coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Wed Jan 13, 2010 8:07 pm Post subject: |
sventinker wrote: |
Quote: |
It looks similar to the size of the VOLKSWAGEN emblem on later Buses but I believe that has 4 prongs. |
see that's the kind of stuff I'm looking for I didn't know that emblem had four prongs. like I said above I will measure the holes when I can but as it is surely a dealership logo I can assume there all going to be different so matching one up will be difficult . Thanks again for the input |
Is the rear script on a SC or DC the same, with 4 prongs? My SC has been painted sometime in the last 20 years or so and I only see two holes above the decklid. Do I need to start chipping the paint off to find the other two holes? _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19670 Location: Land of Whine and Phonies
Posted: Tue Jan 19, 2010 8:43 am Post subject: |
Busryder wrote: |
Found in the 68-79 Camper section of the Gallery:
And this was found in the 55-67 Bus-Deluxe section:
So this is Baywindow?
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Tue Jan 19, 2010 9:28 am Post subject: |
crofty wrote: |
Busryder wrote: |
That's your call man... all I know is that you can't just go run out and swap that one out for a different one, purposefully gapped or not .
This makes me think of the other thread;http://www.thesamba.com/vw/forum/viewtopic.php?t=394850 those damn Baywindow snobs, they think they're so hard. Freakin' VOLKSWAGEN Gangsters. _________________
Lind wrote: |
Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
galexander Samba Member
Joined: April 17, 2003 Posts: 522 Location: Round Rock, TX
Posted: Mon Apr 05, 2010 9:28 am Post subject: |
Working on my son's '63 SC rebuild, and was wondering how does the script actually attach to the hinge plate? The VOLKSWAGEN script I have has 4 studs and there are 4 holes in the hinge plate, but there is no back access to put clips on like the front VW emblem.
Was there some sort of insert that goes into the holes?
thanks _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7442 Location: Hablamos Ingles, So. Cal.
Posted: Mon Apr 05, 2010 11:01 am Post subject: |
galexander wrote: |
thanks |
It IS held on by 4 minute clips pushed onto those studs, from the backside. It's tight, but there is access from the back... (or at least there is supposed to be). If not, someones been in there messin' things up. I have a '63. |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Sun Aug 28, 2016 3:17 pm Post subject: Re: Rear script |
quick question...
does any one make a repro 1500 emblem? google is not being kind to me. _________________ 1954 L227 Type 113
1964 L31 Type 265 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 28, 2016 5:41 pm Post subject: Re: Rear script |
pig-pen wrote: |
quick question...
does any one make a repro 1500 emblem? google is not being kind to me. |
Not so far. We have some NOS 1600 scripts left. _________________ In Stereo, Where Available! |
Troytempest69 Samba Member
Posted: Sun Feb 07, 2021 12:33 pm Post subject: Re: Rear script |
Has anyone tried using the Porsche 356 1500 or 1600 badges? Assuming they’re the same size (not got any dimensions) it looks like the number ‘1’ is the main visible difference. Looks like the Porsche badges come in gold, chrome and 1500 or 1600 versions. |
djholland Samba Member
Joined: July 02, 2007 Posts: 21 Location: Toronto, Canada
Posted: Sun Jun 13, 2021 9:40 am Post subject: Re: Rear script |
How have people actually pushed the clips onto the studs on the rear of the "VOLKSWAGEN". I can get my finger in and touch the stud but cannot get the clip on. The studs are about 1.5 inches in and the hole is not much bigger than the diameter of my finger. I tried taping the clip to the end of my finger as well as a small socket with masking tape. No luck so far. _________________ 57 Beetle, 65 Doublecab, 75 Scirocco, 15 A4 |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 356 Location: Mississippi
Posted: Sun Jun 13, 2021 2:21 pm Post subject: Re: Rear script |
djholland wrote: |
How have people actually pushed the clips onto the studs on the rear of the "VOLKSWAGEN". I can get my finger in and touch the stud but cannot get the clip on. The studs are about 1.5 inches in and the hole is not much bigger than the diameter of my finger. I tried taping the clip to the end of my finger as well as a small socket with masking tape. No luck so far. |
How about....... take a paint stirring stick, drill a hole through the stick near the end of it that is slightly larger than the diameter of the stud, add just a dab of gasket maker silicone/sticky stuff to the stick at the hole to temporarily hold the clip to the stick, then insert the stick with the clip into place and either push or lever with the stick to push the clip on the stud.
Or.....and I kind of like this one better......find a new unused pop rivet that is slightly less than the diameter of clip/stud, tie a piece of fishing line to the head of the pop rivet and another piece of fishing line to the base of the rivet, slip the clip over the line tied to the head of the rivet, slide the clip down to the base of the rivet, add a dab of sticky stuff to the clip, fish the line tied to the head of the rivet in through the decklid from the back side, pull the line and the rivet through the hole in the decklid thus aligning the clip with the hole, then use the other end of the line tied to the base of the rivet to pull the rivet back through the hole leaving the clip stuck to the backside of the decklid. Now put your finger on the clip and push the stud through and into position on the clip. |
Posted: Mon Jun 14, 2021 7:17 am Post subject: Re: Rear script |
BonTonRoulet wrote: |
djholland wrote: |
Thanks BonTonRoulet
Your first suggestion is similar to what I tried (except for the drilling a hole in my finger part). I think masking tape wasn't a good enough sticky substance, so I may try this again (maybe with a dowel with a hole drilled in it).
I like your second suggestion. I'll try this later this week when I get a chance. _________________ 57 Beetle, 65 Doublecab, 75 Scirocco, 15 A4 |
