pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Thu May 19, 2011 6:22 am Post subject: |
vdub411 wrote: |
Then I need to figure out how to wire up the windshield wipers. It's only 4 wires one ground, one high, one low and one return. Anyone know which color wire is which? |
maybe this will help. i have been using the last wiring diagram posted to wire my cars. http://www.thesamba.com/vw/forum/viewtopic.php?t=464110 |
vdub411 Samba Member
Joined: August 14, 2007 Posts: 264 Location: Mid Michigan
Posted: Wed Jun 29, 2011 8:23 am Post subject: |
pafree: Thanks for the link. I will be using that wiring diagram also.
Wow how time flies. I did a little bit of work on the trunk/stereo/wiring. I'm making all my own panels with some fabric and paneling. It's turning out not to bad. All the stuff in the trunk will be mounted on rubber mounts to help absorb the shock. Both batteries are going in the front and I need to finish the cover for the gap under the gas tank. Here's some pics, let me know what you think.
_________________ 1975 Baja Bug
1972 Type III Fastback
B&N Rattler Buggy
SandRails Coming Soon!!! |
Posted: Fri Nov 02, 2012 3:03 pm Post subject: |
Update. Well it's been a while and things have changed again. All the stereo equipment has been torn out. I still can't get the brakes to work right. We went up north over the summer with the bug in tow. It made about 3 laps around a dirt road and broke the clutch pedal. The only thing on the car I didn't replace was the pedal assembly and it snapped the hook off the clutch pedal in the tunnel. Back to the drawing board. Looking at maybe a hydraulic pedal setup and some decent brakes. Nothing against the EMPI disk brakes but they really do suck. _________________ 1975 Baja Bug
B&N Rattler Buggy
coolsnake88 Samba Member
Joined: May 12, 2010 Posts: 63 Location: orange county, ca
Posted: Mon Oct 20, 2014 8:18 pm Post subject: |
you know whats done to those carbs? i have the same carbs on a 1600 and a small turbo would be nice. |
Posted: Sat Mar 26, 2016 12:46 am Post subject: Re: My winter/spring project |
THE RESURRECTION!!!! 4yrs of abuse, neglect and a ton of fun. Finally got some time to drive it last year. The turbo is a PITA! So it got tore off. Running just the 1776 with dual kads so I can actually ride instead of break non stop. Here are some pics from my last run up in Northern Mi. I'll have more updates hopefully. Trying to get some motivation to get this beast back on the road, figured reading my build would help. It's crazy how much I've learned from the beginning of this build up til now. Enjoy!!!
B&N Rattler Buggy
Posted: Sat Mar 26, 2016 12:57 am Post subject: Re: My winter/spring project |
I forgot, I also added these to the collection.
B&N Rattler Buggy
