Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Apr 18, 2013 9:00 pm Post subject: |
tclark wrote: |
Can we figure out what vehicle, those are off did you note any markings number on those, its such hassle to order from europia
They do seem to be taller so much easier to adjust the spray patten |
I thought you posted a couple of years ago that they were Smart car nozzles? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
madspaniard Samba Member
Posted: Thu Apr 18, 2013 9:48 pm Post subject: |
Jake de Villiers wrote: |
tclark wrote: |
I thought you posted a couple of years ago that they were Smart car nozzles? |
The 3-way nozzles are Smart car, the 2-way nozzles we were just talking about are from German websites. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Sun Apr 21, 2013 7:45 pm Post subject: |
kuleinc wrote: |
Anyone know where to get body gaskets for real Vw three way nozzles? |
What real VW 3 way nozzles? The only ones that i am aware of came off of a smart car and they didn't come with body seals. |
Posted: Sun Apr 21, 2013 9:10 pm Post subject: |
kuleinc wrote: |
Wonder what they are then... |
Smart car as far as I know. Got a pic? |
Posted: Sun Apr 21, 2013 9:33 pm Post subject: |
Look like this?
Posted: Sun Apr 21, 2013 9:53 pm Post subject: |
That image is from page 2. They are smart car nozzles.
The part numbers were important if they came off of a VW since the first 3 numbers show the body type and they could be used to track them down for other members. |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Sun Apr 21, 2013 11:13 pm Post subject: |
I have a 2001 subaru forester and the rear window nozzle looks like it could stick out far enough to work. It is a double nozzle. Has anyone explored using one of those? |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Mon Apr 22, 2013 7:30 am Post subject: |
Mundopacheco wrote: |
10C, that's a bang up idea, but I don't see why you couldnt install the check valve close to the pump discharge, where it would be an easier task and the check would work even better, as the seal would be assisted by the added weight. |
I ordered part 914-628-215-00-M78 from pelicanparts.com.
I put it just down stream from the pump.
It certainly improved things, but there is still a lag.
I'm thinking a second valve down stream (closer to the nozzles) might help.
I suppose there is a risk that the additional resistance from the check-valves could reduce the stream.
But, I did not notice an reduction in flow with the one valve close to the pump. _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Mon Apr 22, 2013 7:39 am Post subject: |
It sounds like something else is going on. If that check just downstream of the pump is holding, you are wasting your time adding another check. I would look at the pump, pump suction, etc. |
Posted: Mon Apr 22, 2013 7:59 am Post subject: |
It is essentially working. The lag (formerly a few swipes of the arm) is now just a swipe, or less. Overall pleased with the result actually. The longer it has been since the fluid was activated, the longer the lag with re-activation. So I suspect the check valve is not 100%, or that it is not intended to hold back a long column of fluid (original application, in the smaller Porsche 914, did not likely have so much elevation gain after the valve).
Anyhow... mostly posted the info as I think the valve works pretty well, was cheap, and wanted to put an actual part number out there for anyone searching.
d _________________ ----------------------------------------------------
Posted: Mon Apr 22, 2013 2:03 pm Post subject: |
Well, a check valve is designed to minimize backflow. I don't think any manufacturers claim that theirs will eliminate backflow 100%. The weight of the water on the downstream side being higher than the upstream side should give better results. I have a Westy with the triple nozzle and a Syncro with the single.....neither has a check valve in there, that I know of. Anyway, I'm curious to see if I have a similar lag....will post again later. |
randywebb Samba Member
Posted: Mon Apr 22, 2013 2:13 pm Post subject: |
so... we now have the question: where is the optimal place to install a check valve? _________________ 1986 2.1L Westy 2wd Auto Trans. |
jwatches Samba Member
Joined: September 02, 2015 Posts: 16 Location: Seattle
Posted: Fri Nov 27, 2020 1:13 pm Post subject: Re: 3-way windshield washer nozzles old topic any New Ideas ?? |
Wanted to refresh this thread. I just replaced my nozzles with three-way nozzles from T3. I’ve purchased other things from T3 and have always been happy with their products. The new nozzles are a perfect fit and work well.
http://www.t3technique.com/ |
Franklinstower Samba Member
Posted: Fri Nov 27, 2020 2:03 pm Post subject: Re: 3-way windshield washer nozzles old topic any New Ideas ?? |
Fyi,
The suzuki swift sx4 washer nozzles are a direct fit 3 way nozzle.
https://www.thesamba.com/vw/forum/viewtopic.php?t=692425 _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
