1970 Convertible Top Replacement
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Jan 20, 2011 8:20 am    Post subject: Reply with quote
We found that rubber seal on at least 2 original
late model tops that never had a restoration.
One was a 1974 'vert I used to own.
It's placed on the outside of the top material and
secured with metal insert bars and screws, much like
cabrio door window seals on the top frame.
There are some reasons why we usually opt for placing
the foam seal under the top material at the header bow,
which is original for earlier model cabrios. These include:
The 2-piece insert bars can be HTF. Might have to make your own.
Properly-sized seal can be HTF. Many repros are too wide/thick.
Screws into new top cover and header. Rather not!
Looks cleaner to have the seal hidden, IMHO.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
72Ghia
72Ghia is offline
PostPosted: Tue Jan 25, 2011 2:46 pm    Post subject: Reply with quote
Sure.. if it works as is why bother with the seal, unless it's an originality issue.
Defenetly a cleaner appearance to hide the seal under the material.
BTW-Im getting ready to apply the canvas top shortly. Do you think it would cause any issues to add a few stiches with some thin thread to the flaps which wrap over the sheet of foam padding on top the frame? I know it gets glued.
Bill
WTB- Billet center caps with Wolfsburg logo
72 Ghia Vert project
Bodywork http://www.thesamba.com/vw/forum/viewtopic.php?t=303542&highlight=
Re-assembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=4762737#4762737
72 Beetle Weekend Driver, restored in the 90's
http://www.thesamba.com/vw/forum/viewtopic.php?t=353424
www.airsuckers.com
Ghiaddict
PostPosted: Tue Jan 25, 2011 5:44 pm    Post subject: Reply with quote
Some extra stitching as insurance is a good idea
where glue is used for bonding things together.
Yes, we do that in many cases.
72Ghia
72Ghia is offline
PostPosted: Tue Jan 25, 2011 8:11 pm    Post subject: Reply with quote
Great thanks. Lastly does the top foam also get stapled along with the lining to the wood bows? Im assuming just the liner gets attached. Getting ready to post some more photos Smile
Bill
www.airsuckers.com
Ghiaddict
PostPosted: Wed Jan 26, 2011 5:42 am    Post subject: Reply with quote
Just the liner.
72Ghia
72Ghia is offline
PostPosted: Tue Feb 08, 2011 5:49 pm    Post subject: Reply with quote
While the top is off I was going to replace the small side tension cables which go across the tops of the door glass. Do you usually replace these with a top install? The existing cables appear in good shape but have about 1/2" deflection (play) before the spring begins to pull. I dont know if this deflection decreases once the top is fitted therefore wasnt sure how much tension is necessary on these side cables before the top goes on. Thanks again !
Bill
www.airsuckers.com
Ghiaddict
PostPosted: Wed Feb 09, 2011 5:32 am    Post subject: Reply with quote
Yes, we have always replaced the side tension cables.
Correct tension on them is set with the top closed and latched.
The coil springs are usually stretched just a few mm by the cables
when the top is closed and latched.
OC Ghia
OC Ghia is offline
PostPosted: Fri Feb 11, 2011 11:58 am    Post subject: Reply with quote
How many hours would an install like that take and how much does it costs? I was quoted $400 and 1/2 a day by a local VW guy.
Ghiaddict
PostPosted: Fri Feb 11, 2011 12:11 pm    Post subject: Reply with quote
For what?
The side tension cables? Think
72Ghia
72Ghia is offline
Guess it depends on how many are working on the top. I read it took 2 guys at Karmann factory 4 hours to do a top. $400 seems very inexpensive.
Took me like 14 hours and Im still not done Rolling Eyes
Bill
www.airsuckers.com
NOVA Airhead
NOVA Airhead is offline
PostPosted: Fri Feb 11, 2011 12:16 pm    Post subject: Reply with quote
That is an excellent price for a Ghia top install. In fact I would make sure the shop is competent and can do it. The price is really low and I think it would take more than one half person day to install.
Several years ago I had a top installed on a Super I used to own. The labor was about $500. I believe a Ghia top is much harder.
I remember reading something about the Karmann factory top installers. IIRC it took two men a full day to install a Ghia top. Now they were performing a lot more hand work back then compared to the kits available now. However they were also highly skilled in their craft.
Ghia Owner Emeritus
Ghiaddict
PostPosted: Fri Feb 11, 2011 12:29 pm    Post subject: Reply with quote
No way in the world can one person replace a complete top
in 1/2 a day. Also, it's one thing for 2 VW Factory Techs to
build a top when new VS. repairing and restoring something
that's at least 37 years old.
OC Ghia
OC Ghia is offline
PostPosted: Fri Feb 11, 2011 4:01 pm    Post subject: Reply with quote
I haven't been to the guy's place yet. I've only been in contact via emails. I believe he works out of his house and works on VW's on the side as a hobby. In the email he said he has done three VW convertibles already. I didn't clarify if he was talking about bugs or ghias. I wanted to get your opinion because $400 sounds kind of low.
zepare
zepare is offline
PostPosted: Mon May 16, 2011 12:38 pm    Post subject: Reply with quote
Hi all. What is the best method to add 1/4" (or more) to the front of a wood header bow. I am installing a new one and the side clearance is good (2mm) but the middle is 15mm. It needs to be 7mm. Any ideas? Thank you in advance.
66 ghia vert.
77 Scooby van.
Ghiaddict
PostPosted: Mon May 16, 2011 4:54 pm    Post subject: Reply with quote
As Bill stated in the previous (locked) thread, for filling
a gap of 1/4" or so I'd use some dense, closed cell foam
strips to eliminate the extra space.
Sometimes you face a gap even larger than that and that's when
wooden wedges secured with brads and wood glue can be used.
Vendors still seem to be sending out header bows with too
much arc built into them, causing fit problems.
jbassman
jbassman is offline
PostPosted: Mon May 16, 2011 9:22 pm    Post subject: Reply with quote
From another thread. The pins are overshooting the holes, and everything else is lined up. The header bow and metal corners are the only thing new to the car. It`s never been in an accident and the heater channels are rust free. The body has been off the frame, and all shims have been used to get the door spacing right.
OK, here is a picture of the pin placement to the frame.
jbassman
jbassman is offline
PostPosted: Mon May 16, 2011 9:25 pm    Post subject: Reply with quote
The fit`s good once I loosen the bolts back far enough to get the pins where they should be.
jbassman
jbassman is offline
PostPosted: Mon May 16, 2011 9:26 pm    Post subject: Reply with quote
One more.
72Ghia
72Ghia is offline
PostPosted: Mon May 16, 2011 10:07 pm    Post subject: Reply with quote
Maybe Vince would know if rear straps need to be adjusted to spec first or if this is something that can be possibly corrected by shimming the frame where it bolts to the body. I've seen other postings with this issue before. I'd first guess maybe that the rear straps need to be checked for specified distance between car body & main bow.
Bill
www.airsuckers.com
Ghiaddict
PostPosted: Tue May 17, 2011 5:43 am    Post subject: Reply with quote
One easy solution would be using the shorter locating pins
in your top because they will probably line up better and drop right
into the holes in the windshield frame. The chrome pins are
available in 2 versions:
As a last resort, you could also use the stop bolt located rear of
the door pillar to shorten the forward motion of the main bow. The
VW manuals will tell you that this is not the proper use of this bolt
and it may result in other measurements needing re-adjustment.
Exactly what bolts are you loosening to get a proper fit? When you
loosen the 6 frame mounting bolts on the door pillars, it also allows
you to slide the entire mechanism up or down to obtain the correct
gap between the body and the ends of the main bow @ the lock pillar.
Doing this also changes the alignment of the chrome locating pins
to the top of the w/s frame, but not by much.
It's all a balancing act because one change you make will usually
have an effect on other components and measurements.
Page 7 of 10
