My 1966 EZ Camper Thread.. Pic heavy...
Page: 1, 2, 3, 4, 5, 6  Next
Emeritusx
Emeritusx is offline
PostPosted: Thu Jan 28, 2010 2:52 pm    Post subject: My 1966 EZ Camper Thread.. Pic heavy... Reply with quote
Ok for the sake of prosperity and to introduce myself although I have been posting all over the place (Its hard to keep up with the Vanagon Forum) I never started a thread for Maria my 66
I never cut her, nor did I remove the bulkhead (in fact I want to build a tubular bulkhead to strengthen it back to VW specs)
I got her for 4K about 2 years ago, and have driven her some, but not like my other buses. I only have one leg and splittys are hard to drive with no ankle for the accelerator.
So I decide its time to pull it apart and put in a new clutch, get the gas gauge working and quit lurking on the samba and do some work..
Upper left bolt is kicking my ass... Late model engine with homemade stud thingy.. Oh well I will keep at it...
Here is Maria:
Maria first day home..
Side view
Undercarriage (POR Silver, still have to finish):
Smelt like mice
Inside after pulling the rot
New insulation:
FatMat and POR
Insulate and flooring:
Put the original (when I bought it) walls and cabinets back:
LED interior lights:
Inside:
Outside:
Side view, I replaced the broken scoops and broken wheel well trim, I cut neither.
Using it as my summer camper
Camper plate:
Engine:
Gauge set one:
Holes were there, so I filled them with these:
Close up:
Bolt that is killin' me:
Anyway Big changes coming this summer.... Gonna get her back into tip top shape So I needed a thread to document it all...
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
williamblanda
Don't Disgrace The Eddy!
williamblanda is offline
PostPosted: Thu Jan 28, 2010 5:39 pm    Post subject: Re: My 1966 EZ Camper Thread.. Pic heavy... Reply with quote
Emeritusx wrote:
I really like this set up. Looks period correct. It's nice.
Since this is an "introductory" thread for you and Maria, welcome.
Feels kind of weird saying that to someone with 1070 posts!
Stop Fracking
www.DasVolks.com
John Muir's Engine Sounds
faster
faster is offline
PostPosted: Thu Jan 28, 2010 5:46 pm    Post subject: Re: My 1966 EZ Camper Thread.. Pic heavy... Reply with quote
Your right on that looks great but needs the oil gauge. I`m going to add that to my bus for sure. Cool
PS nice bus.
My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/
Emeritusx
PostPosted: Thu Jan 28, 2010 5:53 pm    Post subject: Reply with quote
JEGGS is where I picked up those gauges, they have other antique looking ones too.. Even speedo if a person was to go that far
Jerry
Jerry is offline
PostPosted: Thu Jan 28, 2010 7:24 pm    Post subject: Reply with quote
Nice looking bus!
Looking for SO34 parts.
thevwcompound *instagram*
westy_LA_fade_away
westy_LA_fade_away is offline
PostPosted: Fri Jan 29, 2010 9:12 pm    Post subject: Reply with quote
Nice -- I met you at Mo-Kan a few years ago, and have seen you and Maria at a few swaps. Love your bus, man! See you around KC in the spring - Looking foward to catching up again...
-Marc
ratherb-buggin
I'm going to try to pick up a few other trannys for more options.
JacsWagen
Sometimes function over looks isn't bad, unless you're at a bar.
Cheers!
Marc Schumer
1979 Riviera pop top camper
[email protected]
_______
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
bill may
bill may is offline
PostPosted: Sat Jan 30, 2010 10:01 pm    Post subject: Re: My 1966 EZ Camper Thread.. Pic heavy... Reply with quote
that is a knurled pressed in sleeve. looks like someone used a vice grip to try and loosen it from the WRONG side. you need to loosen from the trans side next to arm that is part of clutch mechanism.
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Emeritusx
PostPosted: Sat Jan 30, 2010 10:29 pm    Post subject: Re: My 1966 EZ Camper Thread.. Pic heavy... Reply with quote
After I felt that it was round I went and looked at the Thing engine and saw it was part of the case
On the tranny side though is a built in notch bolt holder so the bolt wont spin (older blocks had no threaded casing but used nuts in the rear (RIR) on the upper tranny bolts) So I cant get a socket on the GD nut. I can get a stubby 3" 11/16ths on it (open end) but I cant torque a 3" wrench hard enough to turn the weird ass nut/stud that the PO used.
bill may
bill may is offline
PostPosted: Sun Jan 31, 2010 7:27 am    Post subject: Reply with quote
use a ratchet,a 12" or longer extension and a 17MM/11/16" socket and get it out of there. next time you can space it away from the trans with a lock washer/washer to clear the angle part around bolt hole. if not going to use a doghouse cooler you can remove the pressed in sleeve and use a nut at engine side.
www.sv2s.com
SBS #100
Emeritusx
PostPosted: Sun Jan 31, 2010 8:38 am    Post subject: Reply with quote
Cant get a socket on it... Like I said.. The socket walls are to thick to get on the nut because of the v shape knotch (see it on the Tranny side photo..)
Cant get a chisel up there... I might have to pull the trans with it.. Sure dont want to though... ANyway it might be warm enough today to try it again..
Emeritusx
PostPosted: Sun Jan 31, 2010 3:30 pm    Post subject: Reply with quote
Here is what I am talking about... Pulled and ordered new heat exchangers so now maybe I can get a chisel on it
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jan 31, 2010 3:42 pm    Post subject: Reply with quote
with the heater boxes out of the way i think you could drill straight through the side of the nut and stud using something like a 1/8 pilot and 3/8" to finish it off
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Mon Feb 01, 2010 3:51 am    Post subject: Reply with quote
I like this too will it get damp when the vent is open? I have to replace my plate to weld up a hole perhaps I'll add this too. White faces look really good.
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
Emeritusx
PostPosted: Mon Feb 01, 2010 8:40 am    Post subject: Reply with quote
My old voltage gauge had a water line on the glass - so I i,agine it could get wet. I have driven in the rain and that area was dry, but I suppose with the vent open and a good down pour.. But I really never use that vent, just crack the safari's for air...
Emeritusx
PostPosted: Sat Feb 13, 2010 4:54 pm    Post subject: Reply with quote
Finally got warm enough to tackle this nut again... Got it... POS.. Smile
PBlaster and a chisel...
Engine out:
missing dog house air tin
Now tank comes out next:
PostPosted: Sat Feb 13, 2010 6:24 pm    Post subject: Reply with quote
Isn't it like a major celebration when you can get those off. Good for you. BTW I like that silver por job on the chassis. Without getting too personel how do you shift into gear?
Lind wrote:
Emeritusx
PostPosted: Sat Feb 13, 2010 8:56 pm    Post subject: Reply with quote
Mentally? or Physically?
Physically:
see the stick? -----.............................^
Mentally:
Emeritusx
PostPosted: Sun Feb 14, 2010 9:49 am    Post subject: Reply with quote
I see one thing now after looking for clutches... The P.O. put a new style pressure plate on an old style throw-out bearing.. Maybe that was why my clutch always felt weird...
Looks like I have a seal leaking too...
Emeritusx
PostPosted: Wed Feb 17, 2010 7:20 pm    Post subject: Reply with quote
Old Pressure plate:
Oil all over:
Gas tank out, and see the hippy hole... Damn..
Enjoying a sunny cold day:
Emeritusx
PostPosted: Tue Feb 23, 2010 1:24 pm    Post subject: Reply with quote
Sun is out, still cold but I want to get things ready.. Started cleaning the block and noticed this:
Freakin' nuts are almost falling off...
There is like 1/4 inch slop in the crankshaft... Looks like that 1776 is nearer then I thought...
Page 1 of 6
