Daddybus Samba Member
Posted: Wed Dec 16, 2009 11:14 am Post subject: Emulsion tubes? Jetting help! |
42 DCNF carbs 34mm venturis.
2028 C25 scat cam 7.25:1 CR 40x35.5 heads in a bus. IRS tranny. 60-65 mph at 2500-2800 rpm, 70 mph at 3K rpm.
Currently 60 idle, 140 mains, F24 emulsion, 190 air jet slight flat spot from idle to main circuit transition.
Have tried...
60/140/F24/180 too fat sluggish with poor mileage
60/125/F25/180 too lean gutless no top end
Larger main jet = more fuel, Larger Air correction = more air (leans mixture) What about emulsion tube? What is the difference between an F24 and an F25 emulsion tube? |
Posted: Wed Dec 16, 2009 8:56 pm Post subject: |
Anybody? |
Hophead Samba Member
Joined: January 03, 2005 Posts: 940 Location: Chico,Ca
Posted: Wed Dec 16, 2009 11:29 pm Post subject: |
Idf's run 50-55 idle jets. I do not know if 60's are correct for DCNFs. You still have 130, 135s to play with for mains.
I am just throwing this out there. The Tuner gurus will show up. I vote for too rich of an idle jet.
I had a pair of DCNF's on a 1776cc 25 years ago but I did not need to tweak them as they were set up well. I do not remember any of the particulars. _________________ 70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA |
Posted: Thu Dec 17, 2009 5:30 pm Post subject: |
I had 50's and it was too lean. I think that I went to 60's. I'll have to check. My near vision isn't what it used to be. My emulsion tubes are all F25 (what Berg recommends). I installed 140mains/f25/180 air today and advanced the timing to burn all of the fuel. I have ordered 135s and 130 mains. When they arrive I will try the 135s and retard the timing. Heavy buses don't like a lot of advance. I will check the idle jets, they may be 55s. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
