vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Tue Jan 05, 2010 2:36 am Post subject: Fabricated heat channels |
I have a 67 bug in pretty bad shape that I want to start working on. It would need heat channels, front firewall, rear crossmembers, and a package tray, along with new pans. I have done all this before (on other bugs) using patch pieces and new channels and floor pans. I am considering fabricating the whole bottom perimeter of the body using square (or rectangular) tubing. It would resemble the 3" lift kits that are available, but I will not be lifting the body. I will form in the package tray with square tubing or angle and have the panels be removable for access to top of tranny and back (actually front) of motor. I saw a bug at a show once that had this done, but it was in order to lower it. The channels were raised and fit inside of door openings in order to get the body down several inches. It looked good, but it also took a lot of work. I also want to do something similar with the chassis. Maybe frame the perimeter again with tubing and use diamond plate aluminum pans. I just want to do something different and I think this would make for a very strong setup. I have been searching for pics or posts on other people doing this, but can't find much. I know it has been done, anyone know where to find any pics?
Thanks |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Tue Jan 05, 2010 3:08 am Post subject: |
Seems like a lot of work to me Steve. My heater channels I put in my 67 were only $250 shipped. The nice danish ones. No fabbing, just clean up the old ones and weld them in. I'm sure you could do it, but will it be worth it in the end? _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Jan 11, 2010 5:34 pm Post subject: |
Nobody has any pics? |
hpw Samba Member
Posted: Tue Jan 12, 2010 2:27 am Post subject: |
Thanks for the link. That is similar to what I want to do but I would like to also form the base of the front firewall and the rear crossmembers with heavy square tube and weld it all together. You would never have crushed up jack points again. I have one of those 3" body lifts laying around. I should be able to use that as somewhat of a template. I just figured it was done before and someone might have some pics for ideas.
Thanks. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jan 12, 2010 12:46 pm Post subject: |
All that Work to hack something together that you'll be Embarrassed about! Re-build with new/used parts and build a Nice VW with Resale Value not a hack! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
hpw Samba Member
hpw Samba Member
Posted: Tue Jan 12, 2010 3:56 pm Post subject: |
If it has shiny paint on good metal then I'm happy! If your using new rocker skins that's all that shows. Some people need More than just rockers. I just cut my second squareback up to order to ship to Nova Scotia to repair a notchback.
Posted: Wed Jan 13, 2010 12:33 pm Post subject: |
I'll bet that ghia is stronger than any were from the factory. Do you have any more pics of the fabricating part of it? |
hpw Samba Member
