Early Generator Rebuild?
RichOakley
RichOakley is offline
PostPosted: Mon Dec 07, 2009 3:17 am    Post subject: Early Generator Rebuild? Reply with quote
The generator in my '47 started to scream on the way back from H.O. so I guess I need to replace the bearings. This is a job I haven't done before but I guess the bearings are readily available. Any advice/tips etc?
virtanen
virtanen is offline
PostPosted: Mon Dec 07, 2009 4:59 am    Post subject: Reply with quote
At least here they offer type 6202 bearings with plastic dust covers, but originally there is used separate washer covers. It is needed to remove those integrated covers before use. Otherwise there is too much thickness and it get stuck.
johnshenry Premium Member
johnshenry is offline
PostPosted: Mon Dec 07, 2009 7:50 am    Post subject: Reply with quote
Wolfsburg West sells the bearings
http://wolfsburgwest.com/cart/DetailsList.cfm?ID=111903221A
And the bushes.
Not too much to rebuilding them. You'll need a very wide, thick slotted screw driver bit to get the field cores out without munging up the the slot in the screw. I made one out of an old chisel and use it in an impact gun. You'll probably want to re-wrap the field windings an replace the leads. The paper wrap does not hold up well. I re-wrap them with black cloth tape that I use with the wiring harnesses. I use new cloth covered wires for the leads. Of course replace the brushes.
The armatures I usually just clean up, and chuck them in my drill press and spin them and run some fine ScotchBrite against the commutators. Also, I use dental pick to clean the gaps between the commutators. Metallic junk in there can cause shorts or current bleeds between the windings.
If you take it all the way down, you can bead blast the housing, and have it re-plated. Paint the end caps and make it look "cracking".... Wink
John Henry
'57 Deluxe
'56 Single Cab
RichOakley
PostPosted: Mon Dec 07, 2009 8:23 am    Post subject: Reply with quote
Thanks for the advice guys.
I think I have managed to find a source for the bearings here in the UK so I will strip it down and give it a shot.
Cheers!
Rich.
PostPosted: Mon Dec 07, 2009 8:30 am    Post subject: Reply with quote
One thing to watch for Rich. On one end (fan end I think) the bearing is retained in the cap and you can't just pull the cap and bearing off the end of the armature. And on the early ones, the retaining plate is held in by two slotted M4 or M5 screws. Easy to see if you are looking for it, but miss it, and, say, maybe use a wheel puller to try to get the end cap off, and you'll bugger up the retainer.
Ask me how I know.
Look for the screws, and there is enough room for your to get them out with a small screwdriver. Later ones used a circlip, but I think the early ones had screws.
Also, make sure as you slip stuff off the armature, lay it all out in the order you took it off. Lots of washers and spacers and such. Manuals have pretty good exploded views of this.
John Henry
'57 Deluxe
'56 Single Cab
RichOakley
PostPosted: Mon Dec 07, 2009 8:47 am    Post subject: Reply with quote
Ask me how I know.
Thanks John, good advice.
RichOakley
PostPosted: Fri Dec 11, 2009 11:49 am    Post subject: Reply with quote
My new generator bearings arrived in the post this morning, so I proceeded to strip it down and made sure everything was laid out very carefully in order.
Once stripped, I compared it to my 1952-55 workshop manual which shows the components of a 'RED' generator....
In my unit, no.18 (spacer washer) is not present. I reassembled it as it came apart with the new bearings fitted. However, when I came to slip the armature back into the frame, a very thin 'wavy' washer appeared by the brushes......
and here's a picture of the wavy washer slipped over the end of the armature just for some size perspective...
Firstly, I wonder if this is an early 'RED' generator (it's from my '47) and therefore different to the one in the 52-55 'shop manual.
Secondly, where on Earth has that wavy washer come from? It only appeared when I slotted the armature back into the case. I can only think that it sits in the end of the bearing housing (pulley end) and I did not notice it in there when I disassembled the unit.
Any ideas would be most welcome!!
splitjunkie
splitjunkie is offline
PostPosted: Fri Dec 11, 2009 1:49 pm    Post subject: Reply with quote
your assumption is correct. It is there to preload the bearing on the pulley end.
Chris
RichOakley
PostPosted: Fri Dec 11, 2009 1:55 pm    Post subject: Reply with quote
Thank you and praise The Lord.
It's all fitted back together now and appears to be just fine. Do you know if the missing spacer washer is correct though (as per my description above)? I assume it must be correct, but just want to make sure.
My '46, '48 and '49 parts manuals do not have exploded diagrams of the generator parts.
Many thanks,
Rich.
RichOakley
PostPosted: Fri Dec 11, 2009 2:03 pm    Post subject: Reply with quote
....and John- thanks for your advice on the small M5 retainer plate screws. I would have done exactly what you did with your puller if you hadn't warned me!! Laughing
PostPosted: Fri Dec 11, 2009 2:16 pm    Post subject: Reply with quote
You're welcome. We can make mistakes, but we don't all need to make the same one!!!
John Henry
'57 Deluxe
'56 Single Cab
crotchsplit
crotchsplit is offline
PostPosted: Fri Dec 11, 2009 2:18 pm    Post subject: Early generator rebuilds Reply with quote
Glenn Cheaney is a master at rebuilding these old generators. Give him a call, he is a very well educated on these and has worked on old generators for 40+ years.
View user's profile Send private message AIM Address Twitter Gallery Classifieds Feedback
kevm
kevm is offline
PostPosted: Fri Dec 11, 2009 2:18 pm    Post subject: Generator rebuild Reply with quote
John,
I remember reading a previous topic from you on the rebuild process and recall you mentioned the windings needed magnetising or something and you had a pic of the generator hooked up to something, was that really neccesary and is that something they did in the factory ?
Thanks
Kev
RichOakley
PostPosted: Fri Dec 11, 2009 2:55 pm    Post subject: Re: Generator rebuild Reply with quote
kevm wrote:
John,
Thanks
Kev
Kev,
I had to polarise a generator a few years ago when I had one re-wound on a '62. It basically re-magnetises the dynamo enough for the first initial spin. To do it, you short out the DF connection to the case and then connect a wire from the battery to D+. The generator will start to spin and off you go!
Rich.
PS: still got the Huf carb.
PPS: don't suppose you're going to the Heritage meeting tomorrow lunchtime?
PostPosted: Fri Dec 11, 2009 3:00 pm    Post subject: Re: Generator rebuild Reply with quote
RichOakley wrote:
kevm wrote:
John,
Thanks
Kev
Kev,
Rich.
Yep. Not needed unless you rewind the field coils and/or take the filed cores out. What it does it creates a little bit of permanent residual magnetism in the steel cores so the current "starts off" the right way.
In Australia, you have to reverse to polarity since magnetism is polarized the reverse way there.
Wink j/k
John Henry
'57 Deluxe
'56 Single Cab
rod_vw
rod_vw is offline
PostPosted: Sat Dec 12, 2009 11:01 am    Post subject: Reply with quote
Anyone else with generator or starter problems here in the UK would get good help from Pete Good. See Volksgoods logo on the links page of http://www.historicvws.org.uk/
I've no financial connection with Pete's business, he's just a good supporter of those of us with early cars here in the UK.
Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build.
RichOakley
PostPosted: Sun Dec 13, 2009 12:28 am    Post subject: Reply with quote
I agree Rod. Spoke to him the other day- very helpful guy.
kevm
kevm is offline
PostPosted: Sun Dec 13, 2009 5:22 am    Post subject: Re: Generator rebuild Reply with quote
johnshenry wrote:
RichOakley wrote:
kevm wrote:
John,
Thanks
Kev
Kev,
Rich.
Wink j/k
Many thanks guys, I have removed and rewrapped the field coils in mine so I will need to do this.
Rich, saw you still have the Huf carb, I am interested in it, I should have bid Rolling Eyes
Missed the heritage meet but I think a few of us are going to the Ace cafe on Tuesday night (weather permitting) if you are about ?
Cheers
Kev
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Tue Dec 15, 2009 9:26 pm    Post subject: Reply with quote
Where would one find this black cloth tape? Any store recommendations?
Also does anyone have a source of a small amount of the cloth-wrapped green and red wire? I only need the couple of inches and every place I have looked wants to sell me multiple feet of it.
Thanks !
PostPosted: Wed Dec 16, 2009 10:52 am    Post subject: Reply with quote
Thanks !
I get my cloth tape from Kabel Schmidt in Germany Nancy. I but a bunch of other wiring stuff from them. Rhode Island Wire also sells it, but theirs is heavier, and you'd have to be careful about building up too much thickness.
I can probably send you the wire and some tape if you want, LMK what you need exactly via e-mail...
John Henry
'57 Deluxe
'56 Single Cab
