damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Tue Jan 26, 2010 6:58 pm Post subject: double thrust cam bearings |
I am putting in my double thrust cam bearings and one side of the case accepts the off set tang on the bearing but the other side doesn't have the notch in the case for the other half of the bearing to set into.
Both halves of the cam bearings have this off set tang.
What do I do? _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15302 Location: Deep in the 405
Posted: Tue Jan 26, 2010 7:00 pm Post subject: |
File off the tang on the bearing. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Tue Jan 26, 2010 7:06 pm Post subject: |
Duh! I shoulda done the search thing first. I found it in another thread.
Thanx Dave _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Tue Jan 26, 2010 8:20 pm Post subject: |
I filed the tang into the case, it takes 5 minutes and you won't have to worry about a spun bearing. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Wed Jan 27, 2010 11:46 pm Post subject: |
I got the bearings in the case and they were tight. I filed the thrust side on the flywheel side to .002.
I installed the cam in the case and torqued it down and checked the end play and got .001.
With straight gears, will this be enough clearance or should I go for more? _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
Posted: Thu Jan 28, 2010 6:47 pm Post subject: |
Will .001" clearance be enough? _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Sat Jan 01, 2011 9:54 pm Post subject: |
What did you wind up doing?
I hear the window is .002" - .004"
Checking mine tonight. As usual, reading a bunch of threads looking for the one thing I may have missed. _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Jan 01, 2011 10:57 pm Post subject: |
In my case, the bearings did not fit right. I had to peen the sides where the thrust part rides against in order for the bearing to not wobble side to side. _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
74 Thing Samba Member
Posted: Sat Jan 01, 2011 11:16 pm Post subject: |
Put the cam bearing in and with the case split put the cam in 1/2 the case and hit the front and rear of the cam with a hammer and punch and then do the same to the other 1/2 of the case-then take your measurements. |
gerg a.k.a. 6volt65
Posted: Sun Jan 02, 2011 12:07 am Post subject: |
I read another thread where Raby described that. Tried it with no polishing and only got < .001". Had to polish a tad. I have case torqued now and just shy of .002" end play after tapping each end with wood drift to seat / center bearings. _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Sun Jan 02, 2011 7:55 am Post subject: |
What I ended up doing was taping them together and sanding them on a flat piece of granite with some wet/dry paper w/ oil and doing both sides a little. Put them back in with an old cam and gave it a gentle wack on both ends of the cam to seat them.
Then tried the new cam and it fit w/ .002side play. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
slalombuggy Samba Member
Posted: Sun Jan 02, 2011 10:35 am Post subject: |
kielbasa wrote: |
In my case, the bearings did not fit right. I had to peen the sides where the thrust part rides against in order for the bearing to not wobble side to side. |
Your case is probably worn out and you by doing what you did just introduced huge amounts of endplay on your cam shaft which will pound the bearing to death in short order.
brad |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sun Jan 02, 2011 11:05 am Post subject: |
For me a file takes off just too much on the thrust edges. I take 600 grit w/ a little water on a straightedge and lightly sand my edges down till it fits. I do this until it doesnt pull the bearings out when i pull the cam from the case. Takes me like 5 minutes a piece usually. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
gerg a.k.a. 6volt65
Posted: Sun Jan 02, 2011 11:16 am Post subject: |
I used 800 grit on a vent wing glass, and some liquid wrench spray oil as a lube. _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
