stormforge Samba Member
Joined: May 05, 2009 Posts: 355 Location: Adirondacks NY
Posted: Sun Jan 17, 2010 8:33 am Post subject: Blue wire on alternator? |
Can someone give me a more detailed explanation of the light-gauge blue wire on the alternator? Previous threads and Bentley are a little confusing/unhelpful...
Is the blue wire only a connection for the warning light on the dash, or does it also provide excitation voltage for the field coil? What voltage should I see on the blue wire with:
A. Ignition off
B. Ignition on
C. Engine running
Thanks!
-Bill
'89 Syncro |
Posted: Sun Jan 17, 2010 9:36 am Post subject: |
The blue wire should have 12 volts going through it when the alternator is spinning and should provide a ground path when the alternator is not spinning. It feeds the alternator light and the oxygen sensor mileage counter. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sun Jan 17, 2010 11:36 am Post subject: |
Thanks Chris! I seem to have the strange low-rpm alternator bug that has been alluded to on several other threads:
1. Fire up the engine, alternator light is ON
2. Check voltage at alternator = 12v = no charge
3. Rev up engine briefly
4. Check voltage again -- 14V & charging fine
Seems to be good now even when RPMs drop back to a low idle...
Alternator is almost new
Battery is almost new and in good shape
Cleaned up my grounds recently
Alternator belt might be a little loose
Any idea what's happening here? I suppose the alternator belt might have been quietly and discretely (I was staring right at it) slipping and then it engaged more securely when I revved the engine... Or is this something amiss with the field coil supply or the voltage regulator? Is this scary, or something I shouldn't worry about?
Thanks!
-Bill
'89 Syncro |
Franklinstower Samba Member
Posted: Sun Jan 17, 2010 12:52 pm Post subject: |
loogy wrote: |
The blue wire should have 12 volts going through it when the alternator is spinning and should provide a ground path when the alternator is not spinning. It feeds the alternator light and the oxygen sensor mileage counter. |
And I believe it operates the relay under the drivers seat for a second battery. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
jptech Samba Member
Joined: March 23, 2009 Posts: 65 Location: Allentown PA
Posted: Sun Jan 17, 2010 4:17 pm Post subject: Alt blue wire |
The wire in European DIN terms is D+/61. It is the ground side of the dash charge indicator lamp. When the ignition is switched on, run bus power is supplied to one side of the lamp. the other side of the lamp is the blue D+/61 circuit that provides a ground thru the Alt brushes. This does two things. It completes the charge lamp circuit allowing it to light during KOEO and provides full voltage to the field rotor. When the engine starts, D+/61 is flooded with Alt output voltage. With 12V on both sides of the charge lamp, current cannot flow and the charge lamp goes out. The regulator takes control of the field rotor power & Alt output. If the Alt fails to produce power the blue D+/61 circuit remains a ground, current flows and the lamp remains on during KOER.
John |
Posted: Mon Jan 18, 2010 4:28 am Post subject: |
Thanks John -- that helps. When I was seeing no alternator power I measured about 2.5 volts on the blue wire. Any idea what that's telling me?
Cheers,
-Bill
'89 Syncro |
josh_w Samba Member
Joined: September 18, 2008 Posts: 68 Location: Columbus, Ohio
Posted: Mon Jan 18, 2010 9:11 am Post subject: |
I'd heard the blue wire was an anti-theft bit- if you hotwire the car instead of turning the ignition switch, the blue wire doesn't get connected, the alternator won't charge the battery, and eventually you'll be walking.
Anybody else heard this? |
tencentlife Samba Member
Posted: Mon Jan 18, 2010 10:52 am Post subject: |
josh_w wrote: |
That's pretty far out. Theft prevention features show up on some new cars nowadays, but back when these were built it was barely on OEMs' radar at all. We got steering locks somewhere in the 60's, Saab with their floor-mounted ignition switches made their trannies lock in reverse, but other than that provisions for antitheft were practically unheard-of.
No, as already explained the D+ wire is the field excitement circuit, it's been standard practice on vehicle alternators and generators ever since they were installed in cars. Sometimes an alternator will self-excite the field windings without it, but the D+ wire is there to guarantee that the field windings juice up so charging begins every time. Without it, it is hit or miss. It also conveniently allows for a reliable way to tell if the alternator is not charging because if the alternator stops producing current or the regulator fails the field winding will begin using current, which has to flow thru the warning bulb, so it glows.
Nope, antitheft is pretty fancy stuff; these are very basic vehicles. But the newest cars even with built-in security systems still use this same system to induce charging, and warn if it fails. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
jptech Samba Member
Posted: Tue Jan 19, 2010 12:29 am Post subject: Alternator "Blues" |
Hi Bill,
Its pretty much all or nothing; KOEO - D+/61 = ~0 volts & KOER it = B+ volts. You may be seeing AC leakage due to diode damage. Switch your voltmeter from DC to AC and check the big red B+ & small blue D+ terminals to ground KOER. There should be NO AC voltage. (< 0.2 VAC)
John |
n2wheelies Samba Member
Joined: May 31, 2006 Posts: 65 Location: newport beach, ca
Posted: Thu May 19, 2022 6:52 pm Post subject: Re: Blue wire on alternator? |
thanks guys for a great post.. started here, followed the steps and in the end one of the brushes barely touched the commutator anymore.. problem solved.. ordered a regulator for $60 off ebay today and even made a video... you guys rock! _________________ '87 Vanagon Weekender 'ELNINYO'
past vw's...
'09 EOS 'petal'
'78 scirocco
'66 T2 panel dead tour vehicle, 'mr bus'
'67 13 window
'95 eurocamper 'charlie' (phish tour vehicle)
'03 Mk4 TDI 'steve'
'04 W8 Phaeton 'david' |
jlrftype7 Samba Member
Posted: Thu May 19, 2022 7:44 pm Post subject: Re: Blue wire on alternator? |
n2wheelies wrote: |
thanks guys for a great post.. started here, followed the steps and in the end one of the brushes barely touched the commutator anymore.. problem solved.. ordered a regulator for $60 off ebay today and even made a video... you guys rock! |
. Been there,,,
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Fri May 20, 2022 7:23 am Post subject: Re: Blue wire on alternator? |
Most every alternator I know of if you rev the engine high enough [4k] the alternator will start charging. No blue wire needed.
I've personally had this problem but was too busy/lazy to fix it. Drove the car for weeks before I handled it.
If the alt light does glow, it's because the voltage is not the same across the bulb. Simple voltage drop test will determine where the voltage loss is.
Alternators have been around for a while and circuit 61 was not meant for theft. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Fri May 20, 2022 7:50 am Post subject: Re: Blue wire on alternator? |
In VW boxer engines as well as many VW inline engines the alternator warning light also acts as an impending engine damage early warning light.
The pulley(s) and belt(s) that spin the alternator also spin the coolant pump.
Whatever causes the alternator light to come on may also mean the coolant pump isn't turning.
The driver should immediately check the belt(s) if the alternator light comes on when it shouldn't, to verify whether or not the coolant pump is affected.
Mark |
Posted: Sat May 21, 2022 5:09 am Post subject: Re: Blue wire on alternator? |
Butcher wrote: |
What changes all of this is no more Exciter Circuit as you have known it for decades . Now you have a single wire still going to the Alternator, but it’s a Lin Bus communication wire from a module to the Alternator, which complicates diagnosing charging problems since other modules weigh in with charging system requests to the main module talking to the Alternator.
Long live the single exciter wire system!!!….the modern stuff is no fun to diagnose.. I feel like it’s Charging by Committee these days versus Exciter, output wire and ground in the old days _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sat May 21, 2022 3:17 pm Post subject: Re: Blue wire on alternator? |
stormforge wrote: |
Can someone give me a more detailed explanation of the light-gauge blue wire on the alternator? |
yes. you ALWAYS cut the BLUE wire. wait! no, RED wire.
sorry, it had to be said. _________________ -dan
www.thefixitworkshop.com |
Posted: Sat May 21, 2022 4:51 pm Post subject: Re: Blue wire on alternator? |
DanHoug wrote: |
stormforge wrote: |
sorry, it had to be said. |
LOL _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
