NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Tue Dec 15, 2009 7:42 pm Post subject: Steps to make a runner out of a long dormant 1600 |
Hey all. I found a 1600cc long block intact and was hoping to use it as a beatdown runner while another engine is being built for it.
I have no clue what's going on inside of it and really am in no mood to tear the whole thing apart. I'm more interested in getting it mildy freshened and running it till it blows.
Here's the basic stuff.
It's a DP.
All holes have rags stuffed in them.
I've been squirting Marvel Mystery Oil in the intakes for about 2 weeks.
She turns over about 180 degrees total then gets sticky. (I havn't popped the valve covers yet) If I can get it to turn completely over then I'll feel better about using her.
Plan is to pop the heads off and install new pushrod tubes and seals along with oil cooler seals and a main seal. Check deck height and endplay. I might need a new distributor drive as the one that's in there is looking pretty sketchy. Then piece together some tin and have it ready to go.
Any other input would be greatly appreciated.
NAES
Anything else I should think of doing before I put it back together? _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Tue Dec 15, 2009 7:50 pm Post subject: |
Is the distributor installed when you are trying to turn it over? You mentioned the drive looks 'sketchy'. Without the dizzy in the drive will try to climb out of the hole when being turned over... |
NAES Samba Member
Posted: Wed Dec 16, 2009 12:41 pm Post subject: |
Dizzy is out. I might just pull the drive gear since it looks corroded. Might be a good weekend project for me.
Thanks, NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Posted: Wed Dec 16, 2009 2:18 pm Post subject: |
I should have added if the drive is climbing out it can also lock up the motor. f\Force it too far and you can bugger up the brass crank gear... |
Almost Alive Samba Member
Posted: Wed Dec 16, 2009 4:09 pm Post subject: |
Pull the spark plugs then try to turn it. Should be much easier |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Wed Dec 16, 2009 10:18 pm Post subject: |
Just plop an 009 in there, that's about all they're good for on a stock engine.
I keep busted dizzies just for that kind of purpose. |
