Tons to press out.
