Dry sump engine.. going back to wet sump, concerns?
risk
risk is offline
PostPosted: Thu Dec 10, 2009 9:52 am    Post subject: Dry sump engine.. going back to wet sump, concerns? Reply with quote
I recently bought two motors off a vintage midget racer. they are both set up for dry sump oiling. I want to run them in street cars, and go back to the stock wet sump configuration. Are there any things done inside the case that i should change look for to go back to wet sump?
Two things i noticed off the bat are the oil pump studs, and the dipstick hole has been threaded and plugged.
Stripped66
Stripped66 is offline
PostPosted: Thu Dec 10, 2009 10:23 am    Post subject: Re: Dry sump engine.. going back to wet sump, concerns? Reply with quote
Potentially. How is the current dry-sump configuration scavenging the case? Does it scavenge from the bottom of the sump (likely) or through the stock oil pick-up tube? If the latter, then changing back to a wet sump configuration could be simple. However, if the oil pick-up tube was omitted from the engine build, then it becomes a bit more tricky. The easiest solution to this problem is to split the case and reinstall the oil pick-up. *However* you could feed the sump-mounted oil pick-up back to the case on the inlet side of the oil pump. It would require some drilling, tapping, and plugging, but it can be done.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
risk
risk is offline
PostPosted: Thu Dec 10, 2009 1:35 pm    Post subject: Reply with quote
they both scavenge from the bottom of the sump, with an autocraft sump extension. splitting the case is no big deal, i wanted to check the bearing clearances anyways. they run a pulley with only timing marks and no belt groove. like a drag button. will the case accept the standard size sand seal?
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Dec 10, 2009 1:40 pm    Post subject: Reply with quote
Midget engines? Will you run them on the street, or racing still?
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
risk
risk is offline
PostPosted: Thu Dec 10, 2009 1:45 pm    Post subject: Reply with quote
building them for the street
risk
risk is offline
PostPosted: Fri Dec 11, 2009 7:09 am    Post subject: Reply with quote
Is there some concern about midget engines? they were ran on alchohol and are super clean inside and out..
Jake Raby
Jake Raby is offline
PostPosted: Fri Dec 11, 2009 7:26 am    Post subject: Reply with quote
The engine's internal oil system could have been optimized for the dry sump arrangement. If this occurred it may be impossible to wet sump the engine without complications.
When I build an engine thats designed to optimize with a dry sump system it would never be compatible with a wet sump again without disassembly.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Fri Dec 11, 2009 8:00 am    Post subject: Reply with quote
What mods do you do Jake?
If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here.
miniman82
Samba Swamp Donkey
PostPosted: Fri Dec 11, 2009 10:34 am    Post subject: Reply with quote
Oh nothing in particular, I was just thinking they are probably cammed out so street driving ought to be fun. You know, high winding engines. Laughing
risk
risk is offline
PostPosted: Fri Dec 11, 2009 11:38 am    Post subject: Reply with quote
one has a bugpack 4062.. the other has a BMR 18.4 which i haven't found any info on. i'm not at the point in either of these builds for cam selection yet.
I can ask the guy i bought the engines from.. however he is 82 and has been a little foggy about most of the details on these..
still not sure what case this one is.. the other case is vw mexico.
http://www.thesamba.com/vw/forum/viewtopic.php?t=384688&highlight=todd+francis
Jake Raby
PostPosted: Fri Dec 11, 2009 11:45 am    Post subject: Reply with quote
The ones I have worked with burned alcohol...
Jake Raby
jesus_chrysler
jesus_chrysler is offline
PostPosted: Fri Dec 11, 2009 1:34 pm    Post subject: Reply with quote
is there a reason why you do not want to run the dry sump? It has many advantages over the wet sump.
risk
risk is offline
PostPosted: Fri Dec 11, 2009 2:52 pm    Post subject: Reply with quote
cost mostly, and time to fab and install.. I don't have the pump, lines, tank etc. I figure it will be cheaper and easier to go back to wet sump. Its going in a mild street driven car so there really is no need for me to go dry.
