Rethwish stroker project finished
Braukuche
Braukuche is offline
PostPosted: Sat Jan 23, 2010 4:19 pm    Post subject: Rethwish stroker project finished Reply with quote
After a year or so, I finally finished this little project up. Its a 3 series 36hp with a vintage EMPI pre-Okrasa 69.5 stroker crank, vintage Rethwish dual carb kit with aluminum intakes and stock Solex 28 PCI carbs, vintage Porsche OT threaded pulley and Porsche flywheel, 010 distributor, vintage Knecht air cleaner (looking for one more), vintage Crowe cam,engine completely balanced, case decked and savers installed and a larger oil pump. Once I figured out the firing order it fired right up and ran smooth. Reved like no 36 I've ever experienced and sounded nice and throaty. Even idled smooth and I haven't even balanced the carbs yet! It will eventually go in a '60 Beetle convertible I am building for my wife.
PostPosted: Sat Jan 23, 2010 11:04 pm    Post subject: Reply with quote
Cool!
How does the carburetor linkage work? I can't really see it.
Braukuche
PostPosted: Sun Jan 24, 2010 8:11 am    Post subject: Reply with quote
Cool!
It consist of a metal bar running horizontally from one carb throttle to the other. It has two small rigid bars held in clamps which pivot on the bar and the small rigid bars are in turn attached with a stock barrel clamp to the carb throttle plate. Sort of an odd set up and I wondered if it would really work, but it did, thankfully...at least on the bench.
empiracer
empiracer is offline
PostPosted: Sun Jan 24, 2010 1:42 pm    Post subject: Reply with quote
Looks nice , It would be cool to see You tube of it running.
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Sun Jan 24, 2010 3:56 pm    Post subject: Reply with quote
Can you show some decent pictures of the linkage at the carburetor?
Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible
Braukuche
PostPosted: Tue Jan 26, 2010 5:15 pm    Post subject: Reply with quote
Here you go
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Tue Jan 26, 2010 5:21 pm    Post subject: Reply with quote
Braukuche wrote:
Here you go
Thanks!
195? Project "X"
sub-hatchtim
sub-hatchtim is offline
PostPosted: Wed Jan 27, 2010 12:24 am    Post subject: Reply with quote
right on i wana see that 58 pgsg
(o\!/o)
ON-ON RU
58' pg/sg sub hatch westy
90' doka 1.6td jx import from germany soon to be a bew tdi
76 Porsche 911S
Braukuche
PostPosted: Wed Jan 27, 2010 7:17 am    Post subject: Reply with quote
There you go...
sub-hatchtim
PostPosted: Wed Jan 27, 2010 2:08 pm    Post subject: Reply with quote
very kool
(o\!/o)
ON-ON RU
76 Porsche 911S
jz56oval
jz56oval is offline
PostPosted: Wed Aug 01, 2018 8:28 pm    Post subject: Re: Rethwish stroker project finished Reply with quote
Hey
Just curious how these carbs ran? Any issues with the linkage set up? Easy tuning?
Thanks
