youremyboyblue Samba Member
Joined: December 01, 2009 Posts: 38 Location: whereever my tdi syncro will take me!
Posted: Mon Dec 21, 2009 9:27 am Post subject: mystery line, please help identify |
i have what looks like a vacuum line (? white plastic tubing with black rubber sheath) disconnected in my 1986 syncro vanagon engine bay. it doesn't look to be fuel system related based on the diagram on the black box in the engine bay or in the bentley. any help identifying this is appreciated!
1 of 3 lines coming from passenger side of firewall:
Dogpilot Samba Member
Posted: Mon Dec 21, 2009 9:52 am Post subject: |
It looks as if it was the transmission vent line. The L fitting has broken off. It does get brittle. It should go into the .50¢ piece sized hole in the bell housing, the is a big rubber grommet that fills the hole with a small hole in the middle the end of the plastic L went into. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Mon Dec 21, 2009 2:34 pm Post subject: thanks for the swift reply! |
even with the heads up as to what i'm looking at, i'm still at a loss to find information about it in the bentley ...
now i'm curious, what is the damage exposure while driving like this? filth in to the transmission through the .50 grommet? and, furthermore, is this a simple FLAPS fix? |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Mon Dec 21, 2009 2:43 pm Post subject: |
Hey youremyboyblue,
Those plastic lines are Syncro only vent lines from your front differential,
transmission, and bell housing. Their purpose is to provide atmospheric venting from these units which are sealed against water and mud. Without these vents the pressure difference between inside/outside would blow the seals.
If you cannot find a replacement L fitting for the top of the bell housing it's no big deal unless you want to go mud whooping, then water and crap would get into the bell housing.
You can always fab something to work (rubber stopper with hole for plastic line) _________________ Currently:
Posted: Mon Dec 21, 2009 2:51 pm Post subject: |
youremyboyblue,
Here is a pic of what the original vent plug looks like:
The pic is of my Zetec motor, so the location is different than yours. _________________ Currently:
Posted: Mon Dec 21, 2009 3:28 pm Post subject: thanks for all the help ... |
even with all the help thus far and after looking around for 20 min; i still can't find anywhere this line would fit to.
we just had a snow storm; i guess i'll just drive it 'til it blows ... |
Posted: Mon Dec 21, 2009 3:42 pm Post subject: |
youremyboyblue,
you are not gonna blow anything. Like I said, you can leave it the way it is unless you wanna go driving through deep puddles (2-3ft)
The place where the plug goes is that .50 cent sized hole at the top of the bell housing. You can see it in the photo you posted (Right hand middle of your photo) _________________ Currently:
Posted: Mon Dec 21, 2009 3:55 pm Post subject: |
Quote: |
you are not gonna blow anything. |
whew ...
i think what is throwing me is that i'm missing the rubber grommet; thus, the rusting. any idea on how to determine a replacement part #?
thanks for the help! |
iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Mon Dec 21, 2009 3:57 pm Post subject: |
Go to your pic you sent us and you will see the 50 cent hole behind the #3 intake runner. The hole is in the case just below the engine/trans bolt. You can't miss it. No harm done to leave it as is, it only vents the trans. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
