RIOMX Samba Member
Joined: September 30, 2005 Posts: 1234 Location: La Crosse, WI
Posted: Fri Nov 27, 2009 10:21 pm Post subject: Best way to adjust heater cables and levers? |
Recently I replaced two of my heater cables, and since then I've had some trouble adjusting them.
Tomorrow I plan on loosening the barrel nuts and starting over so I can finally get them right. Here are the issues I'm having:
The left lever only reaches about 1/4 of the way down - it's so tight it won't go down any further. I used to be able to switch from the feet all the way to the defrost, but not anymore. It's always blowing on defrost now.
I did notice the "leg" for switching from front to passenger heat under the bus was pretty tight.
On the other hand, the right lever has almost full range, but it's too tight and won't stay down long enough to engage the fan. To use the fan, I need to hold it down.
If anyone around here has bothered to fix their heating system and can give me some good tips for setting up the heater cables in the best possible way, I'd greatly appreciate it. I plan to get up early in the morning and sort them out once and for all. |
SGKent Samba Member
Posted: Fri Nov 27, 2009 11:19 pm Post subject: |
speaking of heater cables, has anyone found a source for the shorter defrost cables on a late bay? Does GEMO or anyone still make them? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
RIOMX Samba Member
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Sat Nov 28, 2009 8:48 am Post subject: |
RIOMX wrote: |
I'd like to keep my thread from being derailed on the very first reply, if possible. |
_________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 12:59 pm Post subject: |
VDubTech wrote: |
I made a lame attempt to humiliate you, because I was humiliated in your thread about seats. |
Nice try. My picture illustrating you as a cranky child in this thread was better
http://www.thesamba.com/vw/forum/viewtopic.php?t=388218
busdaddy Samba Member
Posted: Sat Nov 28, 2009 1:06 pm Post subject: |
I'll try to add a useful response
To adjust the rears put the dash lever almost all the way down (stop approx 1/4" from the bottom) and adjust the barrel nuts to the full open position. If it's still springing back up tighten the friction nut on the lever pivots under the dash. The last 1/4" should take up the slack in the system and end up with both valves open fully.
As for the diverters you seem to have answered your own question, find out what's binding and lube it up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
RIOMX Samba Member
My left heater clamp broke, so I went to the local VW shop (Painter's Grinding) and got a set of metal levers from an earlier bay.
I plan to swap these over to my assembly (even if they require some modification) and see how the cables behave after that. |
Posted: Sat Nov 28, 2009 1:16 pm Post subject: |
Yeah, you're amazing. _________________ First Trip in the RustyBus:
borninabus wrote: |
notchboy wrote: |
EverettB wrote: |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 1:30 pm Post subject: |
VDubTech wrote: |
Yeah, you're amazing. |
Come on now, only my wife gets to say that. |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 1:36 pm Post subject: |
busdaddy wrote: |
As for the diverters you seem to have answered your own question, find out what's binding and lube it up. |
Thanks busdaddy! That helps a lot. I was asking my wife to keep the lever all the way down when I was under the bus, instead of giving some slack.
Do you know how much distance the lever for the diverter should travel? It only moves about an inch or so. |
Posted: Sat Nov 28, 2009 2:52 pm Post subject: |
RIOMX wrote: |
I would assume all the way.
Слава Україні! |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 2:55 pm Post subject: |
busdaddy wrote: |
Sorry busdaddy, I meant this lever:
SGKent Samba Member
Posted: Sat Nov 28, 2009 3:09 pm Post subject: |
RIOMX wrote:
Lighten up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 3:43 pm Post subject: |
SGKent wrote: |
Lighten up. |
Not sure why you think I need to lighten up. I answered your question, found threads for you with solutions.
I just wanted a solution for my question without the thread getting derailed. Unfortunately, that happened anyway. |
SGKent Samba Member
Posted: Sat Nov 28, 2009 3:56 pm Post subject: |
Wasn't trying to hijack your thread.
My question was has anyone found a NEW source for the 75-79 defrost cables. GEMO makes the long ones and also a 16 mm shorter defrost one for the 1972-74 that can be made to work but it is also temp out of stock through VW Heritage. The part number on the correct 75-79 cable is 211-711-647/C. The 16 mm shorter one is 211-711-647/A. Supposedly it can be adapted. When the part goes bad it will cause the defroster either not to work or the lever to bind. There are several ways to use other cables or one can put in an early tube with a manual lever. I've found that some items whioch are out of stock are being made again depending on the demand so if one isn't available today it sometimes pays to wait 3 months and ask again.
Did you get the problem with yours solved? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
RIOMX Samba Member
Posted: Sat Nov 28, 2009 4:13 pm Post subject: |
SGKent wrote: |
Did you get the problem with yours solved? |
I completely understand. Sorry if it didn't come off that way in my post. I was trying to be polite, not short, but it's tough to read through a computer screen.
I would like a replacement as well. Mine seems to be wearing out fast. I have not found them new though, and mostly see them go fast in classifieds or when a bus is wrecked.
I'm going outside for a bit before dinner now and getting those levers swapped out. Can't wait! The plastic ones are just trash. |
