J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Thu Oct 20, 2016 9:57 am Post subject: Re: New Hightop Option |
Latest NAHT to hit the road. This conversion by Tim H. This is his second hightop conversion,the first was an AW top, this time an NAHT.
Nice job of the bulkhead and interior.
Apparently there were 6 NAHT's and 3 AW's at Descend on Bend last weekend - all staying warm and dry in some nasty weather.
[/img] _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
livethevanlife Samba Member
Joined: May 18, 2015 Posts: 204 Location: La Paz, Baja California Sur
Posted: Thu Oct 20, 2016 9:29 pm Post subject: Re: New Hightop Option |
jimf909 Samba Member
Posted: Thu Nov 03, 2016 11:03 pm Post subject: Re: New Hightop Option |
Pop-top...
...to no-top
... to (be continued) _________________ - Jim
Abscate wrote: |
larss Samba Member
Posted: Tue Nov 08, 2016 4:04 pm Post subject: Re: New Hightop Option |
Hi.
Does anyone know what type of roof is that? Preowner said that this was built in France but I cannot find any info and photos of that.
Posted: Thu Nov 10, 2016 8:11 am Post subject: Re: New Hightop Option |
The Fall 2016 run ofNAHT tops is now underway. Unseasonably humid late summer/ early fall weather and dialing in some new equipment delayed the start of the run but it is now in "full swing"
Some pics of the first top of the run
kernewek Samba Member
Joined: December 09, 2012 Posts: 44 Location: France/UK
Posted: Thu Nov 10, 2016 1:07 pm Post subject: Re: New Hightop Option |
larss wrote: |
Hi.
It could be a Font Vendome roof? You would probably more information at t3zone.fr
Craig _________________ 1998 T4 2.5 TDI with Timber Technicians high top
1985 T3 1.6TD hightop camper |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Thu Nov 10, 2016 1:43 pm Post subject: Re: New Hightop Option |
Welp... the point of no return
Kevin giving Krusty a haircut... basic cut, runners and install. Will have windows and a Fan-Tastic power vent.
I will have a slightly smaller opening, with a bigger storage area over the drivers compartment... due to my overhead/front AC system... getting happy feels now
_________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Posted: Thu Nov 10, 2016 7:15 pm Post subject: Re: New Hightop Option |
Before gluing... hopefully this weekend I can do the insulation. Happy camper... literally
Better pictures later... will update my Krusty thread _________________ Don't harsh my mellow...
1967 Bug- Gone
Posted: Thu Nov 10, 2016 11:25 pm Post subject: Re: New Hightop Option |
Wack-a-Mole time
[/b] _________________ Don't harsh my mellow...
1967 Bug- Gone
tates1882 Samba Member
Joined: August 07, 2012 Posts: 275 Location: Southwest Idaho
Posted: Fri Nov 11, 2016 7:38 am Post subject: Re: New Hightop Option |
TequilaSunSet wrote: |
Better pictures later... will update my Krusty thread |
looking good _________________ 88 Vanaru, ej22, naht |
Posted: Fri Nov 11, 2016 8:47 am Post subject: Re: New Hightop Option |
[/URL]
Neato! Looking forward to seeing more!
Krusty thread for reference...
http://www.thesamba.com/vw/forum/viewtopic.php?p=8203376 _________________ - Jim
Abscate wrote: |
Posted: Fri Nov 11, 2016 3:17 pm Post subject: Re: New Hightop Option |
Wack-a-Mole time
[/b] |
Before you start installing insulation - I'm assuming that you're going to use contact cement - wire up your vent, even on a temporary basis and get it running. Otherwise you're going to have a truly mind altering experience putting the insulation in - likewise for the finish material _________________ NAHT hightop availability May 18 2023 -
thasty07 Samba Member
Posted: Mon Nov 21, 2016 12:30 pm Post subject: Re: New Hightop Option |
Im curious what size solar panel people are running on the back luggage rack. Im not near the van right now to measure, otherwise I would measure but I have seen several that look like they fit pretty well. |
Posted: Mon Nov 21, 2016 1:36 pm Post subject: Re: New Hightop Option |
The measurements of that flat part at the rear of the NAHT are:
Side to side 35" rear to front 24"
I've seen some 85w panels that fit nicely.
J _________________ NAHT hightop availability May 18 2023 -
Posted: Mon Nov 21, 2016 2:46 pm Post subject: Re: New Hightop Option |
Im leaning away from adding the panel to the top of my naht. Right now we are using a 48w portable system that should extend our aux battery by about two days. Giving us 4-5 days between recharges. having the panel attached limits being able to get max sun exposure unless you reposition the van. Just my 2 cents. _________________ 88 Vanaru, ej22, naht |
Posted: Mon Nov 21, 2016 4:30 pm Post subject: Re: New Hightop Option |
tates1882 wrote: |
Im leaning away from adding the panel to the top of my naht. Right now we are using a 48w portable system that should extend our aux battery by about two days. Giving us 4-5 days between recharges. having the panel attached limits being able to get max sun exposure unless you reposition the van. Just my 2 cents. |
A panel sitting in the van collects no power |
Posted: Mon Nov 21, 2016 6:48 pm Post subject: Re: New Hightop Option |
I like the idea of having a about a 100w flexible solar panel because of its size and light weight. Here's how I'd deploy it. First I'd simply stow it flat in the rear storage area of the hightop. Then, on arrival for camping, park the van facing East. In the evening, drape the flexible solar panel over the windshield of the van. As soon as the sun rises, it will begin to produce current. Later on - eg. mid morning, move the panel - maybe drape it from the window of the hightop onto your awning - as its now facing South and because it isn't at a horizontal orientation it will be producing current at a higher rate than a similar panel in a "flat" position. Later in the day, move the panel to the South West corner of the van.
Because the panel is lightweight, moving it isn't onerous and it wouldn't take long for anyone to sort out quick and easy ways to hang the panel.
All solar panels are rated for their output when in direct sunlight - that means the sun's rays are hitting the panel at a 90deg angle. Any deviation of that "direct" orientation means a reduction in available energy to the panel of about 1.1% per degree of deviation of the sun from zenith
Eg a 100w panel mounted flat on a van at the equator, at noon on Sept 22 will have the sun at 90deg to the panel and will be producing maximum power. However, one hour later the sun has moved 15deg from its zenith and the output of the panel will now max out at 100 - 15X 1.1 or 83.5% of 100 watts
Point is, the more you can have your panel oriented as close as possible to having the sun's rays strike it at 90deg. the closer your panel will be to having an output close to the rating of your panel.
Ain't physics Phun ?? _________________ NAHT hightop availability May 18 2023 -
chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Mon Nov 21, 2016 8:33 pm Post subject: Re: New Hightop Option |
our solar system was installed by norcal NAHT installer kevin, and he fitted an 85w panel in the spot in back that is the perfect size. but then he couldn't find the source for the panel again. so below is a shot of the sticker on the back, might be useful if you're trying to find this panel.
my take, with this panel installed, is that your best option is both the mounted and a detachable, unmounted panel. the 85w isn't enough to keep up with multiple days while camping, but it does keep the battery charged and deals well with a day's worth of use. i'm just gonna mount a socket on the side, switch to an MPPT controller and get a flexi 100w to supplement. won't have to find a place to mount it and it can be moved to follow the little amount of sun we get up here.
_________________ '74 transporter panel
'91 vanagon carat NAHT |
TheArmand Samba Member
Joined: May 11, 2016 Posts: 92 Location: Santa Monica
Posted: Mon Nov 21, 2016 10:04 pm Post subject: Re: New Hightop Option |
I've spent hours trying to find the max wattage solar panel that will fit on the back 'luggage rack' on the NAHT, this is the best I can find. The 80W 12v BACK contact version on this auction. 34.6" x 21.3". The sizing is right, but there are no grommets built in to conveniently mount it in a removable frame, and the wiring/box is on the backside, avoiding a completely flush mount onto the NAHT. I'll probably weld/paint a simple steel frame which I'll sikaflex to the top, and figure out a way to secure the panel to that in some easily removeable way.
http://www.ebay.com/itm/401160433332?_trksid=p2060...EBIDX%3AIT
I must say, this is the only drawback I have been able to muster with my NAHT. To think of an adventurewagon/pop top's flat surface and the ability to put whatever solar array you wish, easily 200 watts at that, with inexpensive panels, is definitely something I am envious of.
Otherwise though, my NAHT has been an absolute joy. More info/pics to come with my build. |
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
