ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Wed Jan 27, 2010 5:49 am Post subject: |
Holy crap, that's some IMPRESSIVE fab work. I do have one question, what will the old engine bay now look like? Will it be sealed up, like some kind of trunk, or? Ok, one more question, is the back seat going in again? Is there even room above the new engine (which I ABSOLUTELY LOVE!!!)? _________________ (O\U|U/O) Top Vw (o\UU/o) |
Rigamortiz Samba Member
Joined: August 16, 2009 Posts: 260 Location: Cambridgeshire, England
Posted: Wed Jan 27, 2010 6:31 am Post subject: |
That is absolutely stunning work! _________________ SBS UK #72 FNG
'65 Kombi (Daily driver) |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Wed Jan 27, 2010 6:44 am Post subject: |
Boy...I opened this thread expecting the worst....although I shed a couple of tears for the poor old double cab...the mad fabrication skills have replaced my frown with a big smile. Nice job. _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
Posted: Wed Jan 27, 2010 6:51 am Post subject: |
rjonas wrote: |
Boy...I opened this thread expecting the worst....although I shed a couple of tears for the poor old double cab...the mad fabrication skills have replaced my frown with a big smile. Nice job. |
Eh, no big deal. At least it wasn't a Binz! _________________ (O\U|U/O) Top Vw (o\UU/o) |
dubulup Samba Member
Joined: November 13, 2008 Posts: 387 Location: Earth People
Posted: Wed Jan 27, 2010 7:02 am Post subject: |
very nice...I like |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Kelly Samba Member
Joined: November 25, 2003 Posts: 2437 Location: Olympia, WA
Posted: Wed Jan 27, 2010 7:45 am Post subject: |
impressive welds.
this thread reminds me of the 4,341 people who have said this to me:
"hey did you know you can put a Porsche engine in there" _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
Area51 Samba Member
Joined: September 09, 2002 Posts: 255 Location: Area51 / The Netherlands
Posted: Wed Jan 27, 2010 9:54 am Post subject: |
Hebster52 wrote: |
Gives me some ideas and hints for my crewcab too.. |
Me too !!
Going to collect a complete 964 C4 drivetrain (minus engine and gearbox) in a couple of hours. |
artie325 Samba Member
Joined: July 25, 2005 Posts: 187 Location: Hamburg, NY
Posted: Wed Jan 27, 2010 12:14 pm Post subject: |
Truly excellent work! That suspension sick! I would love to see a video of this thing running. |
67dubcab Samba Member
Joined: February 12, 2009 Posts: 214 Location: sebastopol C.A
Posted: Wed Jan 27, 2010 5:20 pm Post subject: Porsche Powered Mid-Engine Double Cab Build |
The old engine bay will be closed in with sheet aluminum and become a trunk of sorts.
I am going to build a new seat base using foam as a cushion and sheet aluminum for a firewall on the engine side. the seat back might be custom as well with headrests, or modify the original.
The front suspension is set for now but I know Seth could design and build a awesome front A arm setup, got to leave something for future mods. |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Wed Jan 27, 2010 10:25 pm Post subject: |
amazing fab work, top notch for sure.
but,
the ride hieght(stance) and tire sizes make it look like ass. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Twisted Minis Samba Member
Joined: December 24, 2007 Posts: 97 Location: Windsor, CA
Posted: Wed Jan 27, 2010 10:33 pm Post subject: |
my65vert wrote: |
but,
the ride hieght(stance) and tire sizes make it look like ass. |
Don't quote me on this, but I think it will be going down like 2 inches. The suspension is set up to travel the way he wants with all pieces set centered for a neutral adjustment point. Everything can be adjusted from here. I believe he will be going with softer springs as well, because I think the coil overs came with 400 lbs springs. It's pretty stiff as it sits, since it still has the torsions acting with the coil overs. _________________ If you can find it cheaper, I can fix it. |
Posted: Wed Jan 27, 2010 11:28 pm Post subject: Porsche Powered Mid-Engine Double Cab Build |
Hey Seth, funny you just replied to that point as I just came back from my shop doing a suspension tune.
I put some 220# springs on the front and dropped the beam a notch and its sitting perfect.(wether 220# is the correct rate will have to wait for the test drive!)
I pulled the torsion bars last night and tested range of travel of the rear suspension and its spot on at 7" from full droop to full compression.
Now I know where you can build the bump stops.
I am going to adjust the rear torsion splines to set the rear height, keeping the 400# coil springs as a starting point.
The tire/ wheel combo is 7" et55 16" with Toyo TR1 215/40
rear are 8" et52 16" with Toyo TR1 245/45 factory Porsche cup 1's.
Tire sizes in 16" wheel size is shrinking rapidly, I would have rather run 245/40 on the back and 225/40 fronts, but the back tire rolling diameter is just a little smaller than the stock 944s2 for a little more low end, plus I expect my top speed to be only around 145m.p.h. due to aerodynamic restrictions! |
Posted: Wed Jan 27, 2010 11:32 pm Post subject: Porsche Powered Mid-Engine Double Cab Build |
Oh, and I agree it does look like ass in that photo! |
Posted: Thu Jan 28, 2010 12:12 am Post subject: |
Sounds like the bell crank is working perfectly if you are getting 7 inches of travel at the wheel. _________________ If you can find it cheaper, I can fix it. |
RennyRB Samba Textbook Gangsta
Joined: August 10, 2006 Posts: 979 Location: Torrance
Posted: Thu Jan 28, 2010 12:52 am Post subject: |
This thing is sexy! Keep it up. _________________ 1967 Squareback |
LeviMan2001 Samba Post Whore
Posted: Thu Jan 28, 2010 1:45 am Post subject: |
Twisted Minis wrote: |
Sounds like the bell crank is working perfectly if you are getting 7 inches of travel at the wheel. |
So is the point of bell cranks just to fit a longer suspension part in there sideways? Or is it just to say "look at that!" They are pretty cool. _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs |
Posted: Thu Jan 28, 2010 9:59 am Post subject: |
LeviMan2001 wrote: |
So is the point of bell cranks just to fit a longer suspension part in there sideways? Or is it just to say "look at that!" They are pretty cool. |
The shocks he bought have a max of 4" of travel, and they also have that built in bump stop which probably will limit that travel even more. We couldn't get that sucker to compress very much. So the shock doesn't really travel enough, you would be either bottoming it out or limiting your droop a lot depending on where the ride height was and how it was set up (the front will probably be a little bit like this, droop wise it doesn't seem like it has enough, if I had not moved the shock down it would have had 3/4" of droop from ride height). He wanted more travel at the wheel, so the bell crank has a 1.5:1 ratio on it, which would give approximately 6" of travel at the shock mounting point on the arm. Since that point is inboard from the wheel about 8 or 10 inches, I knew we would get a little bit more travel at the wheel than at the shock mounting point. I just hoped that number would be 6.5 to 7 inches with the bump stop in there, since we never fully cycled the suspension here at the shop.
So in short, the bell crank is there to provide more travel than the shock could ever dream of doing in a normal set up.
Since it is on a ratio it will slightly soften things, so it will probably end up with a slightly stiffer spring rate than a traditionally mounted shock would in order to achieve the same load capacity. But the shock itself doesn't care, it will still work just the same. The shock only sees this as moving slower, which means it's never going to start fading (you would have to work a Bilstein pretty fast to get shock fade anyway).
Normally when I play with bell cranks it is just for relocation sake. So this was fun to get to play with ratios and angles of the shock and connecting link rod to get the desired travel numbers. Right now I am designing one for a guys front suspension, because his wheel is hitting the shock in turns and is still about 3" from the frame, so it's limiting his turning abilities. So what I will do is similar to this here, I will run a link bar as tight to the control arms as possible, and it will have a bell crank that will put a Bilstein shock horizontal above the control arms to get them out of the way. _________________ If you can find it cheaper, I can fix it. |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Jan 28, 2010 4:18 pm Post subject: |
An amazing amount of fabrication and engineering. Well done Sirs! _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
