singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Sun Jan 24, 2010 11:03 pm Post subject: |
I was looking today at this location. What's the best way to access the back to screw on the locking ring? Did you remove the cook top or bend your arm in twelve different directions at once to negotiate the void behind? I must be tired today b/c nothing simple was jumping out on how to get access, even with the fridge removed. |
madspaniard Samba Member
Posted: Sun Jan 24, 2010 11:04 pm Post subject: |
singler3360 wrote: |
Hey Mad,
Why one to the outside in the city water hookup? What do you run out there? |
anything you want, air pump for water toys or mattress, solar panel cord, water pump for shower ... _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Sun Jan 24, 2010 11:07 pm Post subject: |
no need to remove fridge, you can remove the metal front plate following directions in this thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=334649&postdays=0&postorder=asc&start=0 _________________ 1991 Westy auto w/ Peloquin TBD
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Mon Jan 25, 2010 8:28 am Post subject: |
madspaniard wrote: |
Home Team Van wrote: |
I like this location. It's convenient when the bed is down and I can hide items that are being charged in the water tank cabinet.
can you use this receptacle with the rear table in place? |
Yes, the receptacle is a good 3-4 inches below the table. _________________ _________________________________
82 Diesel Westy |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Mon Jan 25, 2010 9:36 am Post subject: |
Give that (Mad) man a dollar! Mad's thread was exactly my reference point.
_________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Posted: Mon Jan 25, 2010 4:09 pm Post subject: |
Yes, thanks Mad. My hope is that one day my orly blue Westy follows in his footsteps/tiretracks. |
kshbaja Samba Member
Joined: June 15, 2008 Posts: 476 Location: Portland, OR
Posted: Thu Jul 29, 2010 7:33 pm Post subject: |
To the folks that mounted 12v receptacles in the metal face plate above the fridge and below the stove/sink: what did you use to cut the holes? _________________ 1986 Westfalia |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Thu Jul 29, 2010 9:14 pm Post subject: |
kshbaja wrote: |
To the folks that mounted 12v receptacles in the metal face plate above the fridge and below the stove/sink: what did you use to cut the holes? |
Somewhere I saw a 1 1/8" hole saw drill bit suggested. It worked perfectly on the metal of the face plate and cabinets. MadSpaniard installed 2 side-by-side in that location and I thought that was overkill at the time, but now I wish I had done the same (allows for charging something while plugging in a laptop). |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Fri Jul 30, 2010 9:38 am Post subject: |
McVanagon wrote: |
I was wondering when someone was going to post an USB option. Since most phones/handhelds are using 5v batteries and are able to charged via USB, it seems that everyone will only need to buy one car cell phone charger from now on.
For those of you with campers, these might come in handy for charging a few phones, etc....
any link for this _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Fri Jul 30, 2010 9:53 am Post subject: |
GBA 88West LA wrote: |
McVanagon wrote: |
http://www.itechnews.net/wp-content/uploads/2009/1...-Ports.jpg |
any link for this |
I did a quick search and found this..
http://store.fastmac.com/product_info.php?products_id=458
It's worth a mention that converting 12vdc > 110vac > 5vdc is not the most efficient way to make 5vdc. If I were to use this in a Westy, I would take it apart, and convert 12vdc to 5vdc and supply that to the ports on my own. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
erdonline Samba Member
Posted: Fri Jul 30, 2010 11:02 am Post subject: USB ports |
McVanagon wrote: |
McVanagon wrote: |
any link for this |
It's worth a mention that converting 12vdc > 110vac > 5vdc is not the most efficient way to make 5vdc. If I were to use this in a Westy, I would take it apart, and convert 12vdc to 5vdc and supply that to the ports on my own. |
Forgive me if I'm misunderstanding something here, but the outlets mentioned convert 110v dirextly to the 5vdc for the USB, right? Where does 12vdc come in? (Unless someone is powering their 110v outlet in their camper from an inverter, that is.
Ed in CT _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
