Original Key Shape
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Jan 03, 2010 4:49 pm    Post subject: Original Key Shape Reply with quote
Just wondering if original keys for a 63 type I are offset like these
or centered like these
Images from the classifieds.
Insaniac
Insaniac is offline
PostPosted: Sun Jan 03, 2010 5:08 pm    Post subject: Reply with quote
I believe it should be the off centered type. I do have an SC key that is centered tho', but I don't think many were made that way.
BWD
Samba Mailman
BWD is offline
PostPosted: Sun Jan 03, 2010 5:09 pm    Post subject: Reply with quote
Ask Gabe.
BWD
JHC
member #2850
1966 Beetle
_____________________________
Koffer
Koffer is offline
PostPosted: Sun Jan 03, 2010 7:14 pm    Post subject: Reply with quote
I have the OG key that came with my car and its the SU profile . The key head is centered on the shaft . All the HUF replacements Ive seen are offset . Ive seen a few aftermarket non stamped with the VW logo just solid head, not off set but its been a while
Todd
65 ruby red beetle
AlteWagen
Troll
PostPosted: Sun Jan 03, 2010 9:05 pm    Post subject: Reply with quote
thanks
My 63 is an SU as well.
Is there a sticky that I missed about keys??
PSScoots Premium Member
PSScoots is offline
PostPosted: Sun Jan 03, 2010 9:11 pm    Post subject: Reply with quote
We were first owners of a 1963 bug while I was growing up. The ignition key was offset, the engine compartment key was centered. My 66 bug is the same way.
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Sun Jan 03, 2010 9:39 pm    Post subject: Reply with quote
SU key codes which fit 1963 come in both styles - centered and offset. I have SU Hufs in both styles.
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
Koffer
Koffer is offline
PostPosted: Sun Jan 03, 2010 10:35 pm    Post subject: Reply with quote
Sorry is this
For sale or just a FYI ?
( as I'm looking for some centered type Wink )
Todd
65 ruby red beetle
AlteWagen
Troll
PostPosted: Mon Jan 04, 2010 12:18 am    Post subject: Reply with quote
Doors and ignition use the same key right?
This is from a aug 63 owners manual. It shows a centered key.
65 manual, centered key
67 off center
I take it replacements could be either way.
Were verts the only model that had total matching keys? (doors, hood lock, glove box, and decklid)
67 Florida Deluxe
Samba Purist
PostPosted: Mon Jan 04, 2010 7:41 am    Post subject: Reply with quote
Sorry is this
Just an FYI Smile . The owner's manual may show the centered style, but like I said, SU comes in both style. You may want to contact Gabriel the VW key guru or check his ads. They pop up from time to time and he can cut them according to your key code.
alienchauncey
Location: mostly harmless planet in sector ZZ9 Plural Z Alpha
alienchauncey is offline
PostPosted: Tue Jan 26, 2010 4:14 pm    Post subject: key Reply with quote
My 65 only came with one key off centered without a cut out "the one on the bottom". Found the correct key blank with cut out on line. They called it an "aftermarket" ignition key. Its a little different but works fine. I showed it to my friend with a 63 and his was exactly the same "aftermarket" ignition key. Even the same cut too. we tried both our keys in each others ignitions and they both start. I wonder how many of us have the same damn key.
does your keys look like this???
EXJAY
EXJAY is offline
PostPosted: Tue Jan 26, 2010 6:37 pm    Post subject: Reply with quote
^ that cut looks famillar Shocked
EXJAY
'74 Superbeetle (Family owned since new)
'73 181 Thing (sold)
black.e90
black.e90 is offline
PostPosted: Tue Jul 27, 2010 2:46 pm    Post subject: Re: key Reply with quote
Which key profile is the key on top? I have the same after market key and after comparing it to this picture its a dead ringer. I am hoping to get a OG VW key soon, but don't know the key profile
Dangermouse
Dangermouse is offline
PostPosted: Tue Jul 27, 2010 3:19 pm    Post subject: Reply with quote
I'm lucky enough to have my original SG73 key and it's offset but with the VW rotated 90 degrees to the ones shown.
I'd quite like a spare in this style.
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
bill may
bill may is offline
PostPosted: Tue Jul 27, 2010 7:07 pm    Post subject: Reply with quote
original keys were steel,check with a magnet. brass keys are not original even with vw cutout.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
anthracitedub
anthracitedub is offline
PostPosted: Tue Jul 27, 2010 8:59 pm    Post subject: Reply with quote
I have both of my 62's original keys…they are not offset.
My 57 Ghia has the original key and it is offset.
65VOLLA
65VOLLA is offline
PostPosted: Fri Jul 30, 2010 3:08 am    Post subject: 58 key Reply with quote
Could anyone pls assist on which is the correct key for my 58 Bug
Bruce
Bruce is offline
PostPosted: Fri Jul 30, 2010 10:40 pm    Post subject: Reply with quote
The two keys that are horizontal in this pic are correct for your car.
VdubPilot
VdubPilot is offline
PostPosted: Tue Jul 05, 2011 9:40 pm    Post subject: Re: key Reply with quote
My 63 has an aftermarket ignition with a key that is nearly identical to the one on the bottom, and I would like a key with the VW emblem like the one on the top. None of the original key blanks seem to be the right type of key to make a copy. Does anyone know where I could get a key like the one on top?
Bruce
Bruce is offline
PostPosted: Tue Jul 05, 2011 10:22 pm    Post subject: Re: key Reply with quote
Correct looking keys don't exist for your aftermarket repro ignition switch. If you want the correct key, you must buy an original ignition switch.
If you don't like the idea of using a 45 year old switch, you can transfer the original lock cylinder into your repro ignition switch. That will allow you to use the correct key.
