Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jan 22, 2010 8:43 pm Post subject: |
The switch doesn't change the oil pressure the adjustment is for grounding to occur causiing the warning light to go on _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Thu Jan 21, 2010 12:15 pm Post subject: |
Hopefully this won't be considered as too far off-topic for this thread. I have one of those style switches and it does leak a bit at the joint between the Bakelite and the metal housing. Does anyone have a repair technique for re-sealing them? |
Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2354 Location: Sea level (Mid Atlantic)
Posted: Thu Jan 21, 2010 11:39 am Post subject: |
RareAir wrote: |
If you remove the grounding screw, look inside the cavity. Is there another screw inside to adjust pressure? |
Yes--the screw is in there. I've looked through the Bently chapter on the oil circulation system, and see nothing about actually using this screw to adjust pressure. I assume it's set at the factory to be the appropriate pressure, but . . .
I presume that a good way to check it is to run a oil pressure gague, and if the pressure is good and the oil light goes out appropriately when the switch is installed, all's well. _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
Motorhead55 Samba Member
Joined: August 22, 2007 Posts: 468 Location: California U.S.A.
Posted: Wed Jan 20, 2010 8:55 pm Post subject: |
The switch loks like a 36hp switch. The 0.6-0.3 is the pressure in "bar" where the switch will close and make contact _________________ 2007 Dodge Cummins Diesel 4x4 6spd stick
1939 WILLYS pickup
1967 Triumph Tiger Cub |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Wed Jan 20, 2010 8:53 pm Post subject: Re: School me on oil pressure switches |
Bart Dunn wrote: |
Stamped on the hexagonal sides are:
0.6 -0.3 = ?
4 65 = date code, perhaps?
M10 x 1 = thread size & pitch, probably, but not sure. |
I don't know the differences but the markings above are:
Pressure range in Bars, they are adjustable using the screw RareAir mentioned.
Date code
Yes, thread size. _________________ How to Post Photos
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Wed Jan 20, 2010 12:21 pm Post subject: School me on oil pressure switches |
I bought these a long time ago, and don't remember what for or why, but generally recall that they're NOS for a 36hp engine:
Are there different ones over the years? This is the text stamped on them:
On the black plastic, around the screw terminal: "MESSMER RADOLFZELL" which I assume to be a brand.
0.6 -0.3 = ?
Thanks in advance. _________________ Not enough car seats fit into my:
'58 Beetle sedan |
