jspbtown Samba Member
Posted: Thu Jan 07, 2010 5:19 pm Post subject: CNC master cylinder rebuild |
I have 3 CNC 3/4" square reservoir master cylinders that need to be rebuilt.
I have the kits but want to make sure I do it right.
Does anyone know where I can find an exploded diagram? |
DirtGhost Samba Member
Joined: September 19, 2007 Posts: 547 Location: Greensboro,NC
Posted: Mon Jan 11, 2010 10:34 am Post subject: |
As you take it apart lay it out in a line . replace the parts you need to replace . put back together. _________________ Orange Boxx Design and Fabrication |
busk Samba Member
Joined: September 29, 2008 Posts: 160 Location: Brea, CA
Posted: Mon Jan 11, 2010 9:14 pm Post subject: |
its actually pretty simple just do one at a time and there really is not very many parts to replace |
Posted: Tue Jan 12, 2010 10:53 am Post subject: |
That would be perfect if I had not already dis-assembled all three and cleaned them all in prep for the rebuild. |
shred625 Samba Member
Joined: October 10, 2007 Posts: 1328 Location: Huntington Beach Ca
Posted: Tue Jan 12, 2010 1:14 pm Post subject: |
jspbtown wrote: |
That deserves a Darwin award! _________________ “It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey |
Posted: Tue Jan 12, 2010 1:19 pm Post subject: |
shred625 wrote: |
jspbtown wrote: |
That deserves a Darwin award! |
That is not really nice. He could be new to all this. _________________ Orange Boxx Design and Fabrication |
Posted: Tue Jan 12, 2010 1:44 pm Post subject: |
DirtGhost wrote: |
shred625 wrote: |
jspbtown wrote: |
That is not really nice. He could be new to all this. |
Its all in fun......... we have all done it! _________________ “It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey |
olmer2 Samba Member
Joined: June 28, 2009 Posts: 781 Location: chattanooga TN
Posted: Tue Jan 12, 2010 9:35 pm Post subject: |
shred625 wrote: |
DirtGhost wrote: |
shred625 wrote: |
jspbtown wrote: |
Its all in fun......... we have all done it! |
X2 on the award! I got my first award (of many) when I disassembled the drums all the way around on the farm tractor. Yup, you guessed it, no book.
I'll go out tomorrow and dissasmble mind for you and take pics. (I need to rebuild mine badly, I just need to find a rebuild kit). The CNC is a little different from the diagram posted. If you have any questions feel free to shoot me note. |
ZARJDR Samba Member
Joined: October 27, 2008 Posts: 1039 Location: Eureka, Ca
Posted: Tue Jan 12, 2010 10:51 pm Post subject: |
The only thing I have encountered with them is that the brake piston can be different from the piston for the clutch. It may have an extra little plastic cup with a seal at the very end(pressure side). They are specific as to the way the cup and seal orient, the rest is pretty straight forward. _________________ 2006 RAM 1500 HEMI 4X4 92 LT250
06 Raptor DP1776 Sandrail
02 HONDA 400EX
03 YAMAHA WR450F 74 BAJA |
Posted: Wed Jan 13, 2010 6:39 am Post subject: |
I agree....not the smartest move...but I did do one thing correctly. When I removed the first I kept it all in order and taped it together so I do have a "template" to go by. I just thought that since they sell rebuild kits they would have diagrams readily available.
All three were in really bad shape. They had been left outside and ignored for years. The brake fluid inside was like a firm, crumbled jello. The screws on the easy fill caps were rotted. The caps were corroded and stuck. They were a mess. I have cleaned them, done some paint to detail them, and honed the cylinders. |
j1mmy420 Samba Member
Joined: January 14, 2016 Posts: 1 Location: Victorville
Posted: Thu Jan 28, 2016 8:39 pm Post subject: Re: CNC master cylinder rebuild |
does this look right?
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Thu Jan 28, 2016 8:48 pm Post subject: |
jspbtown wrote: |
The brake fluid inside was like a firm, crumbled jello. |
You might want to look inside the wheel cylinders too then. Sounds like mis-matched brake fluid.
Flush the whole system very well. |
