germansupplyscott Samba Member
![](/vw/forum/images/avatars/144854332242de51a361a96.gif)
Posted: Fri Jan 22, 2010 8:10 am Post subject: |
SGKent wrote: |
In this gallery photo... |
just curious but in what gallery did you find that? _________________ SL |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
![](/vw/forum/images/avatars/649952796491bea76b286e.jpg)
Posted: Fri Jan 22, 2010 8:56 am Post subject: |
The length of the wires of a thermocouple do not matter, excepting a very very tiny loss do to resistance. You can make the distance between the two joints any distance you want within reason without changing the calibration of the gauge. What you can't do is splice in a section of copper (or other) wire to make the leads longer, as each connection you add is another thermocouple operating at an unknown temperature.
The thermocouple is the junction between the two wires, it would not be the ring terminal unless the ring terminal is made of two different metal plies and the wires are attached to each ply separately.
On heads that have the boss for the early TSII sensor, that boss might make a good location for attaching a smaller ring terminal with a screw. It should give close to the same readings as a ring terminal under the spark plug. |
rustbus Samba Member
![](/vw/forum/images/avatars/19643972494c28c64509dde.jpg)
Posted: Fri Jan 22, 2010 9:14 am Post subject: |
now if there was a way we could get a reading FROM the TSII that would be slick, as my engine is ex-FI and still has the TS2 in it... _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
fusername Samba Member
![](/vw/forum/images/avatars/46464069145d2a2d4bd9d9.gif)
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Fri Jan 22, 2010 9:21 am Post subject: |
if you cut off the ring, what is really important ray is that you maintain the factory crimp, as it is the junction of the two wire ends that REALLY matters. they must be joined with no impurities, no corrosion (harder than you think) and EXCELLENT contact. this is often done in a vacuum or special atmophere, and with extreeme pressure clamps. you can cut off the ring, just don't touch that factory crimp!
I can't see how jb weld would affect the reading at all, it MAY cause the guage to read slower due to poor thermal conductivity, however I don't know that for a fact, maybe JB weld conducts heat really well. I have been trying to find a epoxy that is designed to conduct heat, but have yet to turn it up. what is important is that the wires are not too exposedto the air flow, as they will be cooled by the air flow over them, which will wick heat away from the junction, and you will be reading this cooled temp rather than the head temp itself. actually potting the couple end in JB, while still using the ring under the spark plug would probably be the most accurate technique possible, imho. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
busdaddy Samba Member
![](/vw/forum/images/avatars/12378363254b954827328c6.jpg)
Joined: February 12, 2004 Posts: 52180 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jan 22, 2010 9:35 am Post subject: |
raygreenwood wrote: |
busdaddy wrote: |
Casey Ryan wrote: |
I did this on my dad's bus with the dakota digital probe. I just snipped off the ring, cleaned a space between the fins and pushed it down there into a dollop of jb weld. Taped it so it wouldn't move until it was dried.
Was able to do it all through the spark plug hole.
Registers perfectly.
We had tried the spark plug ring, but while putting the spark plug back in, the ring broke and the gauge was registering 100 degrees above what a sensor was telling us.
Casey |
You can't do that. Dakota digital also makes note of this in their literature. This is not just a simple ring terminal. The connector unit for the CHT end....is a thermocouple. The connector wire and ring generate a current as it heats and cools. You cannot cut it, shorten or lenthen it...or remove the fitting from the end without changing the output to the gauge. It changes what the gauge reads. It may be off a couple of degrees...it may be off 50 or 100 degrees.
Worse than that... adding a non thermally linear product such as adhesive, epoxy (JB weld) etc)...can make the gauge wildly erratic.
In short....it might be only a few degrees of variation in one heat range...like start up to say...150....but have a much wilder variation in a range from say...150-300...or even vice-versa.
You can't cut off the VDO heat temp wire ring either. Same problem.
There are gauges available that do not use thermocouple wire...but they also do not use a simple ring terminal. They use a screw in on clamp on thermo couple that creates the current at the head. The wire just carries that current/signal back to the gauge for processing into output.
If I were you...I would definately borrow a second gauge corrected to teh same level as the DD gauge...and check it. or...buy a new lead of teh correct length and install it. Ray |
Are you sure Dakota says that with proven science to back it up or is it just to ensure a repeat customer for the consumables? Or to protect themselves from mechanically inept customers and lawsuits?
I can't speak for a Dakota personally but I have dismantled VDO senders and it is just a cad plated copper ring terminal like any other solderless electrical terminal. The charge for the gauge is generated where the wires are joined inside the crimped area and cutting off the ring part of the terminal (leaving the crimped area) in no way effects the reading. Infact I've changed more ring terminals than I can count by prying the crimp open and replacing the terminal, each one is tested before and after and the end result is 100% of the originals performance.
If the thermocouple end of the terminal is left intact and the remaining part is in good clean contact with the head the reading would if anything be higher than a ring terminal application as the heat has a shorter distance to travel to the junction, being shielded from the cooling air stream by the JB weld would likely even make it indicate hotter.
Nothing wrong with JB'ing into the head if everything is clean and tight IMO. |
Uh...yeah...I am 100% scientifically sure!. And yes...there is nothing correct right or useful about JB welding a thermocuple to a cylinder head.
JB weld generates no current and does not have the same heat transfer characteristics as thermocouple wire. Just cause it looks clean and nice....how does that make it correct with regard to a thermoccouple?
Would you use JB weld...a non-conductor....to glue a ground wire to your block just because you can't figure out how to use a proper ring terminal?
Sorry...not trying to be rude....but you are giving people potentially deadly advice (to their engine)...with no science whatsoever backing it up.
(a) This is 100% what the definition of thermcouple is all about and (b).....DD makes note in ALL of their on-line literature that the connector wire muct not be cut in any way. (c)..I use thermocouples DAILY in my line of work and I have the pyrometers to calibrate them as well. (d) VDO also has the same stipulation about all of their connector terminal wires for their cylinder head gauges.
These are thermocouples. By definition and design...the connector wire and ring terminal are the sensor. The specific type of metals and the mass of said metals contained in this thermocouple assembly generate measurable current as they heat or cool. This is what is measured by the gauge. this is 100% how these gauges work. Change to regular wire and these gauges will either peg themselves to full open or never register anything at all....because regular wire is not a thermocouple and generate no current. Go on....try it.
The specific length and mass of these metals is highly calibrated at the factory and is set to the gauge. You cannot cut it or lengthen it unless the gauge is sent back to be re-calibrated to the thermocouple wire. PERIOD.
This is why....you can also buy any of these gauges WITH LONGER WIRES OR WIRES OF SPECIFIC LENGTH....calibrated to the gauge. All these companies sell what you need so you DONT CUT THE THERMOCOUPLE. Just ask for it.
That being said...there are gauges available that do NOT use thermo-couples. They use sensors....not thermoccouples. The sensor in this case is either resistance based ...similar to the standard CHT on type 3 and 4 fuel injected engines (which is FED a current and resistance to ground point is what is measured by the ECU or by a gauge)...or they are are a screw in thermocouple that generates a current. Those two types can send their signal over standard wire which can (to some extent) be lengthened or shortened with little or no effect on gauge readings
Here is an excerpt from the install manual for the DD Oddyssy series of CHT and EGT gauge
Factory settings:
Unit type: °F.
Hi warning point: 450 °F.
• The gauge can be set to ready in °F or °C. (see page 2 for setup instructions)
• The HEAD TEMP gauge will read correctly between the temperature range of 150 - 750° F (65 - 400°C).
• This gauge has a user adjustable high temperature warning point. (see page 2 for setup instructions)
The red and yellow wires with ring terminals are for the temperature sender input. The sender must be Dakota Digital part SEN-11-4(6’), SEN-11-5(10’), SEN-11-6(14’), SEN-11-7(18’), or SEN-11-8(18’-14mm ring). Sending units from other manufacturers will cause incorrect readings. These cables cannot be extended with standard wire. If a sender is not connected properly, the display will show “EEE”.
The HEAD TEMP gauge uses a thermocouple sensor to measure the temperature. A thermocouple actually measures the temperature difference between the ends of its wire. The thermocouple consists of screw-in exhaust sensor and the cable which connects it to the gauge. Because the thermocouple only measures the temperature difference, the gauge has a temperature sensor so that the temperature at the gauge end of the thermocouple wire is known. The gauge then adds the two temperatures together to display the actual exhaust temperature.
Because of the nature of the sensor used, the gauge will not read cold temperatures. The power circuitry inside the gauge will elevate the internal gauge temperature to 90°-150°F. This is the lowest temperature the gauge will be able to display. The gauge has a user adjustable high warning level. This can be set to indicate when the engine is beginning to overheat.
You need to understand the science of the various gauge types before you start chopping things up. I'm not sure about here...but there has been volumes written about this on Raby's site and on the STF.
Though Wikipedia is generally not a science source to be quoted....here is a good exerpt on thermocouples
http://en.wikipedia.org/wiki/Thermocouple
Ray |
Hold on here Ray, I agree with most of your reply but I can't find the part where I said it was OK to cut the wires, as you pointed out (and alot of us already know) the junction at the end of the wires is where the sensing takes place and cutting it would render a thermocouple useless.
When I change a terminal I carefully open the crimp leaving the junction intact and the way I read Casey's post he cut the ring off the terminal leaving the crimped area alone.
Sure changing a terminal may alter the fine calibration of the unit, but we're not monitoring a temperature critical heat treating or chemical manufacturing process here or leaning a $50K+ aero engine for optimum performance at altitude. In a bus a CHT is only a trend monitor and a few degrees error isn't going to be a big deal unless you plan to run it to 449.99 degrees and hold it right there all day, errors or not when that gauge jumps significantly from it's cruising temp it may be a good idea to wait till the next passing lane to overtake that truck.
Same with mounting methods, maybe the JB isn't a good electrical conductor, but as you stated the sensing takes place at the junction and the temp there is what's measured whether it's crimped into a ring terminal, shrouded in goo or in free air, it senses what it's touching. Perhaps it's a few milliseconds slower and a few degrees off in the goo but even with a lag it'll still indicate when a problem is occuring.
My favorite method is to install a #8 ring terminal and attach it near the plug, no more mangled rings.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 22490 Location: Oklahoma City
Posted: Fri Jan 22, 2010 1:40 pm Post subject: |
Thats exactly what I said...it is NOT OK to cut the wires.
Also...unless you have checked...you have no idea whether your gauge is now only a few degrees off. This is all about conduction and radiation. The ring terminal pulls in and concentrates heat at the TC point at the ends of the wires. Without that mass...you have no idea of what it may do to the accuracy of the TC joint.
Why? because a TC is not just an open to the air joint. The two metals must be intimately connected. Factory high pressure crimping....forms almost a hermetic bond.
Now.....yes it would be much better to leave the crimp on....but you still have no idea how much losing th ring lost you.
Alot of this is seat of the pants calibration. What everyone is failing to understand...is that heat rise and heat banking are not linear across every tempereature range. So its like this.... you try it with the ring under the spark plug and drive it down the road...maybe you read 300F. So you snip off the ring and glue it down and now you read 305-310 and figure..."good enough for me". Did you bother to map this across upper range (above 300F) and middle range and mximum to see if the minor change was linear? The problem is....that in many cases it may not be...and it can be grossly off.
If you are off 25F...thats enough to fry your heads...when you think you are border line at 375 and motor on....and you are really at "seat dropping" 400F.
I could care less about a few degrees...I do care about reliability across the range.
If you are using your head temp gauge for "trending"....IMHO...you would not be buying products from dakota digital. You would be buying a VDO or similar product. DD gauges are designed for greater accuracy.
Wildthings...you are correct and incorrect at the same time. Yes...you can extend milivolt generating TC's ...if you know the wire composition. But....its dangerous to do so. Its generally not the added length of wire and any resistance properties that are at issue. Its the connections in the splice and the connectivity....every single time.....that screw you. There is no crimp system or connector systemthat can guarantee a clean splice in a thermocouple wire. Thats why whatever crimped terminals or splices there are...are calibrated with the wire as an integrated unit. Ray |
WhirledTraveller Samba Member
![](/vw/forum/images/avatars/6510490855587ed1bc2801.jpg)
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Fri Jan 22, 2010 4:55 pm Post subject: |
Hmmm, Ray, I don't really know how to say this politely but I'll try. You are putting a lot of confusing and frankly incorrect information out there.
Thermocouples are not calibrated items in the way that, say, a micrometer is. They are two wires joined together. The accuracy and reliability of the thermocouple itself is mostly a function of the quality of thermocouple wire used, and to a lesser extent the quality of the joint. They are typically not so much calibrated as just checked, at least for general use like we are talking about. Now in my case I made my own thermocouples using high quality SLE (special limits of error) wire, but made a rather crude weld which probably contaminated the joint just bit with some of the metal from the battery post. I'm not that worried about it, it might change the reading a few degrees at most. If the joint is really bad, or the wires in a crimp get separated, you will get no reading at all or an intermittent reading. It won't "drift". Either the wires make electrical contact or they don't. You can simply twist the wires together and the thermocouple will work fine, with perfect accuracy, but probably won't last long. You can even put a different metal in between the wires. This is known as the "Law of Intermediate Metals". For example I could attach one wire to one cylinder head and another wire to a different cylinder head, and get a reading on the gauge which would be an average of the two temps. Not a bad idea, actually!
"Factory" thermocouples from DD or VDO or anybody else are *not calibrated* period. What would they adjust? They are assembled, and, if you're lucky, checked.
Now some of the stuff you have said, really, I must say is truly B.S.
The ring terminal does not "pull in and concentrate heat". That is engineering nonsense. It is made of copper and conducts heat, that's all. We are interested in the temperature of the head, so it is actually more accurate to put the thermocouple in direct thermal contact with the head, rather than through a ring-terminal intermediary.
You do not need any sort of mass attached to a thermocouple to make it accurate. Fine wire thermocouples can be practically microscopic and will respond instantly to any temperature change. Attaching a mass such as a ring terminal does not make the thermocouple more accurate, it just makes it respond slower.
As for "heat rise and heat banking" these are not scientific terms. I have no idea what you are talking about. This is a simple problem... what is the temperature of the cylinder head? A thermocouple placed in direct contact with the cylinder head will be at the same temperature as the cylinder head. It will generate a millivolt signal proportional to the difference in temperature between itself and the cold junction. That millivolt signal will travel through the wire (ANY length of wire, you CAN cut the wire), into the gauge, where a good gauge such as a DD or EMS1 will perform a conversion according to standard thermocouple reference tables, apply the cold-junction compensation if necessary, and display the temperature. This process is remarkably accurate, typically within a couple degrees. There are only a few things that can go wrong:
1st, as I said, the metal the wire is made out of is important. If the metal is chemically contaminated it may change the properties of the thermocouple. This is usually pretty minor.
2nd, since the signal is so low, the wire must be reasonably protected from electro-magnetic interference
3rd, any electrical connections need to be solid, again since the signal is so low.
4th, You want to *avoid* using non-thermocouple wire to extend the leads. However this is not an absolute prohibition. In fact the VDO sender is only 1 foot of thermocouple wire and the rest is normal wire. What this does is to move the "cold junction" to that point of splice. Now, that cold junction acts as it's own thermocouple and will throw off the reading if that junction is at a different temperature than the gauge (which is where the cold junction compensation takes place). For VDO they don't care because they never bothered with cold junction compensation to begin with! They just assume the cold junction is room temperature. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Fri Jan 22, 2010 5:02 pm Post subject: |
WhirledTraveller wrote: |
a rather crude weld which probably contaminated the joint just bit with some of the metal from the battery post. . |
![Wink](images/smiles/icon_wink.gif) _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent ![Premium Member Premium Member](./templates/subSilver/images/lang_english/icon_star.gif) Samba Member
![](/vw/forum/images/avatars/15127423263756d51c9c5a.gif)
Joined: October 30, 2007 Posts: 41294 Location: Citrus Heights CA (Near Sacramento)
Posted: Fri Jan 22, 2010 5:11 pm Post subject: |
WT -
Q. Where is the cold junction electrically? Is it where the wires join the pins in the connector, the full length of the non thermocouple wire or at the head unit? I understand that the different electrical properties generate the signal, however would the signal from say a 50 foot long thermocouple wire twisted together be the same as a 1" long one twisted together at any given temp? I am trying to understand the process. If the connection to the pin in the connector (different metal) helps determine the signal, then is the temperature I am getting on the gauge nothing more than "indicated temp X" over that junction point? Or is it "X" degrees over the average temp along the run from the front to the back, or "X" degrees over the head unit etc? What I am saying in a way is that if the thermocouple and the cold junction were the same temp would there be no signal and where is the cold junction on the VDO? _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Fri Jan 22, 2010 7:13 pm Post subject: |
SGKent wrote: |
WT -
Q. Where is the cold junction electrically? Is it where the wires join the pins in the connector, the full length of the non thermocouple wire or at the head unit? I understand that the different electrical properties generate the signal, however would the signal from say a 50 foot long thermocouple wire twisted together be the same as a 1" long one twisted together at any given temp? I am trying to understand the process. If the connection to the pin in the connector (different metal) helps determine the signal, then is the temperature I am getting on the gauge nothing more than "indicated temp X" over that junction point? Or is it "X" degrees over the average temp along the run from the front to the back, or "X" degrees over the head unit etc? What I am saying in a way is that if the thermocouple and the cold junction were the same temp would there be no signal and where is the cold junction on the VDO? |
I think that WhirledTraveller did a good job of detailing how a thermocouple works. It is the temperature of the joints that count. I had assumed that the cold junction on both a DD and VDO thermocouple would have been in the gauge itself, but will take WhirledTraveller's word for it that the VDO unit has a (double?) cold junction about a foot down the line from the sensor. If so you would want this cold junction located a well a possible away from any heat sources like the exhaust, heads, or heater pipes.
I would say that the size of the junction is important to a point. The size of the junction would relate to current generating capacity, and only indirectly to voltage. With no current flow the voltage output of a joint would be the same regardless of size, but the meter is probably going to require some current flow thereby causing a drop in the voltage. As I have no idea what either the DD or VDO meters are actually sensing (voltage or current) I have no idea what kind of current flow they may require or how the current (and the size of the junctions) affects their accuracy.
The temperature that the gauge reads is going to be the "Δ" temperature between the two joints. |
Posted: Fri Jan 22, 2010 11:33 pm Post subject: |
Wildthings wrote: |
You've got it.
The gauge is measuring voltage. There may be some current flow as a byproduct of the measuring process, but it's going to be microamps or even picoamps. Inconsequential.
Electrically, the cold junction is the point at which the thermocouple wire ends and the normal copper wire begins. In the DD or similar high-quality gauge, using thermocouple wire the whole way, the cold junction is at the back of the gauge. The "cold junction compensation" consists of a separate temperature sensor located at that point. The circuitry then, knowing that temperature, can apply a correction. The VDO gauge is dumb and assumes the cold junction is always 70 degrees (roughly). So it's accurate only when the cold junction is that temperature. If the cold junction is colder than that, the gauge will read high. If it's warmer, the gauge will read low. This is particularly dangerous if you think about it, because on a hot day the gauge will read cold and on a cold day it will read hot!
As for SGKent's question, you are correct that if the "cold junction" and the "hot junction" are the same temperature, there will be no millivolt signal. In this case, the VDO gauge will read "70 degrees", and the DD will read the temperature of the thermistor which is installed on the back of the gauge. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Sat Jan 23, 2010 5:14 am Post subject: |
Yes on the ends matter. if you have a good guage hooked to the end of a thermocouple, and have the sensing end at 100 deg, the guage at 0, and the middle of the wire at 200, it should read 100 deg. only the difference in temp between the endpoints matters. A good guage knows its own temp and based on the voltage figures out the temp of the other end by adding or subrtacting it from its own temp. Any autmotive guage and most guages used anywhere else use voltage to detect the temp difference, as it is constant for one wire type. A guage that sense by current can vary due to wire length and must be calibrated for every isntallation, and takes much finer equpitment. We would never see such a thing in a dash guage.
The voltage generated by the heating of the far end does not suffer from voltage drop over the lines, becasue the guage looks to the wire as an open connection, as its resistence is rediculously high, to the point of being an effective infinity. However the cheaper the guage, the lower the resistance, most likely. Now you have unpredictable voltage drop which simply turns up as error. Another issue You can have with a cheap guage is the onboard electronics can start generating heat. They generate enough heat to mess with realative readings, but not enough to heat up everything inside the guage, meaning one half of the electronics can be many degrees over that of its neighbors due to poor thermal conductivity, so even tho the guage has cold junction compensation, its not compensating for the temperature of the end of the thermocouple, but of one part of the board. This here is splitting hairs, but intersting to those who plan to build thier own guages from scrap, or who just like knowing a bit too much!
Now the DD guage uses a two piece thermocouple wire as well, using a special "thermocouple exentions wire" I don't really know what this means. It is some special wire, I am not sure if its cheap thermocouple wire, or just high grade copper, or what, as it would move the junction, just like was said before, but DD says all thier guages are CJC, so this some how must not effect it, however they may simply be assuming the enging compartment, or wherever the junction i, approx 8 inches from the ring, is going to be at the same temp as the guage, a terrible assumption. This is somethign I need to do a bit more looking into, I have yet to figure that one out. _________________ [email protected]
babysnakes Samba Member
![](/vw/forum/images/avatars/12494822836485e4381a739.jpg)
Posted: Sat Jan 23, 2010 5:54 am Post subject: |
Wow, this was a great read. Although I was planning to install a CHT before I installed the motor anyway,understanding how they work and what to and not to do will ensure the best install. Thanks for starting this thread Skidoo |
skidoo Samba Member
Joined: February 28, 2008 Posts: 40 Location: quebec,canada
Posted: Sat Jan 23, 2010 6:37 am Post subject: |
Really i'm really happy to learn !!! It's interresting to exchange about eveybody experience !!!
I like to thanks everybody who help me about my question !!! i'm new on the Bus world and it's great to see that the AIR COOLED people are so helpfull and give time to other one for helping !!!
See you somewhere on the road !!!!
Jeff ![Razz](images/smiles/icon_razz.gif) |
skidoo Samba Member
Posted: Sat Jan 23, 2010 6:45 am Post subject: |
Just a last question:
What is the normal temperature range for the cylinder head, at what temperature should i become worry about having trouble ??? |
Randy in Maine Samba Member
![](/vw/forum/images/avatars/16657289703f4ffd05744cd.jpg)
Posted: Sat Jan 23, 2010 7:06 am Post subject: |
Stock valve seats likel to drop out about 450º F.
I would not let it get much above 400º F.
"Improved" heads can take a bit more, but don't bet the farm on it. |
Posted: Sat Jan 23, 2010 7:57 am Post subject: |
fusername wrote: |
Now the DD guage uses a two piece thermocouple wire as well, using a special "thermocouple exentions wire" I don't really know what this means. It is some special wire, I am not sure if its cheap thermocouple wire, or just high grade copper, or what, as it would move the junction, just like was said before, but DD says all thier guages are CJC, so this some how must not effect it, however they may simply be assuming the enging compartment, or wherever the junction i, approx 8 inches from the ring, is going to be at the same temp as the guage, a terrible assumption. This is somethign I need to do a bit more looking into, I have yet to figure that one out. |
Thermocouple extension wire is made out of the same metal as regular thermocouple wire, so it does not move the cold junction. It is cheaper, though, because it uses a normal jacketing material which is not resistant to high temps. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
rcnotes Samba Member
![](/vw/forum/images/avatars/54279405943585032993c2.jpg)
Joined: July 09, 2005 Posts: 641 Location: Ann Arbor, MI
Posted: Sat Jan 23, 2010 6:53 pm Post subject: |
I went for a drive today and couldn't get head temps above 380.
That was at about 80 mph and 35 degrees F.
Man, talk about wind noise! |
GusC2it Samba Member
![](/vw/forum/images/avatars/7837194904b146e73dc4b3.jpg)
Joined: June 23, 2005 Posts: 1376 Location: Orlando, Florida, USA
Posted: Sat Jan 23, 2010 10:21 pm Post subject: |
If it will help anyone, I cut my ring off, not the crimp, and wedged it in between the fins, at their base, making sure of good thermal contact, and using JB weld only to hold it in place. It works fine, but here's the thing.
I chose the exhaust side of the spark plug, not thinking that the plug base, where the normal ring goes, is in between the cool intake valve and the hot exhaust valve. My sensing point is much hotter, therefore, I can't compare my readings with those who use the plug ring.
So when I get a chance, I will relocate my sensor closer to the plug base.
I agree with BusDaddy, that any head temp gauge is really a trend indicator, because temperatures vary greatly at different points on the head. (so its difficult to compare with other engines)
IMHO, this is the only positive reason for using a plug ring.
The gauge needs to be calibrated in our heads, the head on our shoulders, , by observing under different driving conditions. _________________ 75 type 2 http://gusc1.tripod.com/1975vwtype2
Old vices have now been upgraded to bad habits.
http://www.facebook.com/pages/VW-Wild-Weekend-2011-St-Pete-Fl/197064760336111 |
jackstar Samba Member
Joined: February 15, 2008 Posts: 274 Location: Gulf Breeze, Florida
Posted: Mon Jan 25, 2010 6:00 pm Post subject: |
Ok, after reading some interesting posts I decided I needed to go to the "horse's mouth" so to speak. I called JB Weld and asked them if their product would conduct electricity. I explained the application and they said that JB Weld would NOT conduct electricity. However, that is not to say you could not take the ring terminal and cut it in a half moon shape, place the metal from the terminal in the pre-cut groove and have the half moon shape fit around the plug hole and have it contact the head and JB Weld over that. It would leave the metal from the terminal in contact with the head and the JB Weld over that. In theory, it should work.
Then I called DD and talked to tech assist. They did say that the end of the lead is special. How special he could not tell me. He directed me to the engineers. They didnt have time to talk. The replacement lead from the 2 philips head screws to the terminal is 7.50 plus shipping. $16 total to NW Florida. I ordered one.
I dont know if this helps or not. I would like to get an answer from the engineers. I will try later. Just my .03 worth. |
