Bruce MacDonald Samba Member
Joined: March 03, 2004 Posts: 193 Location: Markham, Ontario, Canada
Posted: Wed Jan 13, 2010 5:11 pm Post subject: 54 Oval Tar Boards |
I will probably need to pull the engine this spring to free up or install a new throttle cable which keeps sticking on the highway on a hot day (yes it does get hot in Canada in the summer ) If so I plan on replacing the original tar boards which are getting pretty bad. The ones that cip carries
https://www.cip1.ca/ProductDetails.asp?ProductCode=C24%2D111%2D898%2D805
are listed as 56-77. Is there much difference in a 54? Maybe just the routing of the wires? Anybody else carry them? I checked WW but didn't see them. Thanks for any help. _________________ Stop worrying about how much your car will be worth when you are dead and build it to make you happy! |
aa390392 Samba Member
Posted: Wed Jan 13, 2010 5:38 pm Post subject: |
johnhenry has an excellant page on how to make your own out of 30lb roofing paper..all it cost is a lil time and a lil mat'l
its all on page 17 in the bugshop 57 restro. check it out |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Wed Jan 13, 2010 8:21 pm Post subject: |
Ivan Fuller Samba Member
Joined: September 21, 2005 Posts: 149 Location: New Zealand
Posted: Thu Jan 14, 2010 1:02 am Post subject: |
My unmolested Jan '54 has it on the sides, ie 3 pieces in the eng bay, as did a clients mid '54. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9403 Location: Northwood, NH USA
Posted: Thu Jan 14, 2010 8:05 am Post subject: |
aa390392 wrote: |
If you can find rolled roofing of similar thickness that does not have mineral applied to one side ("gravel") that is best. I have a roll of something close in my basement (Bitumen I think). The felt paper thing has held up well and looks great, but you'll need a lot of glue... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jan 14, 2010 6:45 pm Post subject: |
Thanks for the suggestions. BTW mine left the factory on April 9, 1954 (so was being built on April 8 which was coincidentally my 5th birthday) and still had the original boards on back and sides when I bought it. _________________ Stop worrying about how much your car will be worth when you are dead and build it to make you happy! |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Thu Jan 14, 2010 8:01 pm Post subject: |
I actually really like the Wolfsburg West ones.... they are paper in front of tarboard and look very clean when installed. The cheap ones always have this terrible waffle pattern on them (and not the CORRECT early waffle pattern). Here is my April '55 with the WW kit installed.
_________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117 |
cvallone Samba Member
Joined: May 13, 2007 Posts: 875 Location: Congers New York
Posted: Thu Jan 14, 2010 8:14 pm Post subject: |
Careful buying the cip1 tarboard. Past couple times I bought it (german) the material just cracked. Bugcity in CT has a good tarboard for around the same price and does not crack. Nice and thick, and soft enough to get the spikes through.
cv _________________ My restos www.classicvwbugs.com
Restoring Beetles back to their historical beauty. |
Posted: Sat Jan 16, 2010 10:58 am Post subject: |
52HoffmanSplit,
Thanks, I had searced for 'tar boards' on WW's site but couldn't find them so after reading your post I dug out their paper catalogue, tried again and found them under 'sound absorber kit', #111813805, in case anybody else is looking. They do indeed look clean and smooth. I love this forum so much, so many knowledgeable, helpful people. Thanks all!  _________________ Stop worrying about how much your car will be worth when you are dead and build it to make you happy! |
piet&som Samba Member
Joined: February 18, 2009 Posts: 258 Location: Toxandria
Posted: Tue Jan 19, 2010 9:50 am Post subject: |
Also before you install the tarboard don't forget to glue the hairy strips to the firewall. At least that's what they did in Wolfsburg.
Salut |
beetleman217 Samba Member
Posted: Sat Jul 06, 2013 11:23 am Post subject: |
Thought I'd ask here instead of opening a new thread. I just got the WW ENGINE SOUND ABSORBER KIT but it is not a direct fit. Must I cut it to fit? Or just bend it badly? It's a shame to ruin this nice brand new set. How do I go about installing it? |
D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Sat Jul 06, 2013 12:30 pm Post subject: |
Do you have your old stuff to use as a pattern? |
Posted: Sat Jul 06, 2013 1:09 pm Post subject: |
D. Haviland wrote: |
No, but the WW mats are sort of cut to shape. It's just not a direct fit - they are bigger than the areas to cover. Here's the link where you can see their shape
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111813805 |
stanovich Samba Member
Joined: March 18, 2013 Posts: 191 Location: central coast calif
Posted: Sat Jul 06, 2013 9:36 pm Post subject: |
glue? why dont you just heat it with a propane torch and press it togeather like a roofer would do |
vw57drvr Samba Member
Joined: October 23, 2005 Posts: 1705 Location: Rome, Ga
Posted: Mon Jul 08, 2013 11:30 am Post subject: |
I have put new ones in two different cars and havent had to cut anything to fit. Maybe just the WW ones are that way? _________________ 60 Rock Grey Vert |
Posted: Sun Aug 04, 2013 7:29 pm Post subject: |
Well in the end I had to be a little creative and cut a piece off the side parts. It then fit wonderfully
Posted: Mon Aug 05, 2013 7:06 am Post subject: |
I dont think those are installed correctly. The pointed side of the delta should be up toward the roof channel, and the cut off side matches the rear apron. Here is a video of one being installed. Skip to about 2:40 and you will see the side pieces being fit. I would correct this before you reinstall the engine:
http://www.youtube.com/watch?v=zrWNSbEErl8 _________________ 60 Rock Grey Vert |
Posted: Mon Aug 05, 2013 2:05 pm Post subject: |
darn I could have sworn I tried it that way too but it didn't fit. I guess it's just too hard for Wolfsburg West to mark these L and R to avoid confusion
vw57drvr where were you when I first asked on this thread...
any idea howto glue those pieces back on?
Last edited by beetleman217 on Mon Aug 05, 2013 2:28 pm; edited 2 times in total |
oneeyedducky Samba Member
Joined: May 04, 2012 Posts: 79 Location: SOUTHERN CALIFORNIA
Posted: Mon Aug 05, 2013 2:12 pm Post subject: |
The wiring harness runs BEHIND the tar board. You'll wanna fix this so the wiring doesn't get melted |
