73stroker Samba Member
Posted: Fri Mar 19, 2010 11:01 am Post subject: |
Same here, very nicely done, been running it for 2 years on my 2275 with no complaints. _________________ 1973 standard Type 1
2276cc
DRD L6 heads
A-1 Sidewinder |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2829 Location: West Palm Beach, FL
damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Wed Jul 21, 2010 6:57 am Post subject: |
So did I but the ad is misleading.
It's not welded and balanced, they get them from VW which are already balanced and they just weld them up. They do not balance then after they have been welded.
How do I know? I asked them and what they said was "We don't add any metal to the fans".
I think mine needs to be checked. _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Wed Jul 21, 2010 7:22 am Post subject: |
Sigurd wrote: |
Is it possible to have a balanced fan that still has some wobble to it? |
Sure. Just like a tire and rim may have runout, yet be balanced. _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
MAYHEM Samba Member
Posted: Wed Jul 21, 2010 7:28 am Post subject: |
damicotile wrote: |
I think mine needs to be checked. |
No kidding?
Mine spins smoother than the other, non welded, I had. The non welded did not explode, but the center hole stripped right out. Perfectly round. Always replace the fan adapter when replacing the fan. _________________ Greg
Model Citizen
johnnypan wrote: |
74 Thing Samba Member
Posted: Wed Jul 21, 2010 7:33 am Post subject: |
I think most shops do that-they just tig it with out adding filler rod and do not re-balance. The only place I know that re-balances is Berg. Ask before you buy to make sure if thats what you are looking for. |
Posted: Wed Jul 21, 2010 9:24 am Post subject: |
MAYHEM wrote: |
Always replace the fan adapter when replacing the fan. |
You mean the fan hub?
Where do you get that? Do you use OEM? or aftermarket?
I somehow think an old german fan hub is better that any new one, but some vendors are beadblasting old stuff.
Won't that remove some material and make the fit less tight between the fan and hub? _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
MAYHEM Samba Member
Posted: Wed Jul 21, 2010 9:44 am Post subject: |
don.ville wrote: |
MAYHEM wrote: |
Won't that remove some material and make the fit less tight between the fan and hub? |
I bought it brand new and new shims from Kustom1 when I got the fan.
Good tight fit. _________________ Greg
Model Citizen
johnnypan wrote: |
68Bug-lite Samba Member
Joined: July 31, 2005 Posts: 1087 Location: Tustin, CA
Posted: Thu Jul 22, 2010 5:54 am Post subject: |
X2 on Berg. Awesome welds.
They shave metal from on the edges so they spin true. |
tezer71 Samba Member
Joined: February 07, 2009 Posts: 126 Location: norway
torsionbar Samba Member
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Mar 29, 2011 9:46 am Post subject: |
I use these on 2 of my performance motors and a 3rd in another complete 2165 engine parts kit. Despite in the ad not showing the grinding on the edges, all three came to me with them.
http://www.thesamba.com/vw/classifieds/detail.php?id=694422 _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1300 Location: North Carolina
Posted: Tue Mar 29, 2011 5:48 pm Post subject: |
I purchased one from CarCraft due to price.......came in a empi package. The blades looked like they were brazed & every other one at that. I cannot shim it enough where it's not rubbing something.
Well be ordering a berg. |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Tue Mar 29, 2011 7:14 pm Post subject: |
Does anyone offer a welded non-doghouse fan? The narrow fan? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
hoghead Samba Member
Posted: Wed Mar 30, 2011 8:12 am Post subject: |
At what speed does the stock fan stall?
Are there fans that cool to 5800 engine RPM?
Can short bursts over the fan stall speed as experienced by running through the gears on a street car be tolerated without overheating?
Is the stock fan safe to 5800 - 6000? |
77charger Samba Member
Posted: Wed Mar 30, 2011 8:33 am Post subject: |
I also got mine from jason eggum been happy with it and good quality.
I saw he has some in the classifieds again too. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Csaba Samba Member
Posted: Wed Mar 30, 2011 10:16 am Post subject: |
junior55 wrote: |
I not impressed with the weldeds that I have seen either...
Most of the welded fans that I have looked at have the little tabs that protruded through the side plates, burned down FLAT leaving a butt weld.
Now relying strictly on the somewhat carbonized welds to hold everything and not the mechanical interlocking of the metal.
All it takes is one bad weld and its all gone.
A somewhat carbonized weld? What on earth are you talking about? You really think that a twisted tab past a slot is a better mechanical connection than a tig weld? Especially with the forces on the fan at speed? Back to school my friend
I would think that some precision brazing would be better because of the
lower heat and a non-destructive flow AROUND the crimped structure
to be much stronger.
You are probably right. And if you did the work yourself if you had the skills, then sent it off for balancing, it might survive at the 7000 or so rpm where the fan cavitates and is no longer effective.
Welded fans are scarry looking to me personally and I have just relied on
the "loose belt slip" to keep the revs from getting to the destruction point.
There is nothing to be gained by a fan that CAN spin at 10 grand anyway. |
I think the point of this was that a cheap welded fan is no better than a non-welded fan, and that a properly welded and balanced fan would allow you to rev without fear of destruction. |
Posted: Wed Mar 30, 2011 10:40 am Post subject: |
Csaba wrote: |
Back to school my friend |
Csaba wrote: |
fans do not cavitate. cavitation only occurs in liquids. back to school for you my friend. |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Wed Mar 30, 2011 11:14 am Post subject: |
Every nub is not suppose to be welded. Every other one should be, to allow some flexing. And yes air will cavitate _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Csaba Samba Member
Posted: Wed Mar 30, 2011 11:25 am Post subject: |
torsionbar wrote: |
Csaba wrote: |
Csaba wrote: |
Well that's news...I guess we should inform all of the jet engine design engineers that their calculations are all wrong, and that thrust models are not limited to airspeed through the compressor stage... I am sure they will be knocking on your door to consult. |
