Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Mon Jan 18, 2010 5:45 pm Post subject: which lift? |
while i am hemorrhaging cash out of every orifice with the construction of our new house (and garage) i am in the market for a clear floor 2 post lift. i was thinking of one like this, i guess my real question is, how do they work out for a bus? all the lifts i have used in shops i have worked at have been the conventional style (non asymmetric) lifts, and i never had an issue putting my bus up on it.
so, any bus owners that have used a asymmetrical lift, what are your thoughts? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jan 18, 2010 6:03 pm Post subject: |
You will need more than standard 4" concrete where the hoist mounts.
A friend of mine was required to put 10" in under his 10K pound one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Mon Jan 18, 2010 6:29 pm Post subject: |
I went with 12" of concrete (4" of regular slab, plus 8" trough below slab all poured together), for my 2 post lift. My 2 posts are parralel, but the arms are unequal length (front are much shorter than the rear). Mine is made by a company called Forward. I was told it was a "lighter duty" version made by Rotary. When I purchased mine, the guy said "as long as you're only lifting 4-5 cars a day you'll be fine". So light duty is in the eye of the beholder.
For you, I would look long and hard at the max lift height before the safety engages. I used to have a Chevy Astro van and the safety would engage before the lift reached max height. As such, I couldn't really walk under it. So look for one that lets you go as high as possible since your bus is rather tall. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
Posted: Mon Jan 18, 2010 8:59 pm Post subject: |
Russ Wolfe wrote: |
A friend of mine was required to put 10" in under his 10K pound one. |
Florida_Buggy wrote: |
For you, I would look long and hard at the max lift height before the safety engages. I used to have a Chevy Astro van and the safety would engage before the lift reached max height. As such, I couldn't really walk under it. So look for one that lets you go as high as possible since your bus is rather tall. |
thanks for the input guys. i guess the concrete police are out, so here is what i am doing, by choice, not code:
8" floor, 6x6 wire mesh relief cut @ 1/2 way point (20 feet)
below grade will be 2 (one for each post mounting pad) 4'x4' 10" deep concrete pad with pre welded (by me, no less) rebar cage, giving me a grand total depth of 18" of concrete where the lift will be attached.
here is a pic of said garage, with 14' ceilings (well, ok, 13 3/4 finished)
now, has anyone put a bus on a asymmetrical lift? do the arms contact the frame ok? _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Jan 18, 2010 9:01 pm Post subject: |
Sorry, didn't mean to come off as the concrete police, just trying to help.
I was thinking after I posted, I did have a bay window pop-top camper on my lift (I parted it out, VERY rusty). I don't remember any issues with the arms. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
Twisted Minis Samba Member
Joined: December 24, 2007 Posts: 97 Location: Windsor, CA
Posted: Mon Jan 18, 2010 9:11 pm Post subject: |
I have an asymmetrical lift and have worked on a bus, it wasn't an issue lifting it up. You can bias it pretty far forward if you have to.
As far as what to get, I would look into a used Rotary. The prices on them are coming down and you can get one from $1200-1800 depending on the year it was made. They are some of the best lifts around, and parts are very easy to come by. Any bearing/hydraulic supply place will carry their stuff. _________________ If you can find it cheaper, I can fix it. |
Posted: Tue Jan 19, 2010 5:55 am Post subject: |
Sorry, didn't mean to come off as the concrete police, just trying to help. |
no problem. sorry if i came off like an ass. the last few days friends/family have said "if i were you" far too much. i have quite enough of the "if i were you" comments to last a lifetime. although there will be regrets with a build, i think i have planned quite well
Twisted Minis wrote: |
As far as what to get, I would look into a used Rotary. The prices on them are coming down and you can get one from $1200-1800 depending on the year it was made. They are some of the best lifts around, and parts are very easy to come by. Any bearing/hydraulic supply place will carry their stuff. |
i have looked into some other lifts. used are just that, well used and beat to hell. there is a guy local to me that refurb's them, but wants close to new in the price department and gives a 2 month warranty. i have not pulled the trigger on a lift yet, but for a car, i like the asymmetric style, makes getting in and out alot easier _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Jan 19, 2010 7:22 am Post subject: |
no worries.
Oh, consider doing the install yourself if you want to save some money. It took me and 3 friends less than a day working at a leisurely pace. And my friends aren't "mechanics" but if you tell them to do something they can follow directions. It really wasn't hard at all. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
Posted: Tue Jan 19, 2010 8:38 am Post subject: |
I did not mean to come off as a concrete police either. Just giving a heads up.
I did not re-enforce the floor in my shop, so I a limited as to the hoist choices.
I am seriously right now looking as a scissors type, because of my thinner floor.
I do not have the money to rip up the floor and redo it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
p horvath Samba Member
Joined: December 29, 2003 Posts: 1225 Location: south carolina
Posted: Wed Jan 20, 2010 12:48 pm Post subject: lift |
maxjax makes a portable two post jack. |
EdW Samba Member
Joined: January 13, 2005 Posts: 2385 Location: Unemployment Office
Posted: Wed Jan 20, 2010 3:28 pm Post subject: |
I would have to agree with this as well. If you have 14' ceilings, you're going to kick yourself for not getting a lift that goes higher than this:
_________________ 20‰
Quote: |
I would call him a dick, but a dick has a head on it |
Posted: Thu Jan 21, 2010 8:07 pm Post subject: |
i understand what everyone is saying abought the height. the picture with the blazer is deceiving. the pump assy is a bit taller on the post than i am as shown here. just about all the lifts in my price range have the same max lifting height. if i have to go all taco neck under the bus, i am ok with that. or worse yet, i sit in a chair and change my oil _________________
Jake Raby wrote: |
Brian wrote: |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Thu Jan 21, 2010 11:52 pm Post subject: |
Being able to walk under the lift would be nice, but it isn't necessary. I have a bend pak scissor lift and it only lifts to four feet. (nine foot shop ceiling) At max lift with the bus on the tallest pads I have, I can sit on my rolling stool and roll around under the bus. Quite comfy, actually.
IF I had higher ceilings, I likely would go for something with higher lift capacity, though. _________________ nothing |
Posted: Fri Jan 22, 2010 9:24 pm Post subject: |
that's true guys. see, we all learned something here.
All I know is I love my lift. Its nice to put a car on the lift for an oil change, but take a few minutes to look at the whole underside of the car. It really keeps you "in the loop" of your vehicles overall well being. You can see very minor leaks as soon as they develop, sources of squeaks and rattles, etc. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
Posted: Sat Jan 23, 2010 8:24 pm Post subject: |
thanks for the input guys. i have consulted with a few different companies, and i waent with the eagle lift. they took the time to go over the pro's and cons of the lift, and it is now on its way. as luck would have it, it will fit in the back of my single scab, so i will post pix when i get it. (providing the single scab isn't in 2 pieces when i load it in ) _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jan 29, 2010 8:22 pm Post subject: |
well, lift showed up today. it won't be put in for a while, but i hauled it home
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jan 29, 2010 8:24 pm Post subject: |
SWEET! When I got mine me and some friends drove from Tampa to Orlando (about 1.5 hours) with a 6x10 trailer. They loaded it in the trailer with a forklift and when we got home, we just backed up to the lift bay and drug it out of the trailer as we installed it. I'm very lazy that way _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
Posted: Fri Jan 29, 2010 8:44 pm Post subject: |
thats cool! as it turned out, the single cab bed is about 6" lower than the tractor trailer it showed up on, so we wheeled it on to the dolly, and at the end, i put my jack under it (you can barely see it in the pic) i tossed the strap around it real quick just to get off the street (sadly, that is our 'loading dock' at work) i pulled it into the shop, used our lift as a hoist to get all my stuff out from under it, drove it to my excavation guys house where he off loaded it. once the garage is all set, i will have him drag it to the house. he dosen't know it yet, but he will give me a hand setting it up too _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jan 29, 2010 9:53 pm Post subject: |
My father in law delivered my used scissor lift from southern Idaho for me in the back of his big Dodge. I had no way to get it out of the truck (900 lbs) so we went to my buddy's fabrication shop to use the forklift. We put it onto my low little trailer and headed back to my place. I then dropped the ramp on the back of the trailer, tied the lift off to the big spruce tree next to the driveway, and pulled the trailer out from under the lift. From there I was able to wheel the lift into my shop as it's designed to be somewhat portable.
It was an ordeal, but worth it for sure.
That's the lift, and that is the big spruce tree just to the left. _________________ nothing |
Posted: Fri Jan 29, 2010 10:12 pm Post subject: |
Let me know how you like that lift. I am seriously considering getting one of those. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
