front heater fan & resistor fix with 4spd rear A/C parts
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Dec 02, 2009 9:09 pm    Post subject: front heater fan & resistor fix with 4spd rear A/C parts Reply with quote
Today I helped a friend work on his dying heater in an 86. It made a screeching sound while running and low speed was dead. A new switch did not change anything so he pulled the dash and split the box. Last week he pulled out the dead rear A/C and saved the fans and resistors for heater repairs. Almost the same motor as the dash heater and similar resistor but with more speeds so we swapped both in. This gives his front heater 4 speeds now, after we also changed the switch to the 4 speed version and added an extra wire from it to the new resistor. High speed is still the same speed but there are more choice below it including a slower low speed.
The 4 speed switch is a standard VW car switch so low cost. The part number is 321 959 511 about $7 new. It exactly fits the dash hole and wiring connector.
Mark
purplepeopleeater
purplepeopleeater is offline
PostPosted: Wed Dec 02, 2009 9:25 pm    Post subject: Reply with quote
Got any pictures?
mwsnow
mwsnow is offline
PostPosted: Wed Dec 02, 2009 9:39 pm    Post subject: Reply with quote
The photos aren't great, but you can see the difference in the fan resistors.
http://picasaweb.google.com/slowmachine82/SyncroHeater#
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Dec 03, 2009 11:19 am    Post subject: Reply with quote
Hey neat.
Great info.
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Thu Dec 03, 2009 6:04 pm    Post subject: Reply with quote
Problem is the rear resistor is also NLA from VW.
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD
big swifty
PostPosted: Thu Dec 03, 2009 7:24 pm    Post subject: Reply with quote
I think I found a readily available and inexpensive solution to the NLA resistor issue. Film @ 11:00 (well pictures at least soon'.)
Evan
Captain Pike
Captain Pike is offline
PostPosted: Thu Dec 03, 2009 8:28 pm    Post subject: Reply with quote
That is easy to fix. Just rewind it. I have 2 spares of the front but I'm still in to finding a simple resistor pack to replace the NLA part.
In the mean time ___Bone yard ALL VW, Audi,Sabb,
Porsche '80 cars and look for cross parts.
I recently harvested a 924s 2.5L> '88 our little cousins AFM,temp sensor 2(D'JET on an 88?) all swap. Time for a bone yard hunt.
The parts are out there boys____let's find them.
Dancing First one with 10 spares wins. :2gunfire:
LEARN TO SELF RESCUE
.....................All Current.......................
