fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Tue Jun 30, 2015 8:36 pm Post subject: |
modok wrote: |
knowing what the cam blank is certainly is more difficult if identifying marks have been removed by stoker clearance. |
How can I find out without the markings? _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Tue Jun 30, 2015 8:38 pm Post subject: Re: Web camshafts |
neil68 wrote: |
I would not recommend those lifters with a Web camshaft. Double check with Webcam to be sure. |
What would you use, Neil?
These "use with any cam" udo lifters seem to be anything but _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Posted: Tue Jun 30, 2015 8:40 pm Post subject: |
Somebody round here has to call Web and ask what's going on with the cam blanks.
Before you call, see if the cam gear fits correctly. |
Posted: Tue Jun 30, 2015 8:44 pm Post subject: |
modok wrote: |
Cam gear fit fine. It's in the short block already. This is seriously a bit frustrating.
Engle 120 markings c4 and d4
SLR SC-1
WEB....NONE _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Tue Jun 30, 2015 8:53 pm Post subject: |
Aren't all Web stroker-cleanced cams SC-1 blanks?
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Tue Jun 30, 2015 9:01 pm Post subject: |
stan_tichomirov wrote: |
Stan |
I didn't think so, now I'm not sure.
What a rixe this has been. I've got 3 new cams. And one set of $400.00 udo's. Since I'll be orderkng new heads this week, with the cc chamber I'll need, I may just use the Engle 120. I KNOW engle cams are compatible with udo's. Going to sleep on it. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Jun 30, 2015 10:20 pm Post subject: |
modok wrote: |
No answers here, but some clues:
I called 2-3 months ago to speak with Web about different grinds. At that time they were using the Scat SC1 blanks.
SLR is also grinding scat SC1 blanks. At the moment the are 3 different tool steel lifters available, Udo's, Prescott Phillip's, and Shag Leon's ultra light set. I know of one set of Prescott's lifters running a Webcam, and Prescott runs a scat cam in his own race car with his lifters. Shag Leon's tool steel lifters are advertised to work with ANY cam at all.
If Udo is advising against using his lifters with the Scat blanks (webcam/SLR/scat cams), one might assume that he is wary of the hard cam blank after his own lifter hardness issues. Or maybe it is something completely different, but it certainly narrows the available options. |
jason Samba Member
Posted: Tue Jun 30, 2015 10:46 pm Post subject: |
Is there a cam gears not fitting issue going on? I thought I was the only one. |
modok Samba Member
Posted: Tue Jun 30, 2015 10:58 pm Post subject: |
no, no, Just thought I'd mention it. Looks like the same "no name" brand. |
jason Samba Member
Posted: Tue Jun 30, 2015 11:03 pm Post subject: |
I don't understand, no name brand? If you mean the cam gear I tried a vw, cb and Brazilian gear. It's late probably went right over my head. |
modok Samba Member
Posted: Tue Jun 30, 2015 11:04 pm Post subject: |
The cam has no casting marks. |
Posted: Wed Jul 01, 2015 9:44 am Post subject: |
Just got off the phone with webcam....they say not to use udo be ker lifters with their cams. Straight from the horses mouth. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
maui Samba Member
Posted: Wed Jul 01, 2015 11:00 am Post subject: |
A engle 125, Norris 408 is very nice with 2 liter and stock gears and can go 1.25s sometimes if you like. |
Posted: Wed Jul 01, 2015 11:16 am Post subject: |
maui wrote: |
Yeah, but I'm using the webcam 86b. Called webcam and they manufacture their own lifters now, so I ordered a set of them. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Jul 01, 2015 11:22 am Post subject: |
fivelugshortaxle wrote: |
maui wrote: |
Yeah, but I'm using the webcam 86b. Called webcam and they manufacture their own lifters now, so I ordered a set of them. |
They do now? Is this recent? It was common knowledge that they repackage scat lifters. I'm not sure if the lifters are SLR treated or are the lightwieghts. I lucked out and got my two 86c with the cwc blanks. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Wed Jul 01, 2015 11:26 am Post subject: |
jfats808 wrote: |
maui wrote: |
They do now? Is this recent? It was common knowledge that they repackage scat lifters. I'm not sure if the lifters are SLR treated or are the lightwieghts. I lucked out and got my two 86c with the cwc blanks. |
Person I spoke with said they manufacture their own now and that they are not repackaged. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Wed Jul 01, 2015 12:54 pm Post subject: |
Stan |
I just went out into my shop and found 3 Pre-Clearance Cams, one Engle FK44, one Web 86b and a Scat. All are stamped SC-1 on the blank. I have over 10K on an Engle SC-1 with Udo Lifters and not seen any metal in the oil yet. Keeping my fingers crossed. |
Posted: Wed Jul 01, 2015 1:15 pm Post subject: |
Bajaman65 wrote: |
Stan |
Hope it works out. I'm not going to try it. Pulled the motor apart again. Waiting on the webcam lifters to come in. Going to be outting the udo's in the classifieds to help pay for things. People seem to be doing fine with the pifters that each company recommends so thats what I'm doing. Web told me over the phone that their cams are not compatible with udo lifters. They will pit. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Just got off the phone with webcam....they say not to use udo be ker lifters with their cams. Straight from the horses mouth. |
But Why? What did they say other than they make their own lifter; which means they want you to use theirs.
I have a Web 86C and Udo's that I have yet to fire. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
