Spezialist Banned
Posted: Thu Dec 03, 2009 3:07 pm Post subject: Eurovan automatic |
Hey transmission gurus!
I have a 1993 Volkswagen eurovan westy that has some transmission issues.
Symptoms: car starts in park, 3 seconds trans grabs and stalls engine while in park
Will not start in neutral,
Neutral safty switch? Shifter cable?
I don't want to guess, I know these vans have transmission woes so I read.
Any help would be great, thanks _________________
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Thu Dec 03, 2009 8:30 pm Post subject: |
Not a transmission guru, but there is quite a lot of transmission information on the ev_update Yahoo group, and some very knowledgeable people there. Some her too, just not so many for the Eurovan.
Sounds like trans is engaging while still in park position, if I understand your description. Do you mean it stalls because the park pin is still engaged, or you are putting it in gear and then it stalls for some other reason?
RonC |
Spezialist Banned
Posted: Fri Dec 04, 2009 10:40 pm Post subject: |
Hi Ron,
The transmission seems to be stuck in drive.
As soon as it devolops oil pressure it slams against the the park pin and stalls.
The whole van lurches forward in the process!
The process is while in park.
Thanks for your time, where is this ev group?
Rodney _________________
dhermanesq Samba Member
Posted: Sat Dec 05, 2009 5:49 am Post subject: |
Clean out the servo pack. Take off the pan, clean everything that you can see, blast the packs. The pin isn't being released. You may have to dismantle the whole thing. It might be bent from all the slamming. Sucks but thems the breaks on the auto trans. You can rebuild one for about $300 or so if you do it yourself and the servo packs are okay. _________________ 1993 VW Eurovan 5-Speed
1995 Mercedes S600 v12 (Rides again!)
2001 Passat V6-30v |
Posted: Sat Dec 05, 2009 8:31 am Post subject: |
Spezialist wrote: |
Hi Ron,
Rodney |
ev group is here...
http://autos.groups.yahoo.com/group/ev_update/
Good Luck! |
Spezialist Banned
Posted: Sun Dec 06, 2009 5:59 pm Post subject: |
Hi, thanks for the link, do you have to join? _________________
Posted: Mon Dec 07, 2009 7:05 pm Post subject: |
For that group, yes you have to join. Yahoo group membership requirements vary by group, but that one requires membership.
RonC |
