Tonny_Larsen Samba Member
Posted: Sun Jan 03, 2010 4:32 am Post subject: 7, 6 and 5 rib inner pressings- change date? |
Can anyone help me with pictures like this. I will try to find out when the pressing in the reinforcement plate changed from 7 pressings 5.
As I know there are 3 different types.
The picture is from my own 50.
-Tonny
axel struwe Samba Member
Joined: January 18, 2005 Posts: 288 Location: Germany
Posted: Sun Jan 03, 2010 7:08 am Post subject: Re: Help with pictures and information |
Tonny_Larsen wrote: |
-Tonny
Hi Tonny,
on my barndoor (20-06751) it looks the same as on yours. I have no better photo in the moment. But as i see, there are 7 pressings.
See you
Axel |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Sun Jan 03, 2010 8:09 am Post subject: |
5 ribs...Not the best pic and i guess not much help as its a 55 and near the end of BD production _________________ 64 356 C Coupe |
Posted: Sun Jan 03, 2010 8:36 am Post subject: |
Rusting Hulk wrote: |
5 ribs...Not the best pic and i guess not much help as its a 55 and near the end of BD production |
it´s your bus from January-March 1955 or later? |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 394 Location: Phoenix, AZ
Posted: Sun Jan 03, 2010 9:12 am Post subject: |
My '51 (20-14119) has six. Four behind the hump, but only two in front. It's in a tight spot to get a picture right now, but I can try to get one soon if you need it.
-David |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1549 Location: Northampton - Uk
Posted: Sun Jan 03, 2010 9:30 am Post subject: |
May 52 20-026662
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
johnny d Samba Member
Joined: March 22, 2004 Posts: 2204 Location: where it all came from. ;)
Posted: Sun Jan 03, 2010 11:31 am Post subject: |
here´s mine tonny 20-008851 build 16.01.1951
_________________ GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007 |
Barndoor51 Samba Member
Posted: Sun Jan 03, 2010 1:10 pm Post subject: |
The change must have been when the Heater control knob and choke lever from ch. number 20-14685
The chape of the new bulkhead do it necessary to redo the reinforcement plate. _________________ 20-03194 Panel
20-011384 Kombi
20-110724 SingelCab
January -58 double cab "the Swedish Binz" |
DSweinhagen wrote: |
-David |
It would be great with a picture of the six pressing.
-Tonny |
Posted: Sun Jan 03, 2010 1:14 pm Post subject: |
Barndoor51 wrote: |
The chape of the new bulkhead do it necessary to redo the reinforcement plate. |
Of cause, you a right
Then we just have to find, when they changed from six to five.
-Tonny |
Posted: Sun Jan 03, 2010 2:28 pm Post subject: |
axel struwe wrote: |
Axel you should be able to tell by the beam ... it's a February 55... Barndoor _________________ 64 356 C Coupe |
Posted: Sun Jan 03, 2010 9:44 pm Post subject: |
Axel you should be able to tell by the beam ... it's a February 55... Barndoor |
oh, shame on me ...
I never write here anymore, until i ask my mother.... |
Posted: Mon Jan 04, 2010 2:02 pm Post subject: |
I am still trying gather some more information for use on my site, but need two more pictures.
One with six pressings and a picture of the spare wheel box on a ambulance.
Something like this, but from a ambulance.
-Tonny
Joe Caraway Samba Member
Posted: Mon Jan 04, 2010 6:26 pm Post subject: Barndoor Wheel Well |
Here is a picture of right front wheel well from the '53 smooth gate single cab. #20-058686. Hope this helps. |
Posted: Tue Jan 05, 2010 9:29 am Post subject: Re: Barndoor Wheel Well |
Got this pictures from David (20-014119) with 6 pressings.
-Tonny
Buba Samba Member
Joined: February 23, 2003 Posts: 383 Location: Argentina
Posted: Wed Jan 06, 2010 6:23 am Post subject: |
-Tonny
Tonny, here you have the pics, this are from my Ambulance VIN 20-028546
Regards
Marcos _________________ 52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug |
Buba Samba Member
Posted: Wed Jan 06, 2010 6:46 am Post subject: |
Hi, this pic is from my Jan 1952 Panel 20-020427, I promess you I'll take a better pic later.
As you can see there are 6 pressings, but to outside instead of to inside.
So the change, from 6 to 5 pressings should be between Jan and May becouse in my May 52 Ambulance 20-027664 there are 5 pressings.
Other difference I notice between them is the reinforcement on the roof (see link below), is present on the panel, but not on the ambulance.
http://www.barndoor.dk/detaljer35.html
Regards
57 SC
57 Oval
60 SO23
60 Bug |
Scotty Samba Member
Posted: Wed Jan 06, 2010 7:15 am Post subject: |
Buba - Vw used the same panel above each chassis rail, so on one side of the bus the pressings point out and on the other side the point in. If you check the other side of your bus you will see the pressings point in _________________
EverettB wrote: |
Posted: Wed Jan 06, 2010 7:23 am Post subject: |
Fantastic, thank you very much, all of you
-Tonny |
Buba Samba Member
Posted: Wed Jan 06, 2010 7:42 am Post subject: |
Scotty wrote: |
Buba - Vw used the same panel above each chassis rail, so on one side of the bus the pressings point out and on the other side the point in. If you check the other side of your bus you will see the pressings point in |
Great, I didn't know that, I'll check.
Thanks
57 SC
57 Oval
60 SO23
60 Bug |
