Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Sat Oct 22, 2011 11:07 pm Post subject: |
Been a little bit of a learning experience... and slowly coming together.. Broke a rear brake line, it was fragile and just snapped in my hands...
cleaned the floor....
brake plates going on
buttoned up - oil in trans
other side almost done but -
broke the dang brake line...
New final gear 4.12 no redux - cant wait to test drive it... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sun Oct 23, 2011 1:13 am Post subject: |
Looks like that line was due to be replaced anyway. You should replace all of them. |
Posted: Sun Oct 23, 2011 7:47 am Post subject: |
RPGreg2600 wrote: |
You know - that's a good idea..... I bet that other one is just as fragile... Never even thought of it.. (miss the tree due to the forest) Thanx... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sun Oct 23, 2011 4:40 pm Post subject: |
Emeritusx wrote: |
Fixed my brights finally
Fixed the blue lens too... Cant wait to see it tonight... Cleaned the inside of the speedo too... It was pretty easy to take apart... |
Great job on the bus, I have one question, my generator light (Red) is on the left side and oil (Green) is on the right
do I need to switch them? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sun Oct 23, 2011 5:41 pm Post subject: |
no - I have them in backwards... My oil light is red and gen is green... They were both brown when I got the bus, I musta switched 'em when I took the speedo apart.... I have seen the red one blink after a hard run and then idling when its 100 degrees out.. my bad.. It's a jersey thing _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Tue Oct 25, 2011 4:19 pm Post subject: |
3.5" Drop... 2.5K at 55 - Love the new gears... Glad I did not go taller... This seems about perfect... Can actually do 55 in third..
Driving the Thing for now...
need to change to a more normal exhaust next:
sits pretty low... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Tue Oct 25, 2011 9:59 pm Post subject: |
Cant wait til the front is done.... _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Thu Jan 05, 2012 9:37 am Post subject: |
trailing arm - drat...
link pin from that arm
impact socket and a 12lb hammer takes these out...
used swing arm as a holder to drive out bushing
bushing installed....
slowly but surely, I now know that king pins and link pins are two different things _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Tue Jan 10, 2012 10:01 pm Post subject: |
Now sitting about 4" lower... Taller gears, really starting to feel like a highway machine...
changes made:
2161 engine
4.12 straight axle
flipped spindles
dual master for brakes
third brake light
safari's
snazzy horn button
paint
Posted: Tue May 22, 2012 8:11 am Post subject: |
Here she is with the new gears...88848 on the odo.... 300 mile trip last weekend to break her in... I love no redux...
68mph (GPS) at 3100ish rpm.... Sweet _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
