Posted: Sat Feb 06, 2010 10:29 pm Post subject: |
Stuartzickefoose wrote: |
how would setting the timing help? i had bad throttle plate shafts, and a bad dizzy, and i dropped a screw down the intake. where does timing help??? |
Maybe you would have dropped one of the washers off the bottom of the dizzy drive instead and had a different reason to pull the motor.
Sorry to hear of your continuing problems. |
69rulz Samba Member
Joined: June 07, 2009 Posts: 867 Location: On a trip on my couch
Posted: Sat Feb 06, 2010 11:09 pm Post subject: |
kick the tire, it works on tv nah dude but i just picked a 72 camper for 200 bucks as a project and im 16, dam small world |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sat Mar 20, 2010 8:10 pm Post subject: |
UPDATE!
I searched around, found the effing screw. got it out. messed around a bit, got a new coil, fired it up. runs now, and can move up a hill slowly enough. and yes its running on all FOUR cylinders. my next step is to clean the carbs out really well. i got it to drive around the Hood and the longer i ran it the better it sounded. i need to change the oil and filters, and have to find the source of a small oil leak, and replace the valve cover seals, but what the hell, it runs finally!
OH! and while i was driving it for the first time ever, i got it to 20 and was in second, and the front left wheel started makin noise. pulled over, thinking the front suspension was effed, to find myself with a loose wheel! PHEW! fixed it and kept drive'n her.
and yeah, i learned my leson and my bus isnt worth 2500. right now im guessing its worth around 800 in parts.
any other suggestions?
Stuart _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Desertbusman Samba Member
Posted: Sat Mar 20, 2010 9:54 pm Post subject: |
Suggestions for what? _________________ 71 Superbug
71 Westy |
Posted: Sat Mar 20, 2010 10:21 pm Post subject: |
Like anything else i should check? its not a very strong engine. it barely hits 2 mph on my hill. like literaly, no power.
206-841-7324
[email protected] |
Posted: Tue Sep 16, 2014 11:44 pm Post subject: |
wow i cant believe how much of an idiot i used to be..... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
